Question about Lenovo ThinkPad R51e Notebook
Hello, I would like to upgrade lenovo ram memory. I have a RAM card. How can I place it there?
  • Lenovo Master
  • 32,281 Answers
The memory specification for the Thinkpad R51 is as follows:-
  • 64-bit Double Data Rate (DDR) non-parity SDRAM memory
  • PC2700 at 333MHz
  • Two 200 pin SO-DIMM memory slots, one slot is pre-populated with 128MB, 256MB or 512MB, leaving one socket available
  • Supports up to two 1GB SDRAM SO DIMMs
  • Supports maximum memory up to 2GB
Posted on Jul 20, 2009
  • Chris Hingee
    Chris Hingee Jul 20, 2009
    The memory modules are located behind a screwed panel on the bottom of the laptop.
    After the panel is removed there is a DIMM slot where the memory module sits. Push the edge on the module into the slot (there is a notch on the edge of the contacts and it will only fit in one way) and then lower the module until the side clips lock the memory module into place.
  • Lenovo Master
  • 32,281 Answers
On the bottom of the laptop there are one or two panels, remove the screw securing the panel. The RAM module are behind one of the panels. If the memory module does not fit in the memory slot, then you have the wrong type and you need to purchase the correct memory type.
Your friendly computer shop can advise you on the correct type and speed of the memory module your laptop requires.
  • Chris Hingee
    The RAM cover is on the bottom of the laptop under a screwed panel.
    When you remove the panel there is a DIMM memory slot, insert the memory module into the slot, there is a notch on the edge of the module and it will only fit in only one way, the lower the card until the side clips lock the module into place.
How do I update on my Lenovo tablet when it says insufficient storage
Hi Debra
I don't use the Lenovo , I use an iPad
But
If they are using internal fixed memory and there is no way to connect an external SIMM memory chip. And you have reached the maximum memory of the devices configuration. Eg 16gb
Then the only way to free up space is to start removing Photos, Movies and APP's from your device. They all take up space in memory.
Check out the Upgrade capabilities below
Cheers
Lenovo ThinkPad X230T Upgrade Memory up to 16GB RAM
Lenovo Tab 2 A7 30 How to put sim card and memory card
Oct 14, 2016 | Lenovo Tablets & eReaders
How do I clear up storage. Tried to update games but keep getting insufficient storage on my Lenovo tablet
Already supplied answers on earlier post!
Hi Debra
But
Cheers
Want to upgrade RAM for my Laptop, Lenovo G50-80. Can any one please suggest any Lenovo authorised Laptop service center in Dubai?
I am not aware of any in Dubai. You can upgrade up to 16Gb.
See link for details. It is not complicated to replace the RAM.
http://www.mrmemory.co.uk/memory-ram-upgrades/lenovo/laptop/g50-80?search=lenovo+g50
Aug 10, 2015 | Lenovo Computers & Internet
Ram upgrade
no you have to use pc2700 for the pavilion ze2000. Max Memory 2gb (1gb x 2).
Aug 23, 2013 | HP Pavilion ze2000 Notebook
Specs say the Lenovo G560 067999U has max memory of 8gb. ordered 2x4gb for the total 8 upgrade and it won't take the 8. it will see 6gb not 8. did anyone else come up with this issue?
Hi, i have same notebook but not the same problem.
Maybe your graphic card taking some of memory or they make mistake in the PC shop.
Download CPU-Z utility http://www.cpuid.com/softwares/cpu-z.html (download is on the right side)
Run it and go on Memory tab where you see your total RAM memory then you can go to SPD tab and see what memory exactly is installed in every slot.
Hope it will help you :)
May 20, 2011 | Lenovo G560 067999U Notebook
Lenovo 3000 y410 graphic card upgrade?
Lenovo Y410 System RAM can handle up to 2GB of memory. Since the machine has 2 slots for RAM and you already have 1GB preinstalled with the computer all you need to purchase is another stick of 1GB RAM.
There is no chance of upgrading Graphics card since it doesnt have a video card slot and the preinstalled VCARD is onboard.
Should you have any other questions just please leave a comment.
Cheers~
Jul 14, 2010 | Lenovo 3000 Y410 Notebook
Upgrade RAM
You will need to get to Hardware store around you to get that upgrade. It won't cost much to upgrade.
Best regards
May 08, 2010 | Lenovo 3000 Y410 Laptop
What is the optium ram upgrade for a lenovo 3000 y410
DDR2-PC5300, and the max it will accommodate is 2GB (2 x 1GB).
Hope this helps you
Mar 17, 2009 | Lenovo 3000 Y410 Notebook
Ram Sharing
there is a hardware compatibility list for all pc, chances are your pc have exceeded its maximum allowance for any upgrade, even though you have installed a higher value or capacity of RAM.
try reinstaaling once again and make sure you have the right speed allocation on your RAM , make sure that the ols RAM and the new one has the same PC___
Aug 08, 2008 | Lenovo 256MB ATI X1600 Pro VGA DVI-I...
Lenovo ThinkPad R51e Notebook Logo
159 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
