Question about Ashdown Perfect 10 Bass Combo Amp Car Audio Amplifier
Perfect ten bass amp, guitar
Bought this amp second hand last week,(thanks to the nice guy) when i play my bass through it, it sound very slightly blown, as if ive got somekind of fx pedal on.The notes arent clear or crisp.
It does this wether its played loud or quiet,which makes me think its not blown and its something in the amp which is easily fixed. thanks for any help.
    Scholar:
  • 73 Answers
Can you use headphones? if so do they sound normal. probably have bad filter caps. 2200uf caps big ones, go bad and lose their capacitance and cant process the low end notes, sounds like a motorboat or ******* out. speaker may have issues as well. get the caps from mouser.com and careful of stored voltage on the capacitors it is deadly....... those caps are less than 2 bucks each.
Posted on Mar 10, 2010
No sound from hofner icon bass
there is a switch in the jack socket that lets it know jack is in use. when the stop working it usually means you need to change the jack, you cannot bend the part back with out breaking it so just best to change it. you can get a replacement jack from ebay, or any electrical supply shop that does small components.
Jul 02, 2017 | Hofner Icon Series Beatle Bass Guitar LEFT...
I turn my fx off but can still here it and the od sound is lower than the fdx button when i push it in to turn it on
2 things 1: there is no off button for the built in digital effects, you just turn the level down to minimum, the fdx button you speak of is actually fdd (frequency dependant damping) this is supposed to mimic how a tube amp sounds
2: when you press the od switch the amp goes into hi gain mode and will hiss with no input, the point is if you plug a guitar in and play it the volume of the guitar is way above the hiss and you don't hear it
so in conclusion having bought and sold many mg series amplifiers the on you have is perfectly ok
Mar 10, 2012 | Marshall Mg15dfx 15-Watt Combo Guitar...
Fender Deluxe Active Jazz Bass buzzing when i don't have my hands on the strings
Try reversing the wires in your input jack. Please repost results. Thanks!
Nov 12, 2011 | Fender Deluxe Active Jazz Bass Electric...
Bass Guitar Keeps sound keeps cutting in and out.
There is an inconsistency in your text. You indicate that cables were swapped and problem still existed...
You said:... "i have tried using it on a different amp and still fine".
If you tried it on a different amp and it was still fine then the guitar is probably OK.
THEN your amplifier is in question as the root of your problem.
What is the amp you have? The guitar is the CB-42, but what amp do you have?
MANY intermittent problems with amplifiers are often with the input jack itself. These jacks are easily broken by tripping over a cable plugged into them.
Jan 04, 2010 | Fender Rumble 100 Bass Guitar Amplifier
My bass guitar wont connect to my amp.
Assuming that the amplifier is functioning properly, I suspect that the problem is either in the cord, the plug socket on the bass, or the volume control potentiometer. First, I would try another cord that is known to be in good condition (ALWAYS plug the cord into the instrument FIRST). Second, carefully remove the cord receptacle plug from the bass and examine the solder joints (check for loose wires). Third, carefully remove the plate that holds the volume and tone pots. Examine these controls for loose wires or faulty solder joints. CAUTION: If solder joints are found to be the culprit, care must be taken to correct this problem. If too much heat enters the pot, it can be ruined!
Dec 31, 2009 | Music
Fuzzy sound when instrument being played
The 1/4" output on your bass needs to be resoldered in 1 or more places. It's very common.
Mar 28, 2009 | Audio Players & Recorders
Sound through one channel only.....NAD 310 Amplifier
If swapping of left and right input sources and left and right speakers does not help...you might have a bad channel in your amp.
Sep 24, 2008 | NAD Audio Players & Recorders
No sound
i'm having the same problem. theyre not playing bass because it's on face off and pro face off too. it's also not the gh 3 disc because it does the same thing to me on gh 2 and rocks the 80s. it has something to do with the ps2.
Dec 31, 2007 | Sony PlayStation 2 (PS2) Console
Setting knobs for amplifier
Hi gv6257
What sort of amp you play. I will help you sort it
regards
tobotek
Dec 27, 2007 | Audio Players & Recorders
Bass amp for guitar?
i say it can! u would get a nice clean sound! acoustic guitar sounds nice through a bass amp!
you probably wouldnt get distortion out of bass amp though! depends on the bass amp! some bass amps have built in effects! e.g distortion
Oct 15, 2007 | 3Com SuperStack II advanced RPS...
Ashdown Perfect 10 Bass Combo Amp Car Audio Amplifier Logo
111 people viewed this question
Top Ashdown Car Audio & Video Experts
xxxxxx xxx
Are you an Ashdown Car Audio and Video Expert? Answer questions, earn points and help others
