Question about Miele Touchtronic T1403 Dryer
The filter/vent light comes on at the end of a cycle, I have a miele touchtronic T1403 dryer. What does this mean?
The light will switch off on the next load but come back on at the end of the load. What do I need to do?
5 Suggested Answers
  • 4 Answers
SOURCE: Miele 9820 dryer has check
I am adding some pictures to help with the resetting of the thermostat. It is actually much easier if you pop open the top and remove three screws on the top side of the left panel in addition to the three in the back. That way you get more room to work with.
Hope it helps.
1_22_2012_8_27_01_pm.jpeg1_22_2012_8_27_25_pm.jpeg1_22_2012_8_28_04_pm.jpeg1_22_2012_8_28_35_pm.jpeg
Posted on Jan 22, 2012
  • 91 Answers
SOURCE: My Miele Touchtronic T 9800 Dryer progrma works
Hi dear.Try this,that should help you to solve the problem.If you need to download the user manual please click the link below.Thanks.
http://www.mieleusa.com/manuals_pdf/Residential/Dryers/T9802_us.pdf
Problem:The laundry is still wet. The program runs too long.
Solution:The air flow is insufficient. Check the lint filter, air intake and vent for obstructions(REFER USER MANUAL)
Posted on Aug 29, 2010
ginko
  • 19396 Answers
SOURCE: I just had the softwear
Hi.
Try holding down reset for several seconds. If that does not work, then there is a problem with sensitivity settings of the signal from the two sensors in the air duct. Call Miele and insist to get a tech at home, the problem is not your fault.
Here a discussion on the same issue.
Posted on Sep 10, 2010
  • 251 Answers
SOURCE: I have a Miele T9800
Hi - it makes me wonder as why we always tend to do things first prior to seeking the right/correct advice.
A T9800 Miele is not your everyday cheap dryer as you will know - the questions is have you still got your user Manual and if you do - have you read it carefully - it will tell where the problem lies and how to clean it.
I cannot grasp the fact that you would remove the rear access panel for a heater bank to check the resetable over temperature unit.
The machine clearly indicated a vent/filter error not a heat error - I know at this moment you have and are swearing & calling me names...
I will let you cool down a little ....................and I will tell you what you should have done instead of removing that panel Ok?
Posted on Jul 16, 2011
Error code 1477 on Miele T8322 Drier. What does this mean?
not sure bout the code. but it seems to indicate that the dryer is shutting down at certain heat levels. Thus u may have issues with ur cycling thermostat or thermal cut off or even ur venting and duct system.
Jan 28, 2015 | Miele Dryers
Miele t1403 makes rubbing sound
Sounds like the Felt is worn And sometimes it hits just right to make noise
Dec 02, 2013 | Miele Dryers
Miele Touchtronic W1213 Front Load Washer: The washer keeps adding and then draining water continuously. One time, the cycle ended and the machine continued to add water and drain endlessly....until I...
hi - If I remember correctly this particular series had a time related sequence built into the programme, whats happening is the timer has picked up the false readings when the pressure activates the switch.
Suggestions to look into - leave power off & turn water back on - does water run into the machine (faulty valve); turn power on initiate a cycle water runs, then turn power off - is water still running? (faulty valve)
From experiences on the field, theres a slim chance that the pressure tube has a hole in it from the vibrations over time. This effect will not create enough pressure in the tube to activate the pressure switch, the only other problem would be the pressure switch itself.
May 17, 2011 | Miele Touchtronic W1213 Front Load Washer
My Miele Touchtronic T 9800 Dryer progrma works but when the dryer has ocmpleted its cycle, the cloths are still damp and not dry.. .I have to run the cycle several times to even get near dry cloths. what...
Aug 25, 2010 | Miele T9800 Electric Dryer
Problem with Miele Touchtronic T 9800 Dryer end indicator
You've most likely got a bad control board. You'll have to install a new one which can be a bit expensive but cheaper than a new machine by far. I recommend getting a service tech to replace it for you however if your handy you could replace it yourself. Just get the new control board from an appliance parts store, they should be able to look up which board you need as long as you bring them the model number.
Dec 15, 2009 | Miele T9800 Electric Dryer
Miele intake light on since new sink,disposal installed
check and see if the disposer drain port plug was removed. intake/drain light means slow drain or no drain
Feb 04, 2009 | Miele Touchtronic G892 Built-in Dishwasher
My clothes are not drying fast enough
Hello. I was the last person to post with problems with the Miele T1403 Electric dryer. Just wanted everyone to know I solved my problem and this could solve yours as well. To reiterate I too was frustrated with clothes that would not dry. I could feel heat but the vent/filter light would keep beeping and evetually turn off my dryer. The result would be damp clothes especially towels!! I had a certified Miele dealer come in and check out the machine. This was after I completely cleaned out the lint trap the inside of the machine, and the duct connecting it to the wall. Well they looked at everything and determined nothing was wrong with dryer and I had done a great job cleaning it. Armed with this info I was referred to a company that specializes in cleaning the entire interior duct system of the dryer(Not just the lint trap, inside of machine, and connector tubing). They came today and disconnected the machine again went into the attic and used a shopvac type of machine to really clean the entire duct system. Not rocket science but viola problem solved!! You could probably do this yourself if you have a shopvac with a long attachment (depending on how many bends your system has). The machine is working great and now I know to clean the system at least once or twice a year. I was told that slow drying clothes, extra moisture, machines that are very hot to the touch,etc. can all be symptoms of a blocked vent. By the way a blockage can be a fire hazard. This solution is a lot cheaper than a service call or worse getting a new dryer. I wouldn't listen to the hype about European dryers like Miele or Bosch not drying clothes all the way-could just be a blockage. These brands are very good at shutting themselves off when they get hot (which is a good thing).
Aug 24, 2008 | Dryers
Miele touchtronic 1113 washer
There is a float switch in a pan under the machine. This pan is probably full and the float switch is causing the Intake & Drain fault signal. You can lean the machine over to towards the front to partially drain the pan. Put a towel down to catch the water. When you put the machine level again the fault lights should be out. The real question is where did the water come from. You can easily remove the top (4 screws, 1 on each side behind the little plastic caps and 1 on each side of the back. Torx heads) and look down inside while you start the cycle. Look for leaks.
Good Luck,
Dan
Aug 09, 2008 | Miele Touchtronic W1113 Washing Machine
Miele Touchtronic T1403 Dryer Logo
Top Miele Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Are you a Miele Dryer Expert? Answer questions, earn points and help others
