Question about KitchenAid K45SS Classic Stand Mixer
Question I asked you how to adjust the depth of the dough hook on my mixer. Your response was right and wrong. But it was my fault. I checked and the model number is K5SS, not the one that was on the screen at the time I asked the question. When I asked the question I couldn't find the instruction book, but since then I have and have seen that there is no problem with the depth. Thank you for your response. Steven Mandel
Your question can be resolved as follows, but first go to this link for a copy of the user manual:
http://forum.kitchenaid.com/forums/pdfs/u_c_classic4.5_5qtmodels.pdf
On page 11 of the manual, note there is a screw that enables changing depths of mixer attachments thus preventing scrapes on bowl. These adjustments must be done rather slightly. Do not over-adjust. Click a degree or so at a time. Trust this resolves and happy cooking (or baking) as the case may be.
Regards
db from nyc
Posted on Feb 14, 2009
How can I adjust bowl depth?
KitchenAid K5SS Heavy Duty Commercial Stand Mixer ...
www.fixya.com/...kitchenaid...k5ss_heavy_duty/adjust_beater_height
KitchenAid K5SS Heavy Duty Commercial Stand Mixer, adjust beater height related issues. Get free ... Beater hits bowl beater height adjustment screw does not fix problem ... beater ... ...adjust beater depth-it is scraping the bottom of the bowl.
KitchenAid K5SS Heavy Duty Commercial Stand Mixer Adjust
www.fixya.com/search/p105880-kitchenaid...k5ss_heavy_duty/adjust
KitchenAid K5SS Heavy Duty Commercial Stand Mixer, adjust related issues. Get free help ... How can I adjust beater to bowl clearance on my Kitchenaid mixer? I have a kitchen ... How do I adjust the depth of the dough hook. how do I adjust ...
How To Adjust the Bowl Height of Your Stand Mixer ' The ...
www.thekitchn.com/how-to-adjust-the-...
Apartment Therapy's The KitchnFeb 10, 2011 - In the world of stand mixers, there's two different types. ... It's easier than you think and will make your appliance last longer and food taste better! ... If yourbowl height is too high, you'll hear the adjustment needing to be made before you ... I have a different issue with my KitchenAid Artisan mixer (tilt head).
Dec 25, 2015 | KitchenAid K5SS Heavy Duty Commercial...
Drive Shaft stopped kneading dough
To give the mixer strength it has planetary gears. Something may be wrong in the gear section
Nov 26, 2013 | Bosch 800-watt Universal Plus Mixer with...
How do i insert dough hooks into stand mixer professional 600??? There are no holes.
Your Flat Beater, Wire Whip and Dough Hook attachement ends should
look the same. They are inserted onto the beater shaft and held in place
by a single pin. The reason you cannot attach the dough hook to the
beater shaft because it is the wrong hook for your particular model.
Jun 11, 2011 | KitchenAid KP2671 Professional 6 Series...
Dough hook stuck immediately after use
I just got my dough hook unstuck! The problem was the bolt at the top of the dough hook. This bolt is used to adjust the height of the dough hook. This bolt came loose while mixing and went up towards the mixer. The force of the spinning actually tightened this bolt against the mixer so when I tried to release the dough hook by lifting and turning, it wouldn't lift. The bolt was in the way! The solution is to loosen this bolt. You'll need a thin wrench that's about 15 mm. You can test loosening this bolt on the other attachments since they loosen in the same manner. You'll have to bend the white shield down slightly to get the wrench in there. It's a tight squeeze even with a thin wrench. Hold on to the lower end of the dough hook and turn the wrench counterclockwise when looking down at it. Once you loosen the bolt, you'll be able to turn the lower portion of the dough hook to lower it. Then you can lower the bolt further. Once you have them low enough, you can remove the dough hook like normal - lift and turn. Sure beats boxing it up, shipping it for repair and paying for shipping both ways!
May 03, 2010 | Cuisinart SM-55 Stand Mixer
What is the correct dough hook to get for my 'OLD' A200 Hobart?
Check with your local Hobart office.
www.hobartservice.com Click on "Locate an Office" and enter your Zip.
Jan 20, 2010 | Hobart A200 Stand Mixer
My varimixer R30 hook doesn´t seem to reach out far enuff to mix satisfactorily. Can the hook change shape just like that ? Or is the hook for some other kettle ?
This is a dough hook and would typically only be used to knead dough. Therefore, the extra clearance makes sense for kneading dough. For other mixer jobs, use other attachments.
Mar 06, 2009 | Food Mixers
Dry clumps in pizza dough
Hi. You should consider a few things. They type of hook you use, can greatly affect your end result. If you're making a yeasted dough with a high protein percentage 12-13%, you should be using an "ED" hook, this is a spiral hook that has a sharp turn at the tip. You can find them on eBay for a competitive price. I believe that Hobart also sells them, but for a higher price. They are very good for mixing pizza type doughs, they also do an excellent job kneading the dough.
Have you checked the flour for lumps before it goes into the mixer? Have you tried sifting the flour?
Are you adding all the liquid and flour at once? If so try adding flour in stages to all the liquid. If you find that this solution helps you, please rate it. Good luck! ricardok45
Feb 19, 2009 | Hobart D340-6007 Mixer
Sorry but this is not possible on this model (can not be adjusted) And just to let you know it is normal for the dough hook to sit higher then the other attachments!
Please rate this response and help us keep this area free!
Thank You!
Jan 21, 2009 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid pro 5 --dreadful noise; filings
the company jumped right in and helped me out. impressive.
Sep 08, 2008 | KitchenAid KP2671 Professional 6 Series...
Dough Hook Stops moveing under heavy load
Does the mixer work in any other speeds?Are you mixing pizza dough and in what speed?I service these mixers alot--i work for hobart.It sounds to me like you have a sheared key on one of the shafts.The mixer doesnt have a clutch.
Feb 21, 2008 | Hobart H600 Stand Mixer
KitchenAid K45SS Classic Stand Mixer Logo
100 people viewed this question
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
