Question about GE Profile Spectra JGBP90 Gas Kitchen Range
GE44XL propane to gas
I have a GE XL44 that is setup to run on propane. I am moving it to a place that has natural gas. What do i need to do to make it work?
  • 333 Answers
Contact the gas company and they will install the kit needed for the conversion. I hope this helps.
Posted on Jan 21, 2009
Convert GE XL44 from LP to gas
replace original orifices and adjust regulator to natural gas
Dec 30, 2009 | Kitchen Ranges
I have a ge profile xl44 oven and do have the
I just converted aXL 44 from natural gas to propane and I don't have a manual for it do I need to do anything for the oven part?
Also how do I light the pilot light or do I need to?
Greg
Jun 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE XL44 propane to natural gas conversion.
Hi, You will need to use a 1/2" wrench and turn the orfice for the oven 2 turns counter clockwise.
Make sure you flip the plunger over on the regulator also.
After doing these things, watch the flame in the oven to make sure no other adjustment is needed.
Please let me know if this helps or if I can assist you further.
Vic
May 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Converting back to nat gas from propane
Typically, conversion from natural to propane and visa-versa is just a simple connection behind the appliance. Look in the box of the conversion kit (or on the back of the packaging,) and you should see the conversion instructions. Since you are dealing with gas, you need to make sure the shut-off valve is... shut off so no gas can leak while do the exchange. Also, make sure there are not open flames anywhere near the work area. Take your time and follow the directions...
May 25, 2009 | GE Profile Harmony DPGT750GC Gas Dryer
Natural Gas to Propane for Ge xl44 Gas range
The kit is located at the rear of the range right near the gas valve, there are probably 5 spuds and an extender for the large burner, directions are with the range. For the bake and broil you will need to tighten the brass orifice nuts down as tight as possible, also the brass nut on the gas valve needs to be reversed
your local LP dealer should be able to do this for you if you are uncomfortable doing it yourself.
Jan 27, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I moved and after hooking up my gas dryer to gas tank it will not heat up....
were you on propane b4 the move or natural gas? A natural gas dryer will not run on propane nor a propane one run on natural gas
Jan 14, 2009 | Kenmore 73932 Gas Dryer
your going back to natural from LP??? of so tyhere is no new orifice , but hte "hood" on the end of the bake, needs to be adjusted out"loosened", LP the "hood" is secured snugged down,
Jan 11, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
Converting GE XL 44 Gas range from propane to natuiral gas
I needed parts for my GE XL44 propane converted stove. This site was very helpful. I found the part and there is online live help or toll free help. Go to: AppliancePartsPros.com
Thanks,
nnb704
May 23, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
XL44 Self Cleaning Gas Range
your set up foir the wrong type of gas
you probaly have a natural gas oven
'and your using propane
Dec 16, 2007 | GE JGBP24 Gas Kitchen Range
GE Profile Spectra JGBP90 Gas Kitchen Range Logo
137 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Craig Butler
Craig Butler
Are you a Kitchen Range Expert? Answer questions, earn points and help others
