Question about Ovens
I can't refit the oven door (Hotpoint BU 72). I disconnected the lower hinge, but the curved upper runner remains attached. Is there a simple release for the runner I am missing? It seems impos
  • 641 Answers
SOURCE: oven door does not close
Remove the side panel and you will have an access to it. Good luck !!
Posted on Jun 05, 2006
I had the same problem. The first time the Tech. came out, put a new hinge in and it held until Nov. 07. ( 8 months ). Then the left hinge brakes when I opend the door and it crashes to the floor. Bending the right hinge and the metal doorliner. Jan.7,08 everything was fixed. On 1/11 after no more then 10 openings & closings the hinge broke again. This time I heard the crack of the braking metal after opening the door 2 inches. It now sits in my kitchen propped-up with a stick, waiting for the repairman. I am sorry I have no solution , but there must be a problem with the hinges. I forgot to tell you that it started with a door that did not close, like yours.
Ingrid
Posted on Jan 18, 2008
  • 417 Answers
SOURCE: Smeg oven door off hinges
Try www.smegtech.com/site/smeg/pdf_libretti/914772524-GB.pdf section8
Posted on Oct 19, 2008
barkencoa
  • 3463 Answers
SOURCE: oven door hinge failure
U need to replace both door hinges together.
In your browser bar , type in youtube.com
Then in then search box type in fitting oven door hinge
Click on appropiate video and follow instructions.
This should be a big help to you.
Plz rate my solution.
thanks.
Posted on Dec 31, 2008
jumptrout51
  • 3361 Answers
SOURCE: Oven door hinge detached from the oven
Pull the door completely off and re-insert the door on the hinge supports.
Posted on May 23, 2009
Removing oven doors
  • Trying to clean a late 1970s Hotpoint GE Wall Oven Model "R K746 013AD" and
  • I do not know how or if the oven door is removable.
  • See photos.
  • I am able to remove the side of the door hinge attached to the oven but am not sure about the hinge attached to the door.
  • I do not have the owners manual.
Jan 01, 2014 | Ovens
After changing the right door hinge on my bosch hbl455auc the door closes but the upper oven door is 1/8 lower at right top than left. How can I realign the door to level?
There are adjustment screws or bolts on the hinge attachments to the oven. Loosen them and adjust the door using wedges to hold the door in place.
Jan 12, 2013 | Bosch HBL 455 Stainless Steel Electric...
Reinstalling oven door which was removed by overseas movers
Have a look on You Tube, there are a number of videos that demonstrate how oven doors can be removed, it normally revolves around latching the hinge. Refitting is a reversal of the process.
The following video shows a number of different methods to remove and refit the oven door
Hopefully, one of the methods shown in the video will help you.
Jun 15, 2012 | Hotpoint Ovens
I would like help refitting my oven door
Not being able to see the problem, may I suggest you beg, borrow or steal a couple of strong magnets to hold the plate in place while you attempt to re-attach the doors.
Once you got one more or less in place you can use a nail or small screw driver maintain or adjust position.
Jan 30, 2012 | Ovens
We have a Hotpoint double oven spec# BD52K and after having the element refitted have notice that the bottom oven door no longer fits flush causing the oven not to seal correctly. is there any way that...
Assuming that the door was not removed for the new element to be fitted, then it sounds to ne as thiugh the oven door hinges are weak.
The only solution is to replace both door hinges,
If the door was removed, then it could possibly be not fitted back correctly.
Jan 28, 2011 | Hotpoint Ovens
Door does not close tightly ? problem with bottom hinges
Yep, sounds like the hinges/springs have been overloaded.
Dont know if it's a Neff problem in particular, but I had a Neff oven with exactly the same problem - it was already installed when I bought my house.
Spoke to Neff who advised this ocours if heavy things like a roasting tray with a heavy bird / joint in it is rested on the door whilst it's open.
Only cure is new spring/hinge units which are not cheap !
Sep 18, 2009 | Neff B1421 Electric Single Oven
Last year, my 8 year old Whirlpool oven door would not stay closed all the way. I ordered new hinges, replaced them and it was great for 11 months. Still under warranty, I replaced them a second time......
Are you replacing the hinge guides as well? The hinge is usually only one half of the problem. When you remove the door, look into where the upper long arm of the hinge resided. You will see a little runner wheel. Touch it with a thin screw driver and see if the wheel feels loose. I'll bet at least one of them is!
Jun 25, 2009 | Frigidaire 24" Single Gas Wall Oven with...
Oven door does not close fully
You need to replace the oven door hinges.
Please rate my solutrion.
Thanks.
May 15, 2009 | Neff B1421 Electric Single Oven
How do you replace a upper door hinge on a Fridaire fgb24t3asa?
you would need to remove the unit form th ecabinet, at least partially, for the spring is atached to the lower frame of unit , so yyoull need to reomove the side panel to gain acess to this spring,simple hing e to change just a pain in the a** to try to get to!
Mar 01, 2009 | Frigidaire GLEB27S7A Electric Single Oven
Jenn-air JJW9630CAS - double wall oven -door won't close, even after hinges replaced
On my double oven the bottom door was not closing by at least 21/2 inches the upper door would allow the light to stay on . Upon close examination this problem appeared to be the door was too low which did not allow the gasket to seat in the oven cavity, holding the door open. new hinges and receptors did not resolve this condition.This is how I corrected this condition. 1 open the doors one at a time and lock the hinges.2 remove the doors from the receptors (be careful they are heavy) and set aside. 3 remove mounting screws holding oven in cabinet. 4 slide oven forward enough to hold onto receptor sockets on left and right sides lower and upper 5 remove receptor sockets by removing the screws in front of oven(be careful to hold on to the receptor so it doesnt fall behind oven into cabinet)7 with a center punch punch a start point 1/8 inch above the existing screw holes and drill appropriate size hole for screw THE HOLES MUST MATCH UPPER AND LOWER RECEPTOR OR THE SCREWS ON THE LOWER DOOR WILL SCRATCH THE UPPER DOOR .8 attach receptors to oven in new holes 9 slide oven back into cabinet and replace screws removed in step three 10 attach doors into receptors and push locks forward into receptor cavity attach lower door first and check for operation then upper door open slowly and check enough clearance exists for the screws on the lower door miss the upper door . If more clearance is needed elongate the holes drilled earlier(repeat steps 1 through 5) and slide receptor up on upper door. NOTE The receptors are not in a sealed space in the oven cavity and are not exposed to any heat. Periodically check the screws for tightness. After performing this procedure Both doors close all the way and the light is no longer a problem Now 20 minutes cook time MEANS 20 MINUTES COOK TIME.
HOPE THIS RESOLVES YOUR PROBLEM !!!!!
Nov 06, 2008 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
