Question about Brother MFC-8460N All-In-One Printer
Hi , My 4 in one printer get message Paper jam. MFC-8460N MFC-8460N
    Champion:
  • 320 Answers
Hello! i need to know where the jam is so that i may help you. brother tech
Posted on Jan 26, 2009
It says there is a document jam and to clear scanner but there is not paper in the machine. What do I do?
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Nov 09, 2010 | Brother MFC-8460N All-In-One Printer
Overheats when printing pictures on transfer paper and now it will not print anything.
hi
i have problem with my brother prinetr MFC-8460N
IT SHOWS DOCUMENT JAM
ALSO MESSAGE ON SCREN
CLEAR THE SCANNER JAM THEN PRESS THE STOP KEY
STATUS SHOWS RED LIGHT
WE ARE NOT USING SCANNER WE ONLY USE FAX AND COPY
RIGHT NOW BLUE LIGHT IS ON FAX AND WHEN I PRESS COPY BUTTON IS NOT ALLOWING ME
PLEASE ADVISE
Nov 10, 2009 | IBM Infoprint Color 1357 Led Printer
Paper jam
hi
try reset ur printer and if u want our technical support contact http://tinyurl.com/mtgjzz
Jun 22, 2009 | Brother MFC-8460N All-In-One Printer
Mfc 8460n paper jam
Check to see if this happens when you use the drop down manual feed tray. If your printer works fine using the manual feed tray the problem is with your paper tray. Check to make sure it is set to letter size. I've found that sometimes the 'teeth' holding the paper stop on the paper tray wear out and when the printer goes to pick up paper, it pushes the paper stop out of position causing the printer to think it's using a different, much longer size paper thus preventing it from feeding all the way through. You'll probably need a new paper tray if this is the case.
Jan 06, 2009 | Brother MFC-8460N All-In-One Printer
Brother MFC 8460
Hi
There must still be a piece of paper in the machine check the fuser section at the rear of the machine maybe be piece there or check at the paper cassette area remove cassette and check that the paper hasn't got jammed as it feeds through.
Thanks
Dec 29, 2008 | Brother MFC-8460N All-In-One Printer
Document jam brother mfc 8460n
you cannot clear this unless there is still a presence of paper inside the machine.
or you can open and close your machine once you are cleared of any paper jammed, be sure not to leave and removed all residual paper in the paper path, the tiny sensor would recognize any sort of this and thus make your machine unoperable.
Jul 25, 2008 | Brother MFC-8460N All-In-One Printer
Brother MFC 8460N Paper Jam
paper jams alway in the same spot- just as it's about to exit the bottom tray
Feb 08, 2008 | Brother MFC-8460N All-In-One Printer
Brother MFC-8460N All-In-One Printer Logo
175 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
