How to change the capacitor in the horizontal
My mag 786n crt monitor shirnk and i can't use it somebody told me to change the capacitor in the horizontal, but the problem i don't where to find the horizontal in the board of my crt monitor. pls. help me.
  • 153 Answers
If you know what is a flyback transformer in a CRT monitor, then you'll identify the horizontal section on the board. Refer to pics below for reference.
Posted on Jan 22, 2009
VGA cord mag 786N monitor has 9 wires fat wires light blue pinkand whitethen six regular wires orange brown yellow white green and black in what order do they connect to 15 pin male vga adapter
Sweet, looks like something that I'd being doing. Here is one of my schematics for the pin lay out..
26141804-rnsaswimapvq3myhs3omkq3y-2-0.jpg you might need to fiddle with the Vertical / Horizontal Sync wires to figure which are which. Hope this helps FixYa issue..
Have a great night..
Mar 26, 2016 | Computers & Internet
Where is usb port on model 786n mag innovision desktop
The MAG Innovision 786N is a CRT monitor. It will not have a USB port. Look on the computer for a flat input, approximately 1/2 inch wide x 1/8 inch tall. There are likely two or more together, those are your USB ports. Unless your computer is more than 10 years old...
Dec 25, 2013 | Computers & Internet
I just inherited (literally) a virtually new eMachine 786N monitor. I say, "new" because the previous owner probably logged no more that 100-200 hours on the thing. Hooked it uop to my HP...
Sounds like symptoms that the monitor needed to be degaussed (pronounced "Dee' Gowsed"),
and, since most modern (conventional CRT) monitors will degauss themselves upon power-up,
it looks like your restart addressed the problem.
Usually, a CRT that need to be degaussed will develop blurring at the edges first, but its possible
that the monitor was affected by stray magnetic field(s) over time, and failed to successfully
degauss at initial startup (the degaussing circuit won't necessarily succeed the first time if a large magnetic field has built up).
Here's your wikipedia entry on the concept:
http://en.wikipedia.org/wiki/Degaussing
Here's a how-to, in case you want to (or end up needing to) do it manually:
pcsupport.about.com/od/fixtheproblem/ht/degauss.htm
It looks like a .PDF service manual may be available free here:
http://fileshare.eshop.bg/downloadsm/30014/PROVIEW_PROVIEW%20786N.html
Sep 14, 2011 | Mag Innovision InnoVision 786 PF 17" CRT...
My problem is, how can i know the value of a damage capacitor which is exploded, innovision mag crt monitor..
For your information there is no value of a damage capacitor. It may damage transistor. So there is a complicated network of caps and coils with relay switch. You have to removed each cap and checked it for short,open, and correct capacitance. Replace the capacitor soon. Purchase a compatible capacitor and solder it.
Mar 29, 2011 | Mag Innovision InnoVision 800 Monitor
17" crt monitor after 5 min pincusion bend give me
This can be due to a change in the frequency of the horizontal section. You will need to remove the back cover and clean the set. Look for any damaged capacitor in the horizontal section relative to the pin cushion correction section. It is possible that when the set warms up the change occurs and so if you are able to cool off the suspected section the fault can eb pointed out easily using a freeze-it spray. Point to the heated section spray and see if the fault reverses if so the component is a the suspect.
Feb 22, 2011 | Samsung SyncMaster 753S 17" CRT Monitor
Mag Innovation LT916s 900p LCD with a Horizontal twitch
That is capacitors problem, I would change all the caps in the 5v and 12v power supply section, you can have bad caps with high ESR. Also look at the caps on the logic board. I use hair dryer for troubleshooting to locate bad caps.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Apr 15, 2010 | Mag Innovision 19" LCD Flat-Panel Monitor...
Mag innovision 786n winxp driver download
DriverGuide.com claims that the driver is available here
http://members.driverguide.com/driver/detail.php?driverid=489569
for US$2,99.
There is an "universal driver" also here:
http://www.edriverdownload.com/driver/MAG%20InnoVision%20/MAG%20InnoVision%20all%20crt%20models%20Driver.html
Oct 22, 2009 | Mag Innovision Computers & Internet
Looking for a free Mag Innovision 786N video driver.
You can get free drivers on this website www.softpedia.com, once you're there please click on the Driver link found on the "Homepage". You cn now search for your device driver from that point. They are free on the site.
Hope this helped.
Regards
Sep 24, 2009 | Computers & Internet
Monitor emachine
If the width is shrinking, check also if the edges are now distorted too.
If so, there is a 'bipolar' capacitor in the high voltage section that is failing.
To find and verify this, you will need a meter that can measure capacitance, and perferably, DF or losses of capacitors as well.
If you ignore this, the horizontal will continue to shrink until the deflection stops completely and can cause other, more costly parts to fail although these may also be weakened and failing.
I'm afraid this is not a DIY problem.
Aug 27, 2008 | Computers & Internet
I think it's busted
you need to open the case and check the capacitors and if they seem doomed or color is leaking then replace the bad ones that should stabilize the power to the vertical ic chip
Nov 20, 2007 | Mag Innovision LT782S 17" Flat Panel LCD...
Computers & Internet Logo
637 people viewed this question
David Payne
David Payne
