Question about Symbol PDT 3100
What are the hardware and software essentials for barcoding?
I want to use barcode scanning for fixed asset management in tape library. Which product is best suited and what are the requirements?
  • 97 Answers
If you are planning to scan on to a database or spreadsheet etc, i would recommend you just a handheld scanner kind like a LS2208 or similar.
Posted on Mar 26, 2009
Need barcode list for SG303
if you don't have the device application software download it from your cd driver that come with your device and locate the setting of the scanner in the configuration area you will find where you can initialization
Jan 14, 2014 | Manhattan Computers & Internet
Scanner won't scan library barcodes.
The barcode reader is something that the backup software typically uses to identify which tape it is dealing with.
So typically your backup software can already natively read the barcode and therefor you don't need any other software.
The linked barcode reader is probably for reading a barcode that was provided via a picture (from a scanner or camera). This has nothing to do with the barcode reader that can be part of a tape library. NET UPC Barcode Reader
Dec 14, 2012 | Datalogic QuickScan I QD2100 Wired Wand...
I have third party software to initiate scanner functions on the Motorola but they do not work. In fact I cannot even scan without using the "Rapid Deployment Client" provided with the hardware.How do I...
DataWedge is an Application provided by Symbol/Motorola to enable the scanning module also for application without the driver. Scanned barcode is sent like an usual keyboard input.
There can be just one active application using the barcode scanner. If you are running DataWedge, you would need to stop it before starting any other application with built-in scanner drivers.
To stop DataWedge just click on the barcode icon in a right down corner and select - Disable DataWedge
Sep 22, 2010 | Zebra Symbol MC5590 Wireless Enterprise...
HHP 3800 barcode scanner won't scan/read - I think
Ok I have found some info here what you need to do is download the correct driver from this site, install and you should be fine. HHP 3800r? is that the right one? http://www.honeywellaidc.com/Site.aspx/na/en/resources/product_downloads/software/?product=165
This one below is for the HHP 3800r ?
http://www.honeywellaidc.com/Site.aspx/na/en/resources/product_downloads/software/?product=140
Feb 07, 2010 | HHP Hand Held Products IT3800LR-12 Barcode...
Hi, can ls2208 scan a memorex 9840 tape bar code label? Understand that in conform to the Code 39 Barcode Specification. It doesnt seem to work. thank you.
Hello khlai. The quick answer to your question is: Yes. An LS2208 can decode (read) code 39 barcodes. However, since you are reading a barcode on a tape, I would predict that the symbology is actually 'Trioptic Code 39". Trioptic Code 39 is a variant of standard Code 39 that is used for marking computer/tape cartridges. I've uploaded the LS2208 manual to my company's website for you. Just follow these instructions and you'll be right as rain.
  1. Go to www.shiftintoblue.com/resources/ls2208_manual.pdf and save the manual to your computer (or print directly from the web.)
  2. Go to and print page 194 (12-28) that contains the Trioptic Code 39 barcodes.
  3. Take the printed page and scan the barcode labeled "Enable Trioptic Code 39".
Then you're all done! That should fix the problem. If you have any other problems, feel free to send me a message or email me. I hope this helps. Good luck!
Jan 05, 2010 | Symbol LS2208 Handheld
Scanner does not recognise ISBN Bar codes
You will need to enable ISBN symbology. You will find the barcode to enable it within the product reference guide.
Mar 16, 2009 | Computers & Internet
Printing Bar Code Labels from Intermec 3400
I am using Smartforms with Intermec printer 3400-e and it works in the correct way.
What is the software that you use to build the layout of the label? In my case Loftware.
What is the code to print the Barcodes.
In my case Code 39
Aug 07, 2008 | Intermec EasyCoder 3400 Thermal Label...
Symbol Spark LS 1004 Problem
What barcode scanner do you have? USB, SERIAL or ps2.
by the way. the old computer is it like NCR, SIEMENS or IBM because then you need to re-program your scanner.
i found a manual where you can set your pc type with barcode scanner. be careful not to scan reset defaults. because you will loose your settings.
look at chapter 4-9 and 4-10
http://support.symbol.com/support/search.do?cmd=displayKC&docType=kc&externalId=3380601bpdf&sliceId=&dialogID=33708056&stateId=0%200%205522749
If you don't know ask me. we don't want to lose al the settings.
good luck
Nov 29, 2007 | Symbol Spark LS 1004
DS-4600 Problem
Barcode scanner in sending data is being manipulated by your program it means the problem has begun to your system not in the barcode. If you are using third party software it mean the software was not able to communicate the barcode scanner.
Try to use my system POS http://www.locsys.com.ph/products.html. If happen you are located at the Philippines I can help you to settle the issue.
Please let me know if you are interested with my system I made.
Best regards,
Philip
Nov 12, 2007 | Datalogic DS4600 2220 (931061278) Fixed...
Symbol PDT 3100 Logo
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
Michael
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
