Question about Fujitsu ScanSnap S510
Scanner sleeps If there is a pause of more than 5 minutes, scanner goes to sleep
How do i turn ipod off and on
Depends on the model iPod nano but no off button only sleep! But either goes to sleep after a few minutes of inactivity! Press and hold play/pause for a few seconds to force sleep! If not being used slide hold on, to stop it coming on!
Nov 09, 2014 | Apple iPod nano
Windows sleep mode problems
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity
Dec 21, 2012 | Computers & Internet
LCD monitor turn to sleep mode
Does it turn off or go to sleep? If it turns off , there may be a setting that needs to be reset or reprogrammed. If it goes to sleep because of inactivity, just move mouse to awaken it
Sep 27, 2012 | Vocopro Ltv-5 LCD Display System
How to shutoff ipod a1236
Turn off your iPod by holding down the "Play/Pause" button for two or three seconds. The screen should go blank, and your iPod will remain off until you turn it back on again by holding down the "Play/Pause" button.2 Let your iPod go to sleep. When an iPod isn't used for two or three minutes, it automatically goes into "sleep" mode. The screen will go black until you touch any of the controls. Sleep mode uses considerably less battery power.
  • Oct 11, 2011 | Apple iPod nano
    My computer monitor goes to sleep without me prompting every 20 minutes or so?
    on most computers it will do this as a way to save power. in most cases you can change this by going into control panel > Display and then looking for power options. from there you can change these settings if you wish for it to sleep faster, slower, or not at all
    Aug 16, 2011 | Computers & Internet
    We have this odd issue where although the machine has not gone to sleep it loses network connection consistently every 5 hours after non-use. Actually, we have 6 of these machines in our business and they...
    I have many years experience repairing Canon scanners so here is my suggestion for you.
    I have seen this problem before, what happens is when your computer goes to sleep it drops the connection to the scanner, its the computer that is causing the problem not the scanner. I suggest you turn off sleep mode. Also if your doing a lot of scanning with this model I would suggest a fresh reboot daily with this scanner. If you have any other questions let me know.
    I hope this helps you out
    Mar 18, 2011 | Canon ScanFront 220 Flatbed Scanner
    HOW DO I TURN OFF THE SLEEP MODE ON MY PRINTER BROTHER MFC 7420
    Setting the Sleep Time reduces power consumption by turning off the fuser inside the MFC while it is idle. You can choose how long the MFC is idle (from 00 to 99 minutes) before it goes into sleep mode. The timer is automatically reset when the MFC receives a Fax or PC data or makes a copy. The factory setting is 05 minutes.
    To turn Sleep Mode off press Menu/Set, 1, 6, 2. Then use the dial pad to enter the length of time the MFC is idle before it goes into sleep mode, in this case 00 so it wouldn't go to Sleep mode at all. Press Stop/Exit.
    Feb 04, 2011 | Brother Office Equipment & Supplies
    How do I set the sleep timer for GE universal remote RC24991
    Usually you check for the sleep button on your remote controller. Press the button and the sleep function comes on. Pressing it again adds about 5 to 10 minutes to your time for the sleep function to come into effect.
    After the time has gotten to its highest the cycle goes off and satrts again.
    Hope this solution has been helpful?
    Oct 25, 2010 | GE Televison & Video
    I pressed the sleep button by accident and the pic and sound went off and the stand by/timer red light started blinking. what does it mean?
    Depends on how many times it blinks,just count the blinks Example: if it blink 2 times then pauses and blink 5 times then the code would be 25 and so on
    Once you have this code,please post it.
    Jul 30, 2009 | Sony KV-32S40 32" TV
    My psp won't turn off, it just goes into sleep mode
    To tur it off, hold the switch no more than one second
    Jan 21, 2009 | Sony ACY-BR81/OB
    Fujitsu ScanSnap S510 Logo
    22 people viewed this question
    Top Fujitsu Office Equipment & Supplies Experts
    Electro Med Services...
    Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
