Question about Cooking
Are there nuts in honey nut cheerios? - Cooking
    Guru:
  • 269 Answers
Strangely enough, there are no nuts in Honey Nut Cheerios. Although the box does warn that there can be trace amounts in case someone that is allergic to nuts wants to eat it.
Posted on Jan 10, 2013
How do I make glazed peanuts in a room with high humidity?
Store them in an airtight container when you're done grilling ...
Jun 29, 2014 | Oh Nuts Honey Glazed Roasted Peanuts - 5...
Keeway hurricane 50 keeps over revving
Weak return spring? Is routed correctly so it doesn't pull when the hadlebars are moved?
Feb 15, 2014 | 2006 Keeway Hurricane 50
Does anyone have an idea how good the life cereals are? They have 6 gms of sugar ! Is that a lot of sugar ?
When gms is used in the context of food, it is 6 grams, this is a small amount of sugar. Many cereals have more, few have less and according to a study by FoodPolitics.com (http://www.foodpolitics.com/wp-content/uploads/CEREALSewg_press_cereal_report.pdf), all Life brand cereals except Oh!s pass the stricter federal standards to go into effect in 2016. In fact 44 children's cereals - including Honey Nut Cheerios, Apple Jacks, and Cap'n Crunch have more than in a serving of Chips Ahoy cookies. The American Medical Association suggests 24 grams(in a 2000 calorie diet) as daily recommended amount. While consuming sugars is linked to diabetes, consuming sugars with fats and proteins (like those found in milk) help the body regulate its sugar levels better.
Jun 20, 2013 | Health & Beauty
How do I adjust brake pedal on my mower
  1. Press down on the clutch pedal and set the parking brake.
  2. 2Identify the brake adjustment feature, located below the brake operating arm. It includes a jam nut, regular nut and rod. Measure the distance between the brake operating arm and the regular nut. The regular nut is distinct from the jam nut -- the jam nut is the outer nut.
  3. 3Loosen the jam nut and turn the regular nut so that it's exactly 1-1/2 inches between the arm and regular nut. Double-check that the parking brake is engaged, then re-tighten the jam nut so it abuts the regular nut and holds it in place at the correct distance. Try the riding mower stopping procedure again in a safe place.
Apr 25, 2013 | Cars & Trucks
Passenger side control arm nut keeps comming loose
Install a new nut
Is it not a compressed lock type nut ?
Can only use it so many times
Dec 18, 2012 | Cars & Trucks
HI THERE....HOW DO I REMOVE THE REAR MOTOR MOUNT FROM THE ENGINE?? THANKYOU SWEETIE, I'M THE CHICK WHO IS DOING ALL THE RESEARCH FOR MY HONEY. THANX SO MUCH FOR YOUR HELP!!
Well, Hello Chickie. I'm the guy giving what I hope is good information to you for your honey. I've got some bad news on this one. To remove the rear engine mount, you have to split the engine cases. You don't know how many times I've seen guys put the engine cases together and leave the rear mount off thinking they could put it on after getting the cases together.
However. Once you take all the cams and the transmission out of the cases, there isn't that much to splitting the cases. One thing to remember however. Look the bolts along the very bottom of the cases. Notice which direction they are put into the case, ie. what side the nut is on. If they are installed backwards, you'll wrestle with the engine for a couple of hours trying to get it back in the frame and it will not go back in because of the bolts hitting the frame. Yes, it is that tight.
Good Luck
Steve
Sep 16, 2010 | 1979 Harley Davidson XLH 1000 Sportster
Torque spec for 2002 daewoo leganza for half shaft nut
THE LEGANZA MODELS TIGHTEN THE HALF SHAFT NUT TO 111 - 155 FT LBS .LOOSEN THE NUT RETIGHTEN TO 37 FT LBS.RETIGHTEN AN ADDITIONAL 60 DEGREES.STAKE THE NUT WITH A PUNCH AND HAMMER.THE NUT WILL NOT BE LOCKED IN PLACE UNTIL THE NUT HAS BEEN STAKED.
May 13, 2010 | 2002 Daewoo Leganza
Cooking Logo
535 people viewed this question
Top Cooking Experts
Tom Chichester
ray gallant
Are you a Cooking Expert? Answer questions, earn points and help others
