Question about Panasonic SC-HT680 System
2 disks stuck in one slot of DVD player
Hi there! My mischevious 2 year old stuck 2 disks in one slot, we fear, and now we can't get the whole thing to work. After we power off and back on again, we get a INIT error message and then get stuck on WAIT. Our guess is that it can't get beyond the dvd issue. Any thoughts? We're broke and want to fix it ourselves, if we can! THANKS!
    Problem Solver:
  • 4 Answers
Remove the top by removing the screws and then you can remove the stuck/jammed discs. For the Panasonic SC-PT750 there are 7 screws, three small silver ones on the back, then 4 black ones, two on each side, all philips head. Once you have that off, gently pry it off starting from the back, the cover is actually hinged into the front plastic piece of the player.
Posted on Dec 31, 2007
    Genius:
  • 2,985 Answers
Looks like it will have to come apart. Can you see how? Usually the top/side casing is simply 5/6 screws 2 each side and 1/2 at the back then slide back away from the from panel. Technical help at Panasonic may be helpful.
Posted on Jul 02, 2007
How to remove stuck dvd from lg blu ray
sounds like the disk may be sticky on top and is now stuck to the chucking clamp. Try to cut power as the door tries to open, then open the door as much as it will aloow and you should be able to fish the disk out. If it is stuck, you may have to push down the disk with a screwdriver to release it.
Jul 28, 2014 | LG Televison & Video
My dvd player is stuck on one dvd and wont let me eject, change disc, or even stop the current dvd. display reads "locked" whenever i press any buttons. can only turn on and off the device.
Hi, For some reason the disk will not play. You push the eject button over and over again, but the disk slot will not open. Here's one solution...
* 1 Turn off the DVD player. Wait a few minutes, turn the DVD player back on, and
then press the "eject" button. If this does not work, turn it off and unplug
the DVD player...while you keep pushing EJECT button plug the DVD and turn it on (your hand still on the eject..) is should come out..
* 2 ..if it does not eject , unplug the DVD player again, Remove the screws off DVD on the sides and take off the DVD casing.
* 3 Look for the DVD holder inside the DVD player. This device holds the DVD in
place while the DVD player reads the disk.
* 4 Push the stuck DVD disk toward the front of the DVD player until the DVD
ejects. Remember the DVD player is not on and some force ( gentle ! ) must be applied.
* 5 While it is open,plug it on and place a DVD disc just to see if mechanism works properly..
* 6 Replace the casing and the screws. Plug the player in and turn it on. Put
another DVD in to test whether the player is finally working ..
Hope this helps!..
Take care and please
Remember to rate/vote and give us 4 Thumbs Up
to continue f
or Helping out the Community :)
Jul 09, 2011 | Televison & Video
My 4 year old APD 3955 stopped working. You can
Check the lens, sometimes dirt gets in there. Try to run a DVD cleaning disk... they are sold at many places, they are cheap and you can still use them for cleaning your CD players and DVD players at home. This should fix the problem.... if not ... try to shake the DVD player gently to remove any foreign matter that could be stuck somewhere...good luck!
Jun 05, 2010 | Radio Shack Accurian APD-3955
DVD Player will spin disk, but will not read
Is your DVD player a multisystem player??????? If no,It is quite possible that the DVD's you are playing are not recorded on the format which your DVD can play. Please check It is also possible that the head of the DVD requires cleaning over use for 2 years OR the DVD being played has been lying inoperative for a long time thus gathering dust and moisture requires cleaning now
Dec 20, 2009 | Cars & Trucks
Pilot valve will not turn
Hi do not remove the screws it will be safer to change the gas valve
Jun 05, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Disk tray wont stay closed.
I am having the same problem with panasonic Karaoke player, it wont play anything cause the drawer wont stay closed!!! HELP!!!
May 05, 2009 | Televison & Video
DVD disk stuck
There's a slot underneath the machine with instructions to manually get the dvd out
Jan 04, 2009 | Cyberhome CH-DVD 300 DVD Player
DVD player door won't open
took out the dvd player and inverted it and pushed the advance disk button . There was a disk stuck between the disk slots. The door opened and I removed the disk.
Sep 20, 2008 | GPX D2816 DVD Player
Go Video VR 1940 DVD Recorder + VCR - DVD disk will not eject from slot on top of flat screen TV
My sugestion is to open the dvd player cover, then after you remove it the disc cover you screw out it to remove your disc.
Apr 24, 2008 | GoVideo Go Video DVD/VCR Combo
Panasonic SC-HT680 System Logo
189 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
