Errore 22.1:10 in hp dnj t2300 - Office Equipment & Supplies
2 Suggested Answers
  • 304 Answers
SOURCE: hp dnj t610 79:04 error
System Error: 79:YZ (YZ=04 Upgrade System Firmware)
Problem Description: Generic Firmware error.
Corrective Action: Try the following:
  • Switch the Power OFF from the back of the Printer and disconnect the Power cord. Reconnect the power cord and power On the Printer.
  • Check that the Printer has the latest Firmware version. If not, update the Firmware to the latest version.
Posted on Jul 09, 2011
Plese help me t2300 error 21:13
System Error: 21:YZ
Problem Description: Failure moving Service Station
Corrective action: Try the following:
1. Switch the power off from the back of the product and disconnect the power cord. Check
the Primer Tubes. Reconnect the power cord and power on the product.
2. Make sure that the Service Station path is clear. Remove any visible obstacles (screws,
plastic parts, etc.) restricting the movement of the Service Station.
3. If the carriage has stopped over the service station, on the right side of the product, check
that the cutter is not activated. The cutter may be blocking the carriage over the service
station, preventing the service station from performing the movement correctly. The cutter
is on the left side of the carriage.
4. Perform the Service Station diagnostic test to troubleshoot the problem further. See
Service Station Test on page 102.
5. Replace the Service Station. See Service Station on pag
Mar 01, 2014 | HP Designjet T2300 Inkjet Large Format...
Hp t2300 error 21.2:13 solution
This would normally indicate "Service station error". I found the following solution elsewhere on Fixya for the HP Plotter T1100, but looks like it is for the technically minded.
"Remove right cover, remove & take out service station, check any objects in service station movement, remove motor clean entire unit with water you can find out lot of ink inside & too dirty clean it allow to dry apply grease for smooth movement( pl take care of pumping unit & tubes), fix it back, perform service station test ( to enter in service mode switch of the machine with power off button from front panel hold UP arrow button & OK key button then which on the from front panel button, wait till enter in service mode scroll to service station enter, three options service station,primary motor and aerosol motor select service station, enter wait till result papers on panel)."
Hope this helps.
Sep 08, 2012 | HP Designjet T2300 Inkjet Large Format...
Hp dnj t610 plotter 79:04 eror
79.04 is a generic software error.
Can be caused by bad firmware.
Can be caused by bad job.
Try sending a different job to the printer.
If that works and the original job fails again, something is wrong with it.
If the new job fails, power off and on again. Resend the job. If it fails again...go to
www.hp.com. Select support and drivers. Upload the latest firmware.
This one isn't easy. Good Luck
Jul 09, 2011 | HP Designjet T610 InkJet Printer
Hp dnj t610 79:04 error
Jul 09, 2011 | Office Equipment & Supplies
How do i get my MPC laptop TransPort T2300 Finger Print scanner to work? I tryed runnin my finger across it nothin happend .
Did you enroll your finger print first?
If not, log onto your account, and start the protector suite
go to the passport section, and set up a passport for your account.
Sorry if this isn't very clear, but I don't have the suite anymore, I'm running windows 7 on my t2300
Oct 12, 2010 | MPC Computers TransPort T2300 Notebook
HP Designjet 800 with a 'system error 81:01'
i have hp dnj Plotter 500 Printer Is Redy But Self Test & Computer Print Than Error 81:01 Papar Jam
Feb 23, 2009 | HP Office Equipment & Supplies
Hp 530 notebook cpu upgrade
It's not posible to upgrade to a dual core, the motherboard is a different design. Keep in mind that the processor, motherboard and memory have a matched frequency. If the processor doesn't match the board then it won't recognize it. Since the board does recognize the T2300, it may be that you need to match the memory in order to get it to boot. Match the memory by going to patriotmem.com and entering the model that the T2300 came from, it will tell you the memory frequency. If the memory matches the processor simply will not work with that board.
Jun 25, 2008 | HP 530 Notebook PC
96 people viewed this question
jasbo
jasbo
