Question about Volkswagen Golf V Vw Blue Diecast Model
Central Locking on 2005 Golf 1.6 FSi
When I press the key fob once the driver door opens, when I press the fob twice the passenger and back doors should open. However, only the passenger door opens. If I mess around with the key for 15/20 minutes pressing the fob in different combinations one of the back doors will eventually open. Also the door open button on the drivers door will not open the back doors either. Can anyone help open the back doors consistently? reprogram the fob? or tell me how to over ride the fob so I can just open the back door from the inside/manually? Thanks for your help.
  • Rossa Reilly Jan 14, 2013
    Does anyone know how to override the fob key in order to open all the doors?
5 Suggested Answers
5LTRBTR
  • 180 Answers
SOURCE: VW Golf 2002 central locking
this sounds like a stuck switch in the door lock assembly. it will make the locking system work like its got a mind of its own. The best fix is to first try cleaning the latch on the door it has a switch to tell the car if the latch is open/closed. Use an old tooth brush with some degreaser scrub the base of the latch on the door. After its cleaned up relube it with some white grease or dry graphite. Then try the lock again. If this doesn't solve it then the lock assembly has a faulty switch inside and replacement is the best option
Posted on Dec 18, 2008
  • 121 Answers
SOURCE: vw bora central locking
I would check the electrical wiring connector that connects to the B Pillar (the structure between the front and back doors looking for a pinched wire. If you move the rummer boot around a bit I think you can get a pretty good look at the wires and you will be looking for one that might be dangling loose. If this sort of thing isn't really up your alley a trip to the dealer may be in order.
Posted on Feb 26, 2009
BRADLEYFRANC
  • 104 Answers
SOURCE: my mk4 golf has a problem with the central
try disconnecting your vehicles battery for about 5 min[remember to have your radio code].reconnect battery and try the central locking again.
Posted on Oct 09, 2009
BRADLEYFRANC
  • 104 Answers
SOURCE: VW bora 2002 Central locking The remote only
Try disconnecting the cars battery for a few minutes.Remember to have your radio code handy as it will go into safe mode.This should reset your convienience control unit[central locking] and it should operate as normal..good luck
Posted on Dec 28, 2009
Vw golf mk4 my rear passenger door willnot open with central locking key system. i can't even open it from the inside, pull the door handle and the lock pin rises but door won't open. i believ
This worked for me on 2008 Mk5 Golf, after the rear passenger door would not open fro outside or inside.
Hold the inside door latch open and keep it extended, then with the key fob open and close the door locks (still holding the inside latch open). Keep locking and unlocking the door, then it made a kluck and it released.
Mar 23, 2013 | Volkswagen Golf Cars & Trucks
I can use the key fob to lock my all doors plus the boot, however when trying to unlock the car only the drivers door unlocks and I have to use the button in the car to unlock the rest of the doors and the...
Not sure if this is right and don't want to come accross a belittling but have you tried pressing the key fob twice? I'm sure I read somewhere that pressing it once will do the driver's side and that a second push of the same button will unlock the other doors. Unfortunately, I don't have remote central locking on my Golf but hope this helps!
Oct 22, 2010 | 2002 Volkswagen Golf
My passenger door central locking has stopped
Method 1: Press lock or unlock button 4 times in succession. Method 2: Switch ignition ON and OFF. Within 10 seconds press lock and unlock button in succession.
This is the only manual reset
If this does not work go to your local auto electrician
The probable fault could be central locking activator passenger door
Jul 15, 2010 | 2002 Mini Cooper
Central locking
turn key twice when opening, ie turn right. once drivers door will unlock, turn twice passengers doors will unlock, and locking is turn anti clock wise once will lock all doors, turn twice will set door dead locks.dead locks will stop openand lock internal button working and handle from opening door. the same actions can be applied to the remote one press drivers door, two press passenger doors, press and hold unlock button for 5 seconds and rear window will open.
Apr 23, 2010 | 2003 Land Rover Freelander
Key fob only opens drivers door
hit the unlock button twice. most fobs are programmed so you hit it once, drivers unlocks, and again for all the rest.
Jan 25, 2010 | 2004 Volkswagen Passat
My mk4 golf has a problem with the central locking..it locks fine,but when you unlock it opens driver door with one press of the remote fob,,but does not open rest of doors (after pressing remote twice)...
Sep 22, 2009 | 2002 Volkswagen Golf
Central locking issue on my Land Rover Discovery II 2003
Does it open from the outside once you have manually opened it from the inside.
Jul 08, 2009 | 2003 Land Rover Discovery
Mgf central locking won't open the car doors
I had same problem. It was cured by "flicking" shut the interior opening handle of the drivers door. This allowed the central locking to lock then unlock the drivers door properly. You get into the car in the first place by using the romote to "unlock" and whipping the passenger door open quickly before it has a chance to relock!
Feb 21, 2009 | Vehicle Parts & Accessories
I need to use my key to unlock the central locking of my car. It worked fine until last night when the drivers side lock will not open the car. I have to unlock the car using the passenger side door.Im...
i also have a MK5 golf tdi with cental locking problem the drivers door wont open from the fob but all the other doors will, i taken the car to a garage last week when it was pluged in to the computer it showed errors they cleared them it sem't to solve the problem now its started again ?
Jul 31, 2008 | 2005 Volkswagen Golf
Volkswagen Golf V Vw Blue Diecast Model Logo
43 people viewed this question
Top Volkswagen Toys Experts
Gary Nitowski
Kulu Criss
Kulu Criss
Bogdan Odwazny
Bogdan Odwazny
Are you a Volkswagen Toy Expert? Answer questions, earn points and help others
