I have a Indesit IDL700.2 and everyday we have to refill the rinse aid, this shouldn't be happening, also the cups are coming out with stains still even after re filling. The dishwasher is only just under 4 years old. Does it need someone to come out and look at it?
Comments:
Jan 22, 2009
- It's set at 4 however, is that because of the hard water?
First check in the dispenser is a knob that has an arrow on it see where this points it should only have to be set on one or two normally any higher and you will use more rinse aid if it is on one or two then get a tech to check it it may need to be replaced
Comments:
Jan 22, 2009
- With the rinse aid set at 4 it will use more rinse aid than is needed set it a 2 and give it a bash as for the hard water rinse aid is there to assist in the rinse and drying of the dishes,the hard water if you have in fact got hard water problems is usually sorted out by adding sea salt/salt blocks to the salt dispensor usually sorts out hard water problems.Hope this is of assistance to you.
number light flashing and wont reset to wash again, usually you press P and it moves onto new...
(More)
number light flashing and wont reset to wash again, usually you press P and it moves onto new setting, but that is not ahppening its an indecit DI 620
ola muito boa tarde sera que poderiam me azudar. por a caso nao me pueden forneser o esquema do...
(More)
ola muito boa tarde sera que poderiam me azudar. por a caso nao me pueden forneser o esquema do programadar como se liga? e uma indesit dv CE 61 4668 o meu indereço é pedrosilva6318@hotmail.com
My timer switch seems to be out of sync, and stops mid programme, how can i reset my indesit...
(More)
My timer switch seems to be out of sync, and stops mid programme, how can i reset my indesit dishwasher program?
