Question about Whirlpool GS460 Gas Kitchen Range
I have a whirlpool gas range. When I try to use the oven it counts down and the pilot looks like it starts to heat up. Sometimes it will work and heat and other times it does not. The unit is about 6 years old.
  • Whirlpool Master
  • 8,220 Answers
If the ignitor looks pale orange and dim then it needs replacing. Read more
Posted on Feb 09, 2009
I have a Garland Sunfire 36 inch gas Range. oven does not come on again after reaching temp.
You probably have a bad thermocouple. Try cleaning it off with sand paper. It's the part that the pilot light is igniting.
Mar 15, 2012 | Garland SunFire SX-10-26 (Gas) Stainless...
My oven is ten yrs old lately when i push bake then start the timer starts counting backwards and the pilot light comes on but the oven does not get hot. sometimes i can slam the door and it will start...
Sounds to me like your oven is a gas oven that uses silicone carbide ignition. When that ignitor gets aged it gets weak and will not open the safety valve. How it works video:
When you bang on the oven the bimetal will open on a weak ignitor. If yours is dim orange that is another sign of a weak ignitor.
Jun 29, 2011 | Whirlpool Ovens
Oven does not work: pilot light out? How feasible (how dangerous) to try to relight pilot light? T Phillips Winston-Salem, NC
Actually, your oven probably doesn't have a pilot light at all. In order to ignite the oven, it has an oven igniter. If you open the broiler, look up on the "ceiling" of the broiler to the back of the burner. There, you'll see a white block. That is the igniter. What it's supposed to do is heat up (electrically) and when it heats up enough, the gas valve turns on and the oven lights. What happens with these, is that the heating element on it opens from years of use and must be replaced. Inside the broiler door (usually) is the stove's model and serial numbers. Write them down and visit your local appliance parts store with those numbers and they'll give you a new one. (Usually around $30-$45 or so.) Also, you can usually change the igniter from inside the oven by removing the bottom drip plate, so that'll save your back a lot of straining. :)
I hope this helps and hope you have a wonderful holiday season!
Dec 22, 2010 | Whirlpool GS460 Gas Kitchen Range
Oven won't heat up
oven won't work got power to safely valve and gas come from regulator
Oct 11, 2009 | Whirlpool GS460 Gas Kitchen Range
Older whirlpool gas oven pilot lights but oven will not ignite
your oven most likely has a safety shutoff valve
with a thermostat that has to be heated by the
pilot flame,(this ensures that the pilot is lit) before gas is sent to the oven burners. this unit mounted in the bottom of the range and is
connected to the gas line.
Aug 21, 2009 | Kitchen Ranges
Oven works sporadically
IF YOU CAN SMELL GAS, TURN THE STOVE TAP OFF. Get it checked out immediatly.
Aug 03, 2009 | Whirlpool GS460 Gas Kitchen Range
Oven gas turns off
If your Wolf has pilot light, most cases dirty pilot light (flame looks yellow, normal flame looks blue), you have to disassemble the pilot light to clean it, thermocouple connection is loose, bad thermocouple or bad oven safety valve. you can try change the thermocouple first, if it did not solve the problem, then it will be bad oven safety valve. You can buy thermocouple thru Hardware store. Have fun.
Dec 17, 2008 | Wolf Range CHR-10-229-FT11 Kitchen Range
Oven won't light
there is the oven ignitor nest to the oven burner it's an electric pilot, it's about 4 inches long by 1 inch thick, it needs to be replace.
Dec 08, 2008 | Whirlpool GS460 Gas Kitchen Range
Oven does not work at all
something is wrong did it work in the past or is it a new unit see the link below for good tips to help resolve the issue
by the way i am from Buffalo, NY also Top 5 Reasons Gas Oven Wont Heat Gas Range Troubleshooting
Jan 02, 2018 | Whirlpool SF378LEP Gas Kitchen Range
Roper gas oven won't work
replace the thermal coupling on the pilot make sure it is in the flame of the pilot it looks like a copper wire or tube if its bad it wont open the gas valve after the pilot heats it up
Mar 02, 2008 | Ovens
Whirlpool GS460 Gas Kitchen Range Logo
76 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
