Question about Carrier XHB123D X/Y Series Heat/Cool Air Conditioner
Fan works on "on", shuts itselfoff on "auto",no heat either way,
No heat coming from the furnace, no burnt element smell (if there are elements)in the home . filter has been changed. the fan blows on "on" but shuts itself off when on "auto" after a few moments.can this be an easy fix if i do it myself,changing elements or unit ? is there a site that has how to instructions for free ?
    Problem Solver:
  • 12 Answers
Sounds like the themostat isnt properly set up check the back and make sure the gas/electric switch is properly set
Posted on Jan 21, 2009
E1eh-017ha ele.furnace fan shuts down then the heating elements get4 times hotter turn off.discount breakers in furnace still hot sets off fire detector. You have got to kill main breakers
Dont really understand .Is it a furnace with electric heat ,if it is then Check to see if contactor or relay is stuck closed ,also you heating element should not get so hot there should be a limit switch to shut heater off .Maybe bad limit and bad relay .Your electric heat should shut off when fan shuts off
Feb 15, 2018 | Heating & Cooling
Intertherm furnace burner comes on, but blower does not. If I turn thermostat off then back on until it clicks the fan will then come on. It does not do this all of the time, just now and then.
Furnace burner and heat element are not the same. I think the fan time delay, a sensor that turns the fan on when this sensor senses heat, is shot and needs replacing, for a furnace type heat ( gas heat)
Aug 08, 2017 | Intertherm E3EB010H Electric Furnac
Have a model 3500A820 furnace that heats but blower doesn't come on. Shouldn't elements go off in this case. Really over heated, scary!
Turn the blower to manual on at thermostat if you can.
Most electric furnaces have a overtemp switch to shut off the elements. If it is auto reset then it could be shutting off and you would not know it.
If its a manual reset it should shut everything down,
its possible that it is not sensing the plenum temp.
If you can trace your blower wires and it is multispeed,if you can see which wire is tied in with
the heat circuit, change it with another wire, it is
possible that you may have a burnt out speed on blower motor
Jan 18, 2010 | Heating & Cooling
Oven not working
fan oven element video. 1, If the fan motor . in the back of the oven is going round and the temperature light is on (normally little red light), but there is no heat then you will probably need a new oven element, these are generally very easy to fit and readily available from our website these can be tested with a electric meter.
To gain access to the element .you will have to remove the back plate from inside the oven. Once removed you will see the fan and element,. if you look closely at the element .you will probably see a small hole burnt in it where it has blown. Sometimes however there is no evidence of a fault but the element is open circuit ie: broken inside the element casing, either way it will need replacing. Some elements will are fixed from inside the oven and some are held in place by nuts from the rear of the machine.
2, If your fan oven is getting warm but takes a very long time to cook or is burning the food more on one side than the other, then you need to check if your oven fan motor is working you will see the blade turning fast if it is ok. if the element is heating but the fan motor is not blowing the heat into the oven then you need To replace the oven fan motor is a little more expensive and a bit more involved.
3. If you have the opposite problem ie: your oven is over heating and burning everything then you will need to replace your oven thermostat
4, A quite common and easily overlooked answer is if your oven is not working at all ie: no heat and no fan then the chances are that someone has put the oven timer into AUTO mode, simply put oven back to MANUAL mode and all should be working again.
For all Free appliance repair videos visit our VIDEO TUTORIALS
Jan 12, 2010 | GE Ovens
Rheem RHQA Heater:Blower works but no heat.
Is there a setting on the thermostat for Auto or Fan? If so, make sure it is in the Auto setting. You will have a contactor that turns on the elements and a relay for the fan. Follow the wiring diagram to see which relay energizes the fan then unplug it to see if the fan stops.
Nov 02, 2009 | Heating & Cooling
Draft fan keeps on running after furnace shuts
That sounds pretty normal for most furnace/heater products. They run the heating element with fan for a cycle then after the heater reaches temperature it will shut off and the fan will continue to run to cool the element and to circulate the heat that it produced. If you want the manual for this product it looks like you can get it here: http://homeappliance.manualsonline.com/ex/product/headline/m/Coleman%2BEvcon/d/furnace/p/DGATO75BDC
Oct 26, 2009 | Coleman 10' X 10' Sundome Tent 9160K101
Heating element not working
condinuity test between each end it has to make a complete circuit
May 08, 2009 | Heating & Cooling
Ruud Electric Furnace Cannot Reach Setpoint - "Watt Restrictor"?
unfamiliar with watt restrictors.
heat strips have 2 safety devices, a thermal overload, they get to hot they shut off, cause not enough air flow increase fan speed this device is auto reset. a fusible link a fail safe to thermal over load, no reset and sometimes replaceable. if this does not help would like to ask you a few questions. one of the buildings i take care of has 200 + reem/ ruuds all electric heat. if a part is defective replace, please do not by pass. safety frist.
Mar 02, 2009 | Ruud UBHC Air Conditioner
Carrier XHB123D X/Y Series Heat/Cool Air Conditioner Logo
65 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
