Question about Fujitsu ASU12RLS Halcyon Ductless Mini Air Conditioner
Removal of front panel of fujitsu asu12rls - Fujitsu ASU12RLS Halcyon Ductless Mini Air Conditioner
Compressor thermister error
You will need to replace the compressor thermistor which is just a temperature dependent resistor - a wire going to a metal tube about 1 inch long. They usually come as an assembly of several of them that terminate at a single connector and plug into the controller board. Should be cheap to obtain and fairly easy to install. just make sure power is isolated for 10 mins before exposing any circuit boards.
Dec 09, 2015 | Fujitsu ASU12RLS Halcyon Ductless Mini Air...
Green color fluid leaking down wall from ASU12RLS
The gas is leaking stop use strait away highly toxic get profestional help!
Oct 23, 2011 | Fujitsu Heating & Cooling
Ihave a fujitsu air conditioner model asta18lcc about 2 yrs old when I turn it on fan works but room wont get cold or hot,red operation light does not stay on but green timer light flashes on. thanks...
The lights on the front panel indicate fault codes dependent on the amount & intervals of the flashes. Fujitsu units carry a 5 year warranty so check with your local Fujitsu store for the agent in your area.
Aug 13, 2010 | Fujitsu 24C1 Air Conditioner
How do I remove front cover of Fujitsu indoor unit
THE INTAKE GRILLE REMOVAL
(1) Open the intake grille.
(2) Pull down the knob.
(3) Lift the intake grille upward, until the axle at the top of the intake
grille is removed.
THE FRONT PANEL REMOVAL
(1) Remove intake grille (Reference the intake grille removal.)
(2) Remove four screws.
(3) The thumb is hung on the lower part as shown in the figure,
and it pulls to the front, pushing [-] mark , and bottom hooks
(two position) is removed from wall hook bracket.
(4) The front panel bottom is pulled to the front, and bottom hooks
is removed indoor unit.
(5) The front panel is pulled to the front, raising the upper surface,
and a front panel is removed.
Feb 23, 2010 | Fujitsu 18R1 Air Conditioner
How to open the back panel of fujitsu AMILO D 7820
u can use the software herionee to change the password ...if not use the guide which is given to u with the lptp t
Feb 05, 2010 | Fujitsu AMILO D-7820 Notebook
Air conditioner dripping water
Try pouring some bleach in drain.
Jun 28, 2009 | Fujitsu 12C1 Air Conditioner
Drain line obstructed Fujitsu split unit aircon model ASA12ASHTW
The best way to clear the drain line is by using a shop vac and sucking out the blockage and the water. This will make sure all the goop in there comes out. Let me know if you need anything else.
seth
Jun 28, 2009 | Fujitsu Heating & Cooling
How to remove cover on fujitsu split system head
The front cover can be dismantled (taken off as one Piece) by unscrewing the screws at the bottom of the air outlet (they are covered by screw cvers which will need to be taken off. Then just pull off the cover. PLEASE NOTE that the front panel (liftable to take out filters) will need to be removed lift up until 90 degrees and then pull off gentley and also take out filters before removing front cover
I take the time to answer you questions so please rate me
Thankyou
Mat
Feb 21, 2009 | Fujitsu 18R1 Air Conditioner
Replace the batteries on the remote,
Simply continue sliding front panel down until it stops. At this point, move same panel left to right and apply further pull down pressure. Panel will now be removed from controller and reveal batteries.
Hope this helps, Ash.
Oct 21, 2008 | Fujitsu 24C1 Air Conditioner
Fujitsu ASU12RLS Halcyon Ductless Mini Air Conditioner Logo
105 people viewed this question
Top Fujitsu Heating & Cooling Experts
Fotis Papastamatiou
AJMAL KHAN
Donni Steen
Are you a Fujitsu Heating and Cooling Expert? Answer questions, earn points and help others
