Question about Samsung RS267TDRS - 26 cu. ft. Side by Side Refrigerator - Stainless S
Samsung RS267TDRS refrigerator side not cooling
Refrigerator side not cooling
I have a samsung rs20nrsv side by side but the freezer side is not freezing or cooling what is the problem?
could be a thermostat fault or a start/run capacitor for the compressor unit
have a technician check it out
Aug 12, 2015 | Samsung RS20NRHS 510L SIDE BY SIDE...
Turn on my fridge
somewhere inside the refriderator there will be a dial the turns it on sets cooling level or to shut it off not all are located in the same place so look around of course it has to be plugged into a good outlet .
Jan 05, 2015 | Samsung RS267TDRS - 26 cu. ft. Side by...
SAMSUNG REFRIGERATOR MODEL RS267 ERROR CODE 5E
Error code 5 E : Ice Maker Function Error - Ice-ejector and level failed three times or more. May simply be a trapped piece of ice which is not too rare a problem especially if the freezer door is left open too long.The ice pieces will stick to each other. It may dislodge itself or if the problem persists you may have to de-freeze it ( letting the freezer defrost over night.)
Jun 27, 2014 | Samsung RS267TDRS - 26 cu. ft. Side by...
Not cooling and led blinking from top to bottom
Your refrigerator is in "Cooling Off" mode, or sometimes called "Store Display Mode", which basically allows everything in the fridge to function except for the Cooling system. Press and hold down the "Lighting" and "Freezer" buttons for 5 seconds until you hear the "Ding Ding". Your 'fridge will be working again.
Feb 26, 2014 | Samsung RS261MDPN Side By Side...
Trobleshooting refrigerator RS263TDPN
your cooling system must be damaged or connecting wires are ligued.
Mar 22, 2013 | Samsung RS263TDPN 26 cu. ft. side by side...
Samsung RS261MDPN not cooling properly
sounds like a defrost issue defrost clock heater or limit could be bad
Jan 18, 2013 | Samsung RS261MDPN - 26 cu. ft. Side by...
Samsung model rs263tdpn fresh food stops cooling.
Air channels freezing? they might be blocked with foreign matter, clean them out. This might also be as simple as turning down the dial for how much you wish to cool the unit. Running it constantly at full blast is not a good idea.
Oct 08, 2012 | Samsung RS263TDPN 26 cu. ft. side by side...
Samsung RS267TDRS - 26 cu. ft. Side by Side Refrigerator - Stainless S Logo
70 people viewed this question
Top Samsung Freezers Experts
Dan Webster
Dan Webster
Jay Finke
Jay Finke
ray gallant
Are you a Samsung Freezer Expert? Answer questions, earn points and help others
