Printer does not respond, and we restarted it and it still does the same thing When I click the print command on my computer, the printer does not respond.
  • 63 Answers
Try reinstalling driver, change the data cable between the printer and the computer...
Hold down the paper feed button while turning it on (or the change ink button) and it should print a self test...
for info on self test instructions let me know the printer make and model...
Matt
Posted on Jan 21, 2009
I have a networked printer in my office. it has been working normally until recently where it takes no print command from any of the networked computers. If i disconnect the network cable, the test print...
Try this solution
Go to START MENU
Choose Commamd prompt, right click mouse and run as administrator ( For Window vista and windows 7)
Type the letter "cmd"
Type the word "net stop spooler"
Exit
Go to C: drive
Choose to Windows Folder
Click show content
Choose system32 folder
Choose spool folder
Choose printer
And delete all printing jobs pending
Again go back to CMD window and type the word "net start spooler"
Restart your computer and must also turn off your printer and then switch it on.
It will work fine right now
I hope it helps you
Please let me know it you need more help. Regards
Mar 07, 2011 | HP Computers & Internet
Tip
HOW TO CHECK AND FIX PRINT SPOOLER SERVICE THAT CAUSES UNABLE TO PRINT FILE...
Print spooler service is a computer service that loads the print jobs into the printer memory for later printing and it acts as intermediary between a computer and a printer. When the print spooler service is stopped or malfunction, printing is not possible.
Here are the possible reasons :
1. Virus or Malware infection.
2. Spooler service was stop by accident or turn off to manual/disable mode.
3.Faulty installed printer driver that contains error or incompatible with previous printer drivers installed in your computer or system.
4. Print jobs and drawing jobs were corrupted by accident which caused print que lock and resulting print spooler service to crash.
5. Your printer had printing problem issue with pdf files.
To fix this problem, you have to check if the print spooler service had stop.
Here's how to check and fix the print spooler service.
Go to START
Choose RUN
Type SERVICES.MSC
Click on PRINT SPOOLER and check if the STATUS IS STARTED
If not, on the upper left side, click on STOP to stop the spooler service
Then click on RESTART to restart the spooler
Restart your printer and your computer
Then try to print again and it will surely solve your printing problem.
Another procedure :
Go to START
Right click on DOS command prompt and run as administrator
You should be in this command directory before you
Type CMD and be sure you are in this directory C:Windows\System32
And if not, type this to change the directory, CHDIR C:Windows\System32
Type NET STOP SPOOLER and message will appear like this
Exit and go to C: DRIVE
Choose WINDOWS and click show content if not view all the folder files
Choose SYSTEM32
Choose SPOOL
Choose printer and delete printing jobs if any
Again right click on Command prompts and run as administrator
Type NET START SPOOLER
Exit and restart your printer and your computer
I will works fine right now.
NOTE : You can bypass the C:Drive procedure and just type NET STOP SPOOLER AND NET START SPOOLER in the DOS COMMAND PROMPT if you believe that there are no printing jobs pending.
Another procedure is to download this troubleshooting software and follows the troubleshooter wizard and it will fix your print spooler service automatically and some common problems as well.
Click here to start downloading.
I hope it helps you solving your print spooler problem. Regards to all readers.
on Mar 24, 2011 | Office Equipment & Supplies
I cleared a paper jam from an HP Deskjet 6122, but now it won't respond to commands from the computer. I've restarted the printer and the computer. Now the print manager just says it's...
First things frist. If the printer is conected with a USB Cable to your computer, try removing and reinserting the usb cable. To make sure that it is properly connected.
You might just have unintentionally got the printer in offline mode. Now follow this steps:
To check if it is offline. 1. Go to devices and printers (7), Printers and Faxes(XP), Printers (Vista) 2. Double click on the printer icon 3. Click the option that says Printer on the upper left corner of the window that pops up.
Th only options that you need checked is the one that says Set as Default Printer. For any other options that has a check mark. Click on them to remove the check mark.
4. Click Start again, on the search box type in services.msc, hit Enter. For XP, CLick Run, and type the same thing and then hit ok. 5. A window should pop up with the list of services for your computer. Look for Print Spooler in that list. 6. Right Click on the Print Spooler and Click Stop. 7. Right Click on the Print Spooler and Click Start.
Restart your computer. Try printing again.
Feb 03, 2011 | HP DeskJet 6122 InkJet Printer
My Canon Pixma IP 2200 Inkjet Photo Printer won't respond to any printing commands. It is installed in my programmes. I have tried troubleshooting re setting but it still won't work.
Bottom right of your computer screen where your speaker icon would be? Is there a printer icon?
Printers will buffer (collect) till they can be printed. even if you shut down your computer and restart, these buffered print ques may not leave - printer traffic stops on this first print in the Que.
Right mouse click this printer icon and open all active printers. if there is more then one in this buffer, then select all of these and cancel them..
If this doesn't help and your USB and power cables are connected then unplug your USB cable and wait about 10 seconds and then reinsert your usb cable - see if your computer responds by indicating your printer has been identified. And try printing then.
Best photo printing and general use printing. Canon
Thank you for your Visit to fixya.com
Nov 15, 2010 | Canon PIXMA iP2200 InkJet Photo Printer
Cannot get my printer to respond..when I trouble shoot it says printing paused, I click on resume printing and it still doesn't print... I unplug my printer and turn off my computer and once I restart my...
1. Click on START, CONTROL PANEL, PRINTERS AND FAXES (or PRINTERS AND OTHER HARDWARE).
2. Right click your printer, and select PROPERTIES. (If your printer is not listed, click on VIEW INSTALLED PRINTERS first).
3. Select the ADVANCED tab.
4. Select PRINT DIRECTLY TO THE PRINTER.
5. Click on APPLY (if applicable), then OK.
6. Restart your computer.
7. Try printing now.
Aug 22, 2008 | Lexmark Office Equipment & Supplies
Cannot delete print jobs in queue
Instead of restarting, try this:
1. Start
2. Run
3. Type this in the box: services.msc
4. Hit ENTER
5. Scroll down to PRINT SPOOLER
6. Right-click on it and choose RESTART
This will clear out your print queue without having to restart. Good luck!!
Whats the brand and make of the printer and are there any error lights being displayed ?
also try this solution it may solve your problem:
Click start > click run
in the Run window type cmd
hit enter
now a black DOS window will appear
now type
net stop spooler
wait 10 seconds
now type
net start spooler
it should look like this :
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\NCR>net spool stop
The syntax of this command is:
NET [ ACCOUNTS | COMPUTER | CONFIG | CONTINUE | FILE | GROUP | HELP |
HELPMSG | LOCALGROUP | NAME | PAUSE | PRINT | SEND | SESSION |
SHARE | START | STATISTICS | STOP | TIME | USE | USER | VIEW ]
C:\Documents and Settings\NCR>print spool stop
Can't find file spool
Can't find file stop
C:\Documents and Settings\NCR>net print spool stop
NET PRINT
\\computername\sharename
[\\computername] job# [/HOLD | /RELEASE | /DELETE]
C:\Documents and Settings\NCR>net stop spooler
The Print Spooler service was stopped successfully.
C:\Documents and Settings\NCR>net start spooler
The Print Spooler service is starting.
The Print Spooler service was started successfully.
Anymore information would be great
Thanks
Aug 18, 2008 | Office Equipment & Supplies
All in One Printer/Scanner/Copier will not respond to print command.
Pls make sure that your computer recognizes your Printer, if it doesn't it would never respond to any print command you sent
check to see (if the computer recognizes)
1- go to start then select printer
2- select your desired printer - right click
3- go to properties
4- select print PRINT TEST PAGE
5- check the message on your paper
if it doesnt then you might have installed a wrong driver
Jul 14, 2008 | Office Equipment & Supplies
Spooler serivice is stopped
Overview
This article describes two methods for restarting the Print Spooler service within Vista.
Method 1: Restart the service using the services console
  1. Click Start, type services.msc in the Start Search box, and then click services.msc in the Programs list. If you are prompted for an administrator password or for confirmation, you can either type your password or click Continue.
  2. Right-click Print Spooler, and then click Stop.
  3. Right-click Print Spooler again, and click Start.
Method 2: Restart the service at a command prompt
  1. Click Start, All Programs, and then click Accessories.
  2. Right-click Command Prompt, and then click Run as Administrator. If you are prompted for an administrator password or for confirmation, type your password, or click Continue.
  3. Type the following commands at the command prompt.
    net stop spooler [Press ENTER.]
    net start spooler [Press ENTER.]
    exit [Press ENTER.]
Apr 12, 2008 | Lexmark X4270 All-In-One InkJet Printer
Printer will not respond to Windows Vista
This printer model _does not_ have wndows vista support at this time. Check the manufacturers website for updates
http://www.lexmark.com/lexmark/sequentialem/home/0,6959,204816596_920309141_0_en,00.html
Feb 14, 2008 | Computers & Internet
95 people viewed this question
jasbo
jasbo
