Question about Philips HTS-6500/37 System
DVD will NOT eject!
We have a DVD stuck in our DVD player. Does anyone know how to mechanically extract this DVD. Help would be appreciated Thanks
  • 1 more comment
  • john payne Jul 02, 2007
    Thanks for the response. I can open the unit, but I am worried that doing so may void the warranty. The unit is still under warranty, but I have to package the unit up and ship it from Maui to Arkansas at my own expense. And it will take weeks to get a replacement. Rather than incurring the expense and long delay, I wanted to see if I could get it fixed here.
    Does opening a unit typically void a manufacture's warranty?
    Hi again Jackboy,
    We got the DVD player apart BUT the unit that contains the stuck DVD is completely seales.
    Guess we are hosed.
    Any suggestions?
    WOuld appreciate it.
    Thanks
    Lo and behold :o)
    after opening the player we plugged it in again.
    And the DVD started playing and therefore we were able to eject it.
    Thanks for you help.
    Genius:
  • 2,985 Answers
Looks like it will have to come apart. Can you see how? Usually the top/side casing is simply 5/6 screws 2 each side and 1/2 at the back then slide back away from the from panel. Technical help at Philips may be helpful.
Posted on Jul 02, 2007
  • john ash
    john ash Jul 02, 2007
    Not if your are careful I would imagine
    chech out if there are seals or other sorts of evidence that would indicate that it has been opened,
    Going by what you say about shipping etc, I would have a go.
  • john ash
    Wekk that has done it- how completely close fused plastic or clipped together shell
    Remember theses things are snapped together for cents a piece - they cannot make them too difficult.
    Don't rush at it -take your time
Disney cars TV doesn't eject. The DVD seems to be stuck. Does anyone know how to fix that?
CD loading mechanism fault. Contact any service technician. Sometimes, a broken loading belt might be the reason.
Gopakumar Gopalan Google
Mar 25, 2014 | Disney Televison & Video
How to remove a dvd stuck in the dvd player in a gmc 2004 envoy
Most DVD players have a tiny hole on the front to mechanically push the internals to eject stuck DVDs. If the player does light up, sometime a thump with your fist is enough to jolt the mechanism. Failing that, you have to remove the player to get the DVD out.
Mar 01, 2014 | Cars & Trucks
Will not eject disk.
Almost always, your described problem could be caused by:
  • stuck disc;
  • fault in the load/eject mechanism.
It it were a stuck disc, the correct fix would be to open the unit and manually extract the erring disc. However, there may be possible workarounds:
  • unplug the unit for an hour or so;
  • press and hold the eject button while plugging in; or
  • invert the unit (bottom side up);
  • plug back the Apex and quickly unplug soon as you hear the mechanical noise start;
  • revert to normal position and try ejecting; or
  • while still in the inverted position, press and hold the eject button while plugging in but must unplug quickly even before the tray starts to move out.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Oct 15, 2010 | Apex Digital AD-1225 DVD Player
I have a sony dvd player that has a stuck disc. Model number DAV-HDX275. The readout has a message "C31 00" displayed. Do you have any suggestions to remove the disk?
The only way to get this to eject is to open the case, Look carefully at the mechanism. Press eject and see what opart tries to unlock and assit it. The tray will then eject. It may be stuck because a piece iof the label is jamming the mechanism.
Please rate my help++++Thanks for using FIXYA
Jun 26, 2010 | Televison & Video
DVD is stuck in mechanism - don't know how to get it ejected
you would see at least 5 screws 2 at least at the side and 3 at the back. remove all the screws then lift the top cover. upon lifting it, you would see the top assembly of the pick-up lens. their is a piece of plastic that holds the cd and on its sides there two screws that might be covered by a double add tape, remove it and you would see the screws.
Aug 11, 2009 | RCA DRC230N DVD Player
Wife put another DVD in 32" Regza LCD with DVD, now 2 are stuck
Open it up. Once opened they are pretty easy to figure out.
Jun 28, 2009 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Stuck DVD
im not resposible for anything here but try this. stick another disc in only about half way or as far as it will go up to that point. when the loading mechanism in the player sees another disc trying to come in, it pops up to accept the disc. it should spit your stuck disc back at you while holding the new disc in your hand.
Jul 11, 2008 | Jensen VM9510 Car DVD Player
DVD caught inside machine
When a DVD won't eject, the most common problem is that the belt that operates the eject mechanism is slipping and not allowing it to eject the DVD. This can be fixed by either using a re-grip solution on the belt or having the belt replaced. With the cover off (be careful not to touch anything live with power) try to find the motor and belt which operates the DVD loading & eject mechanism. Try moving the belt pulley with your finger to give it a little help and see if it continues on with the operation. If it does, the belt is probably slipping. It takes more effort on the belt & pulley during an eject sequence rather than the a load sequence, so it may load fine but have trouble ejecting. Gravity and the weight of the DVD is why you may not have this problem during a load sequence.
Let me know what you find and we'll go from there.
Good luck,
- Jim
Feb 15, 2008 | Philips DVDR985 DVD Recorder
Dvd wont eject
Make sure the DVD player is level, and that there is nothing stuck inside. You might have to GENTLY nudge the door, with a careful prying motion. If it still won't eject, and you feel daring, you can open the device with the POWER OFF, (Don't lose screws), and see if it there is an obstruction. This last option will most probably void the warranty, so only do this if you are comfortable.
Sep 07, 2007 | Oritron DVD600 DVD Player
Philips HTS-6500/37 System Logo
233 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
