Question about Acer Aspire 5610-4648 Notebook
My sound device is gone
My notbook is Acer Aspire 5630, yesterday I found there is no sound at. Would you tell me what kind of sound device you use on the notebook ?
Acer orbi webcam for lap top acer aspire 5630 not working by skype???
Check your device manager for device flags.
If found remove them. Remove the device and allow windows to reinstall the drivers.
If the imageing device is not being shown in device manager, you may have a bad webcam.
Remove any, all usb input devices and reboot to safe mode.
Check your device manager for device and flags.
If your imaging device shows up in your device manager and not in Skype, try removing Skype and reloading
Hope this helps
Apr 08, 2014 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer web cam not working last 2 weeks,model of lap top is:aspire 5630
Check your device manager for the imaging device ( webcam )
If not found, try booting into safe mode and give a look again in device manager.
If you have any usb devices connected disconnect them
If all of this do not work, you may have disconnected the webcam or could be bad.
Hope this helps
My acer aspire 5630 wireless divices wont turn on
have you tried opening it on the control panel? please do try.
Mar 29, 2010 | Acer Aspire 5630 Notebook
Soundcard acer aspire 5630
Laptop speakers are usually **** so you could spend a lot of time and money on something that won't make a difference. Try plugging in external speakers to the headphone jack. If the sound is good don't bother looking for a fix.
Apr 27, 2009 | Acer Aspire 5630 Notebook
Problem with Bluetooth And Special button on top & Right (around keyboard)
  • Remove and then reinstall the device:
    1. Click the Start button , click Control Panel, click Hardware and Sound, and then click Bluetooth Devices.
    2. Select the device that's not working, and then click Remove.
    3. Click Add, press the reset button on the device (or make it discoverable following the manufacturer's instructions), select the My device is set up and ready to be found check box, and then click Next.
    4. If the device is not found, repeat the previous step. When the device is found, select it, and then click Next.
    5. Follow the rest of the instructions in the wizard.
  • Aug 18, 2008 | Acer Aspire 5630 Notebook
    Not drive sound found in my conputadora
    install the soundcard driver....use your installation cd
    Aug 04, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
    There is no sound
    Try re-installing the Sound Device Driver, you can download the driver here.
    http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=
    en&cc=us&dlc=en&product=366264&lang=en
    If my solution works, please spare a little time to accept my solution.
    -mrsolution
    Jun 12, 2008 | Acer Aspire 5600 Series 5630-6951 Laptop
    Aspire 5630 orbi cam
    ** Note ** When the My Pictures or Pictures folder gets full, camera will not work - Cut and Paste all pictures in that
    folder to another folder and restart Orbicam program.
    If that does not work then do this:
    Start - Programs - look for Acer Empowering Technology then Acer E-Recovery - The look at the bottom and you will
    "Backup", "Burn disk" and Restore" choose Restore - choose Apps and Drivers at the bottom of Restore tab (it will say
    extracting) - once extracted - click Install or Guides and Manuals if needing Orbicam instructions - click Vista or (XP) on the left - click Drivers - click Camera or CCD - on the
    right side of the screen, then look for Bison driver or (or your model which can be found in device manager - control panel - system - device manager - Imaging devices) you have then click a phrase that has something like "Install now", follow on screen instructions. Then repeat steps above and instead of driver choose Bison (or your model which can be found in device manager - control panel - system - device manager - Imaging devices) Utility
    Jan 28, 2008 | Acer Aspire 5630 Notebook
    Acer Aspire 5610-4648 Notebook Logo
    35 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
