Question about Cobra AH-1G - 1:48 Scale - US51208
Tail rotor does not work and the chatging cable does not attatch
This is a doubble set, the tail rotor stops working with in 10 seconds on one and the battery chager does not plug in on the other. The toys are still under warranty, but I can not find any contact information for Cobra toys.
Knut
  • 906 Answers
Good day,
hope this link below will solve your problem.
toys
Posted on Jul 30, 2010
    Brigadier General:
  • 4,090 Answers
Http://www.cobratoys.com/
Surely the place where it was bought should honor any warranty rather than the main company.
Posted on Jul 29, 2009
Brookstone cloud DSS copter will not stop spinning out of control and trim buttons will not fix it, what else is there that I can do to fix this problem.
many reasons for this, first tail rotor, then controller. but if the tail rotor in not working all it will do is spin just like the real ones I flew in the military.
Dec 30, 2014 | Toys
How could i use my iphone 4g to control my toy helicopter
Instructions
    • 1 Remove the main rotor blades, throttle up the helicopter while holding it in your hand and twist the helicopter from side to side to determine if the gyro is working. The gyro should make the tail rotor spin faster when the helicopter twists; you will be able to hear a difference. If the gyro does not appear to be working, replace it. Some gyros have a sensitivity adjustment screw; try making small adjustments if possible.
    • 2 Check the tail rotors and see if they are connected correctly. If the tail rotor blades are not pitched correctly they will not be able to hold the helicopter still.
    • 3 Test the tail rotor motor and see if it seems strong and responsive. Brushed motors, like those commonly used to drive tail rotors, can wear out in a relatively short time. Replacing the motor may solve your problem if the gyro seems to be working.
    • 4 Check the trim on your transmitter. Ideally the trim should be in the center of the stick movement. You may need to dial in some extra right trim or you may find the trim is set too far to the left.
Jan 20, 2013 | Toys
Ir helicopter only upper wing spinning
Have a SATURN-X 2CH IR and the tail and the tail rotor will not spin? What can I do?
Dec 30, 2012 | Worldtech Devices World Tech 85618 2CH...
We have lost our instruction manuals for our rc heicopters. is the small tail propellar supposed to spin? we can't get them to liftoff the main propellars seem to be working fine.
Sadly, Bob is incorrect here. In a coaxial helicopter, the main rotors spin in opposite directions, equalizing the centrifugal force and allowing the craft to hover without spinning, fine-tuned by the adjustment of the trim control. The counter-rotating main blades and internal gyroscopes provide a stable hover, while the tail rotor serves only to push the rear of the chopper up or down, providing the forward/backward thrust. If you are not moving the right joystick, you tail rotor should be stationary, or perhaps moving lazily from the wash of the main rotors. Sounds like a charging issue. What type of charger are you using? Also, Li/Po batteries are not meant to be fully discharged. Fully draining a Li/Po too many times, ESPECIALLY when they are new, will ruin them. Luckily the batteries on an 032 are easily replaceable. Available on Amazon and many other online retailers, and replaced in about 1 minute with only a small screwdriver. With a new Li/Po, charge them FULLY with the correct charger, and always stop the flight as soon as you are having to give it full power to maintain altitude. Also CRUCIAL is you MUST MUST MUST let the battery rest and cool for after a flight, wait a good 10 minutes BEFORE you connect the heli to the charger, and another 10 minute cool down after charging before you fly.
Hope this helps
r
Aug 19, 2011 | SYMA Toys industrial Syma S032 Ready to...
The tail rotor wont spin
It appears that the tail rotor holds the horizontal stability when going backwards. i.e. only works when command is backward.
If the tail rotor does not spin then try lubricating the shaft with some talcum powder. To test whether it working blow down on to the rotor and it should spin rapidly. The talcum powder worked for me.
May 05, 2011 | Spinmaster Air Hogs Yellow Jackal R/C...
The tail rotor will not work. The tiny motor is not working so it does not spin the rotor. What can I do???
doubld blade rotor there is no need for a rear/tail rotor, on the remote are 2 buttons they will control Left/Right spin , adjust so that it does not spin around
Feb 05, 2011 | JCPenney Gyropter RC Helicopter
97 Nissan p/u, dashboard,tail-lights,cabin lights,a/c not working
there should be a smaller fuse block with larger fuses. one should say either main or alt either way they are fuses that are larger and you can see through the top. if they do not come up easily, do not force it. some are attatched below with screws. the one you are looking for will probably come right out.
Nov 17, 2009 | 1997 Nissan Pickup
Orbit does not chatge (USB) NOT working !!!
there is a setting in the power optinos that says "not charging the pd while it is on AND plugged in to the computer"
Apr 17, 2008 | O2 Xda Orbit Smartphone
Hover Lites RAdio-Controlled Helicopter
MERCHSOURCE, LLC
19511 Pauling Street Foothill Ranch CALIFORNIA 92610
Mike Roberts, Partner and Co-founder of MerchSource, LLC
Mike Roberts, 949-900-0904
949-587-9207
RE: Hover Lites Radio Controlled Helicopter parts
I have/had the same problems as everyone else.. I found that this helicopter is the same as 9093 Syma RC Helicopter, here is the site where you can get parts!
http://www.raidentech.com/sy90drrchesp.html
Nov 11, 2007 | Optics
Cobra AH-1G  - 1:48 Scale - US51208 Logo
187 people viewed this question
Top Cobra Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Cobra Toy Expert? Answer questions, earn points and help others
