Question about Hyperkin Wireless Retron 3 Video Gaming System: 3 in 1 Console Plays NES, SNES, and Genesis Games - Charcoal
Retron 3 power supply cable problems in Australia. Where can I buy a cable that will work over here ???
American lead, how do i convert
How to convert an American lead will depend on where you are. You can buy a universal adapter at most travel stores, but first of all consider the local supply voltage. US power is delivered at 110 volts. Australia, Europe and much of the world have a 220 to 240 volt supply. Connecting a 110 volt machine to a 220 volt supply will create smoke and potentially flames - I've seen a number of disasters. Some machines are made to operate across both supplies. Check the label on the back of the machine, near where the power cable plugs in. If it reads 110 - 220 volt you should be OK. Your local Brother dealer should be able to supply a local market power cable for you. They cost around $30 in Australia.
Mar 03, 2015 | Brother Sewing Machines
MATCHING CABLES FOR A IOMEGA LPHD-UPC
Use a USB 3 cable it will provide more usb throughput
USB 3 card will provide more power when needed to the device to gain maximum throughput and conserve power when the device is connected but is idling http://blog.premiumusb.com/2010/09/usb-2-0-vs-usb-3-0/
Jan 24, 2013 | Iomega 500GB Prestige USB 2.0 Portable...
Retron 3 nes controller ports
I have no solution but having the same problem. Did you ever get it to work? And if so how?
Jan 09, 2012 | Hyperkin Retron 3 NES/SNES/Genesis Triple...
I have a model nus-001(usa) that was purchased some years ago. my grandson would like me to bring it to Spain where he lives with the games so he can play it. Will it work on the different electrical...
You can get a power adapter for the 64 that will drop the voltage for you. You will also have to get an video converter box that will convert NTSC to PAL B/G. You should be able to get a traveler power kit that should have what you need. The adapter should convert the power down. Don't use just the adapter unless the 64 says it can handle a 240v power. the usa use a 110 to a 120 power grid and Spain use a 240v power grid.
The retron 3 wont play nintendo 64 games. It olny will play nes snes and sega genesis games.
Sep 10, 2011 | Nintendo 64 Console
Super Mario game loads, the battery-operated wireless controllers do absolutely NOTHING. Cannot start the game -- get it onscreen and it goes through its little demo but the controllers just won't get...
I don't know a lot about this console (the Retron 3), but the game sounds like it works fine, try using a different third-party console, I recommend the Retro Entertainment System, it's only around $20 - $25 on eBay, try a different NES game, if it doesn't work, than it's probably the controllers, get replacements, or the batteries are dead.
May 06, 2011 | Hyperkin Wireless Retron 3 Video Gaming...
Here in Australia we have different power sockets and power supply As I understand the machine I have has 120V 60HZ 1025 W What do I need to use it here in Australia? Do I need a new plug or a...
good day.
first,the power socket,,try to see the power plug of your machine and the power socket you have..compare it..when its compatible no need to replace,,if not you need a socket adapter.or if not available buy a new plug (if your plug is not compatible to the socket)
secondly,you don't need a transformer if your ac supply in Australia is 120v..
if the supply in your place bigger than 120v...like 220v,230 or 250v..you have to use a step-down transformer with input of what you have in Australia and the output is 120v..and of course pay attention for the wattage of transformer to avoid over heat or burn..I suggest to buy 1500w...
thank you and good luck
Apr 07, 2011 | Microwave Ovens
Power supply different voltage supply will it work in Australia
Unless the power supply is a multi-system* type, the unit will not work in Australia without major modifications to suit the mains voltage. The differences between USA and Australian voltages are significant. We use a higher voltage rating for appliances than America does, and appliances made for Australia operate at around 220-250V AC.
In order for it to function correctly and safely in Australia, the power supply would need major modification, which can prove expensive, and often impractical.
Mar 02, 2011 | Magnavox MDR513H/F7 Player
Rode NTK power supply and cable needed . I inherited a mic but no power supply or cable.
use the web dude
http://www.rodemic.com/support.php#q23
Q: Can I buy a power supply for my mic?
A: NTK, K2 & Classic II mics are sold as complete units, power supplies and mics are not sold separately but as warranty items only.
For direct information and technical support questions contact:
In Australia:
ozsupport@rodemic.com
or call (02) 9648 5855
In United States and Puerto Rico:
usasupport@rodemic.com
or call (805) 566 7777
between 12:30PM and 4:00PM PST
Hope this helps
Thanks for using FixYa
Aug 12, 2010 | Rode NTK Professional Microphone
Hyperkin Wireless Retron 3 Video Gaming System: 3 in 1 Console Plays NES, SNES, and Genesis Games - Charcoal Logo
Top Hyperkin Video Game Consoles & Games Experts
James Wishart
Are you a Hyperkin Video Game Console and Game Expert? Answer questions, earn points and help others
