Question about General Kitchen Ranges
GE rofile Air Conditioner F2 error - General Kitchen Ranges
My window AC is showing F2 error, pl guide what should i do.
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem. Different models have different codes. Air Conditioning Repair Coral Springs
May 22, 2015 | Heating & Cooling
I get an error code EP on my GE room Air conditioner. what does this mean? i did what someone suggested and unplugged it; replugged it and reset it; still did not work,.
GE EP code is main compressor sensor.
Check damage to the temperature sensor
Sensor Cable left side yellow.
My airco got visited by a rat and damaged the wiring.
Cut it rejoined and code 32 changed into temperature.
You need the sensor. Just joining the cables will issue 99 and it will cut off and change into 32
You need a working sensor.
Sep 10, 2010 | GE AJCQ08ACB Air Conditioner
I have an E1 error code
Hi
E1 means Automatic filter clean reminder. Turn the air conditioner OFF and unplug it. Kindly make sure that the air conditioner is unplugged for the automatic filter clean timer to reset, then clean the filter. After cleaning, replace the filter and plug the air conditioner back in.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 08, 2009 | GE Heating & Cooling
E4 code is showing on my GE room air conditioner APE07AHM1
There is a water holding tank on the right lower side (when u are looking at the front), empty it and the unit comes back on.
Jul 12, 2009 | GE APH10AA Air Conditioner
Have a ge model ASW12ALS1 Air conditioner with error code E1
What does the EP light mean on a GE air conditioner when it. stays on and the unit stpps cooling.
Jun 17, 2009 | GE AJCQ08ACB Air Conditioner
F2 Error code displays with audible beep.
The F2 typically means an overtemperature conditions:
1. over 650 degrees F unlatched or 915 degrees F latched.
2. cooling fan stalled while over above 650 degrees F or an oper thermal switch in the yellow leads.
Check for:
1.Welded relay contacts
2.Cooling fan stalled or blocked air flow to rear of unit.
3.High resitance in over sensor leads/connectors, especially at sensor in rear.
Nov 03, 2007 | GE JTP20 Electric Single Oven
Kitchen Ranges Logo
16 people viewed this question
Top General Kitchen Ranges Experts
Dan Webster
Dan Webster
D. E. Hev
Owen Barnes
Are you a General Kitchen Range Expert? Answer questions, earn points and help others
