Question about Watches
Niagara conservation ECO IQ user manual
How to set the controls
Como hago para que me funcione el ensendido del tv
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Aug 03, 2015 | Casio Watches
Klik radio controlled watch
Why would he need the manual to do that ???
The time is self setting !
and to chage the battery just take out the back cover and slide the pin holding the battery in place, and replace it with the with similar battery...
I will try to find the manual for you..
post back in a second
Jan 09, 2008 | Watches
Program my Toshiba remote ct-8037
If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://electro-medical.blogspot.com/
Oct 19, 2014 | Toshiba 40UL605U 40-Inch 1080p 120 Hz...
Curtis and Co. Big Time 3 zone watch w/ temp gauge. What does the stem positioned at aprox 10 O'clock control? It is near the temp guage but does not seem to control anything.
Crown(stem) at 10 O'clock has air inlet for temperature, does not move. Crown at 8 O'clock is for setting 3rd time zone next to it. The two buttons on the right of the case, above and below, set 2nd time zone which is at the 6 O'clock position of the large dial. To set #2 push top button till min. hand moves 1 min., then push bottom button to move 1 min each time or hold for rapid movement. Large crown sets date and large dial. Unscrew it (counterclockwise) then pull out to first click, then set date turning crown clockwise, continue to pull out till 3rd click which is where you set the time on the large dial.
Dec 29, 2010 | Bulova Watch
Setting after battery replacement
I sent my Lacrose radio controlled watch out to have the battery was changed now the vendor says that the display is _ _ _
what do I or the vendor do to set the the watch again
My email is georgesaufley@yahoo.com
Aug 29, 2010 | La Crosse Radio Controlled Watch
Roberto vecci radio controlled watch instructions i cant set the analoge time
i HAVE RDIO CONTROLLED WATCH NUBER 02390 PUT A NEW BATTIER INIT BUT i CANT GET IT WORK RIGHT,DAVID
May 20, 2010 | Fossil Watch
Silicon Scientific Radio Controled Watch
how to change hour number for setting clock back
Feb 05, 2010 | Watches
I have a Timex N3 Radio Controlled Wrist Watch, but cannot find the instructions on how to set the functions. I have looked at Timex.com, but cannot find the model there either. The watch is approximately...
It seems likely that the setting instructions for radio controlled watches of one make are very similar so almost any of their radio controlled watch instructions may be used.
The user instructions list includes ones labeled "universal radio controlled book". Choose the one for your area and follow the instructions. You have nothing to loose!
Good luck.
Jan 15, 2010 | Watches
How to set a timex i-control watch
switch to time mode, and hold the middle buton on the left side until the watch shows SET TIME. press the next track button to set the hour (blinking on the screen) by pressing the + and - buttons to change the value. press the next track button to move to minutes, then seconds, then month, then day, and then year all being changed by the + or - buttons. then press the left middle button to exit. Congratulations, you just set your watch :D
Sep 23, 2009 | Timex i-Control 29571 Wrist Watch
Set date & time on radio-controlled Timex
Hold down the split/reset button until the flashing tower icon stops flashing then release the button. The watch will automatically receive the next scheduled radio update.
Apr 22, 2008 | Timex 27191 Wristwatch
Watches Logo
156 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
