Question about Kodak EasyShare Thermal Photo Printer
Kodak EasyShare printer dock
When trying to change ink cartridge, it would not eject. How do I get it out?
  • 5 more comments
  • Anonymous Dec 13, 2007
    The first time I need to get the ink cart. out to replace it will not eject and therefore I guess I'll have to send it back to Kodak...Because of course the warranty at the store has expired!
  • rgately Feb 10, 2008
    I am having the same problem. It just started. I have changed my ink cartridge before w/no problems until now. It just won't eject. Please help.
  • Anonymous Jul 22, 2008
    My printer indicates that I need to change the ink cartridge however the old cartridge will not eject.
  • Anonymous Nov 08, 2008
    I am frustrated. I can not change my ink cartridge either! I have been trying to use a fork to pry it out. I don't recommend it.
    I have the same problem. I can not remove my color cartridge in order to change it. I have been using a fork in an effort to pry it out. I don't recommend it.
  • Anonymous Nov 17, 2008
    the first time i tried to eject my ink cartridge it was jammed also. i did the same... trying to pry it out... did not work. any solutions?
  • El Queso Jan 14, 2009
    The left arrow key/ transfer button worked like a charm! Thanks! I almost broke my printer trying to get the ink cartridge out!!!
    Genius:
  • 2,985 Answers
Read the manual Tech support at Kodak if the manual does not have the answer
Posted on Jul 02, 2007
The print head needs to be released. One solution that worked for me was to: unplug the power source, hold down the left arrow key and the transfer key together. Plug the power cord back in. Hold keys down for 10 seconds or longer then release. This is supposed to release the print heads and allow the cartridge to pop out when releasing the little green tab that holds the cartridge in. The key is you have to release the print head if you try prying or forcing you can possibly damage the printer beyond repair.
Posted on Jan 13, 2009
SOURCE:
Need new ink cartridge for kodak easy share printer. have found no one that carries ink cartridge for our 2004 printer.
You don't say where you live but ink cartridges are available at places like BestBuy, Office Max, and online at amazon.com
Jan 13, 2011 | Kodak EasyShare CX7430 & EasyShare Printer...
How do you get the ink cartridge out of the printer
  1. Unplug your Kodak Photo Dock's power cord. Pull the black tab on the right side of the printer down to open the ink cartridge door.
  2. 2 Push up on the green cartridge release tab in the upper center of the ink cartridge to release the old cartridge. Pull the old ink cartridge carefully from the Photo Dock.
  3. 3 Rotate the new ink cartridge's ribbon wheel on the side of the cartridge clockwise with your finger to remove any slack in the film. Do not rotate the wheel too much---this will damage the cartridge.
  4. 4 Insert the new ink cartridge into the Photo Dock with ribbon film facing down until you hear the cartridge click in place. The ink cartridge will only go in one way.
    Do not touch the ribbon with your fingers. Handle the cartridge by its edges.
  5. 5 Close the ink cartridge door and plug in your Kodak Photo Dock's power cord.
jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
Aug 26, 2010 | Kodak EasyShare Printer Dock Series 3
Ink cartridge is empty and I can not remove it to change it. It won't come out!
Press the power button to turn off the printer. Hold down the transfer and left arrow button at the same time. While holding them down at the same time turn on the power button. Let it go through the initialization process and once completed, the head should be in the up position. Open the cartridge door and push the cartridge to make sure it is latched and locked in place. Once the cartridge is latched, release the latch and the cartridge should release itself. Remove the cartridge from the printer.
May 18, 2009 | Kodak Easyshare G600 (1633379) Dock /...
Can't remove used ink cartridge from G600 Printer dock???
I found a how to video on the web.Turn off your printer. Hold down the left arrow button and transfer button at the same time, then turn your printer back on. You should hear it make some noises, open side door push on cartridge to see that it is locked in. Then hit the green release button on the inside and the cartridge should come out on its own.
Mar 20, 2009 | Kodak Easyshare G600 (1633379) Dock /...
Hold the transfer button down then hold the left arrow. Make sure the printer is on. Should here some clicking noise. When it completes then remove the ink cartridge.
Jan 24, 2009 | Kodak EASYSHARE G610 Thermal Printer
Kodak EasyShare
All paper that will fit your paper tray will work. However, it is questionable that all ink will. Each cartridge has a unique chip inside that instructs the printer what the fluid level is and if its been refilled. To keep one cartridge design from being used in the wrong printer there is usually a design in the shape so that it will either not fit or not lock in place.
You can use any Kodak paper, yes. You cannot use any cartridge, no.
Best,
Worldvet
Jan 05, 2009 | Kodak Cameras
Easyshare printer dock seris 3
TRY THIS
UNPLUG POWER CORD/USB TO COMPUTER IN BACK OF DOCK.TAKE OUT PAPER TRAY.
LIFT DOCK (LOOK INSIDE (DEEP INSIDE AND SEE IF YOU SEE THE CARTRIDGE FILM ON A STEEL ROLLER,WRAPPED AROUND IT.)A FLASHLIGHT MIGHT HELP IN THAT STEP).
IF CARTRIDGE IS WRAPPED AROUND TAKE TO SERVICE PROVIDER(I TRIED TO FIX IT LIKE THAT AND IT WAS A HASSEL)
IF NOT WRAPPED AROUND GO TO CARTRIDGE OPEN DOOR/LIFTGREEN TAB UP.SHOULD EJECT(IF NOT TRY A BUTTER KNIFE AND PRY UNDER SLIVER DOT)NOT HARD BUT WITH ALITTLE FORCE SHOULD POP OUT.
REMEMBER TO LIFT GREEN TAB WHILE PRYING.
IF STILL STUCK MAY BE STUCK IN PRINT MODE
THATS BEYOND ME. GOOD LUCK.
Mar 19, 2008 | Kodak EasyShare Thermal Photo Printer
Kodak EasyShare Thermal Photo Printer Logo
190 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Clive
Clive
Ekse
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
