Error 92,607 on xerox phaser 8570 - Office Equipment & Supplies
  • 2072 Answers
SOURCE: xerox printer error code (04,025.46)
This is a print head position issue.
TRY FIRST (Solutions without parts):
1. Check that the wipe mechanism has homed. 2. Check the printhead position and verify that it has initialized properly / manually home the printhead and power cycle the printers power and check for the error to return. If not then the error was most likely due to non-process function (something out of sequence).
Part likely to be the cause:
GEARBOX AND MOTOR,PROCESS DRIVE - PL 4.0, Item 14.
Posted on Jan 21, 2008
  • 2072 Answers
SOURCE: Xerox Phaser 8200 error code 15004.45:25393
Yep. The drum heaters are burnt out.
There are 2,,, 150 watt Halogen lamps that heat the drum.
The way to see if they are working or not is to turn off the lights in the office or room the printer is in. Turn the machine on and look through the fan slots on the right side of the machine. GIve it a minute or two and you should see lamps glowing inside, ( I seriously doubt you will see them comming on).
That is a very common problem, You can purchase those lamps at Lowes, Home Depot or anywhere you can purchase halogen lamps. They cost about 12 dollars for a good pair.
Replace both .. If you want to try and do it yourself. Let me know I will send you directions.
Posted on Sep 11, 2008
  • 2072 Answers
SOURCE: XEROX 8550 DP ERROR Message 09,035,43; 10192
That is a cyan, ( blue) ink stick fault. What is happening is that the cyan ink sticks are not advancing down the ink loader properly.
Open the area where you load the ink and you probably have a cracked, twisted or otherwise stuck ink stick, the code you are reporting specifically refers to the cyan sticks. If you have to remove them, take a screw, a drywall screw is best, and twist it into the sticks and slide it back and out, then replace them or add new ones. But thats your problem.
Posted on Oct 29, 2008
  • 2072 Answers
SOURCE: i have xerox phaser 8560MFP error cod 07,010.43:14059
there is a stainless steel print head block on the lower back portion of the frame that gets contaminated with spill over ink from the catch tray. That causes the print head not to move properly.
The wiper blade may also be tacked to the print head.
That code means the print head is not moving into the print position properly.
That stainless steel block is about 1 inch square.
Posted on Mar 11, 2009
pineworks
  • 4041 Answers
SOURCE: Xerox Phaser 8560 - error code 09 037 45 108564
Hi there
That's a ink loader error, due to the 8200 ink stick; to fix it:
- Power down the printer.
- Hold the back button and the info button at the same time, without letting go, power up the printer.
- Keep holding down the buttons until the XEROX logo comes fully to the center of the screen, keep holding for 2 more seconds, then let go. I'll take about a minute or two for the Diagnostic screen to come up, the display will turn blank and black.
- When the Diagnostic screen comes up go to down to the Function or Exercise option, there will be an option that says "clear ISC faults" it'll ask you to press OK to confirm, after you do then you will exit Diagnostics and the printer will reboot.
It should be fine until it happens again. Until all the 8200 ink is gone you will probably be doing this a few more times. Also make sure the 8200 ink is not jammed inside the ink loader, if it is then you have to un-jam it some how.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 02, 2010
What does error code 99,013.00:49569 mean xerox 8570 color cube?
Process Drive Fault"
Do you have another kit you can take from another printer.
Switch the printer off.
Swap out the kit with the one from the other printer.
Turn it back on. If it clears the fault when the printer is ready put back the new kit
Aug 14, 2015 | Xerox Office Equipment & Supplies
What is Xerox 8570 ColorQube error 93 984.00:3683
93,984 means: Cyan obstructed, reservoir not filled
• Check for ink spills around the Printhead.
• Check the Ink Loader for bent melt tips.
• Check the Ink Loader power cable misrouting around melt tips.
• Check height of ink levels in the head reservoir.
Mar 15, 2015 | Xerox Office Equipment & Supplies
What does error code 91,721,00:3959 on a xerox colorqube 8570 mean
That error is a printhead tilt fault. The printhead is not able to cam back and forth correctly. There is a kit that fixes that problem, part number 8570-Z1. http://www.iteminconline.com/itemdesc.asp?ic=8570-Z1&eq=&Tp=
Aug 26, 2014 | Xerox Phaser Office Equipment & Supplies
Xerox colorcube 8570 wont start
its crazy we just had one the other day that was acting up. If you have a spare control panel try switching it, look for any lights. If you know your control panel is 100% good. Then you might have to end up switching the power supply.
iteminconline
Nov 04, 2013 | Xerox Phaser 8200 Laser Printer
Phaser 8570 makes grinding noise
Our Xerox 8580DN is making a grinding noise when starting up and then it doesn't start up it state that there's a jam.
Mar 12, 2013 | XEROX - COLOR PRINTERS COLORQUBE 8570/N...
What does a error code 99,060 mean on a xerox 8570
On the 8570 that is either a wave amp, the print head or a bad or loose cable in between.
Not a problem for the casual user.
I hope it's under warranty.
Sep 27, 2012 | Xerox Qube 8570/DNM Color Laser Printer...
What does error code 91,721.00:1039 on Xerox ColorQube 8570 mean
The error is a printhead tilt fault. It's unable to tilt on the axis, caused by a fault camshaft and process motor. The part you need to fix it is 8570-Z1.
http://www.iteminconline.com/8570-z1_8570-z1-xerox-colorqube-8570-8580-8700-process-drive-camshaft-kit-includes-process-drive-motor-drum-maintenance-camshaft-transfix-camshaft.htm
Aug 13, 2012 | Xerox Office Equipment & Supplies
222 people viewed this question
k24674
