Question about Heidelberg Linocolor Saphir Ultra2 Flatbed Scanner
Flat bed scanner
I am looking for a LARGE flat bed scanner
How can I find out if there are digital scanners available for 2.25 square negatives.
Given the popularity of these films (Kodak 120 or 620, dependent upon size of hole in the spool) there are scanners available.
However, the negative is large enough that ordinary flat-bed scanners with a film attachment will be sufficient for scanning.
http://photo.net/medium-format-photography-forum/00cN3y refers.
Jan 29, 2015 | Photography
How to scan a slide on flatbed scanner
This model Canon MX700 cannot scan slides.
A flat bed scanner that can scan slides and negatives has a light scource that shines through the slide and negative fand is detected by the scanner sensor.
I suggest you purchase a slide scanner, it will be cheaper that getting a new flat bed scanner with slide capability.
May 17, 2012 | Canon PIXMA MX700 All-In-One InkJet...
Scanner and flat-bed printing functions will not work. Printed paper shows a large white line in the middle.
Hello.
Check for a dirty lens, toner cartridge window or drum. Also, check for very tiny paper or other objects. Use a can of compressed air to clean, if necessary.
Hope this helps.
Jul 20, 2011 | Samsung SCX-4725FN All-In-One Laser...
I am looking for a scanner
Hp makes a nice Flat bed Scanner. Check out Best buy or Office Max for one.
Jun 26, 2010 | Umax Astra 1220S Flatbed Scanner
Color Slides appear griney at times & are not a complete slide
This May be a Problem with the Scanner Bed or the Scanner Software itself..........
If u Have a Windows Vista.......
Go to Start/All Programmes/Windows Photo Gallery...........
There you will see an option saying File click on that and now on the drop down click on Import from Scanner or Camera.........Select ur scanner from that list and click on Import.............And See how the Quality Looks there if the Quality there is Fine that means there is a Problem with the Scanner Software you can just Uninstall and Reinstall it........If it is the same there also it is a Problem with the Scanner Bed..........Try Cleaning the Scanner Bed with a Dry Soft Cloth..........
Good Luck
Apr 04, 2009 | Canon CanoScan 8600F Flatbed Scanner
I have a S2W 5000 W flat bed scanner and works
sorry 2 tell u this but its not compatible with vista
Mar 17, 2009 | BenQ Scan to Web 4300U Flatbed Scanner
Hp 2840 laser printer
are you feeding in the copies from the Automatic Document Feeder? Open the top of the flat bed scanner and look to the left you will see a small piece of glass that is used for the ADF and then you will see a large piece of glass that is used for the flat bed scanner. Clean the small piece of glass used for the ADF and let it dry before trying to use the copier again. Test the copier and see if the gray line is still there.
Nov 12, 2008 | HP LaserJet 2840 Printer
Copying on my 7210 hp all in one
are you feeding in the copies from the Automatic Document Feeder? Open the top of the flat bed scanner and look to the left you will see a small piece of glass that is used for the ADF and then you will see a large piece of glass that is used for the flat bed scanner. Clean the small piece of glass used for the ADF and let it dry before trying to use the copier again. Test the copier and see if the gray line is still there. if you are using the flatbed portion of the scanner, clean the larger glass on the scanner and as before let it dry before trying to use the copier again and then test the copier.
Sep 18, 2008 | HP Officejet 7210 All-In-One InkJet...
Scanjet 4850 flatbed
Hmmm... Throw a rather large hard covered book over the top of the lid when scanning?
Jan 07, 2008 | HP ScanJet 4850 Flatbed Scanner
Heidelberg Linocolor Saphir Ultra2 Flatbed Scanner Logo
29 people viewed this question
Top Heidelberg Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Heidelberg Office Equipment and Supply Expert? Answer questions, earn points and help others
