Question about HP DeskJet 6122 InkJet Printer
I have an HP 6122 Printer that has problems printing in black. There are streaks and gaps in the print. I went to the self-help and they state to run a program from the Tool Box. I do not have this software loaded on my laptop. Is is possbile to download the appropriate software from the web?
    Scholar:
  • 21 Answers
The original CD for this printer includes maintenance and utilities programs. If you do not have the original CD, you should be able to access the HP6122 maintenance and utilities programs online at the HP service website http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=83028&prodTypeId=18972&prodSeriesId=88749&swLang=8&taskId=135&swEnvOID=228
Select the full-feature version of the driver package. This kind of software generally is available free of charge from HP, but might require a small fee if you need the CD itself.
Within the HP6122 printer utilities are head-aligment and head-cleaning routines. One or both may be required to solve -- most likely head cleaning is required. Might require more than one cleaning event. Once clean, you can also print a test graphic from the printer utilities that does a good job of testing all colors and black.
Posted on Jul 13, 2009
How to check the ink level onC4480 printer
To check the ink levels from the HP Photosmart Software
1. In the HP Solution Center, click Settings, point to Print Settings, and then click Printer Toolbox.
NOTE: You can also open the Printer Toolbox from the Print Properties dialog box. In the Print Properties dialog box, click the Features tab, and then click the Printer Services button.
The Printer Toolbox appears.
2. Click the Estimated Ink Level tab.
The estimated ink levels for the print cartridges appear.
Or
Print a self-test report
1. Load A4 unused plain white paper into the input tray.
2. Press and hold the Cancel button and then press the Start Copy Color button.
The product prints a self-test report, which might indicate the source of the printing problem.
3. Make sure the test patterns show a complete grid and the thick color lines are complete.
• If more than a few lines in a pattern are broken, this might indicate a problem with the nozzles. You might need to clean the print cartridges.
• If the black line is missing, faded, streaked, or shows lines, this might indicate a problem with the black or photo print cartridge in the right slot.
• If any of the color lines are missing, faded, streaked, or show lines, this might indicate a problem with the tri-color print cartridge in the left slot.
Nov 30, 2010 | HP PhotoSmart C4480 All-in-One Printer ...
My HP Inkjet 6122 has suddenly started printing color photos with stripes. I don't use it very often, only when I need color photos. I have replaced both the #45 black and #78 color cartridges with genuine...
Use the HP Printer Assistant software tools to run a "head-cleaning" cycle -- the problem is not with the ink (there is plenty of it) but with the print-heads (that **** the ink, and then spray it onto the paper). Some of the jets are clogged, and so you get "white-stripes".
Aug 19, 2010 | HP DeskJet 6122 InkJet Printer
Greetings - have a full black cartridge yet prints green?
This printer uses all 4 inks to make black by default. You have run out of magenta in the color cartridge. Go to printing preferencies, Color tab. Check Print in Grayscale and tick "Black only" to disable color use.
Aug 14, 2010 | HP DeskJet 6122 InkJet Printer
Misplaced my manual. Color running streaks. How do I clean?
Go to printing preferences.
There should be a tab called service...
There you will have two options...
Clean the cartridge and Align.
Do both.
Jul 24, 2010 | HP DeskJet 6122 InkJet Printer
My printer is running a white streak through the center of pages
You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Next, try this printer self-test by following the steps given below:
1. Turn the power to the printer "off."
2. Press and hold the "Paper Feed" button.
3. Press the "Power" button once while continuing to hold the "Paper Feed" button.
4. Keep holding the "Paper Feed" button until one sheet is cycled through.
5. The test is continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, let us know.
Oct 01, 2009 | Lexmark Z715 InkJet Printer
Does not print color
did you recalabrate after changing cartridges? and if you di is the color printer head bad? run the hp test software at www.hp.com to troubleshoot your problem.
Aug 13, 2009 | HP Office Equipment & Supplies
Colour printing problem
clean it...
if u have cold air blower...
Mar 17, 2008 | HP DeskJet 6122 InkJet Printer
HP DeskJet 6122 InkJet Printer Logo
310 people viewed this question
Ben Johnson
