Question about Whirlpool Washing Machines
MODEL: ISC23CNEX*0* PLASTIC SKIRT BELOW DOOR AT FRONT
How do you remove melted plastic ironed into fabric
Did you try a ice cube or goo be gone you can get it at walmart.
Dec 25, 2012 | Irons
Whats an Air dam?
The air dam is the plastic skirt below the front grill that prevents air from getting under the vehicle. The air dam lets the vehicle hug the road for better steering control.
Jun 22, 2012 | 2008 Toyota RAV4
Hi all how do i use the jack of a 1997 318i bmw on the back wheel that is flat
Hi, BMW's have a jacking point. If you are looking at the back wheel, look along the side skirts under the back passenger door. There will be a small disc with a horizontal hole. Use a screw driver to turn the disc until it comes out, that is your jacking point.
Place the jack's horizontal arm all the way into the jacking point and start to wind the jack handle. The car will then start to rise at the back. The same prinicple appplies for the front as well, the fronts jacking point is on the skirting under the front doors.
Jan 10, 2011 | BMW 318 Cars & Trucks
Location of oil filter
The 2007 Tundra 5.7l engine doesn't have a spin on filter - it uses a replaceable paper cartridge within a permanent housing. Located under the skid plate on the front-left portion of the engine, the oil filter unit has two coolant hoses, a black plastic screw-in housing, and a large, metal, round screw with a 1/2" square fitting in the middle of it. The cartridge-type oil filter is in the housing.
If equipped with a skid plate, access is accomplished by removing the 5 skid plate bolts, allowing the plate to swing down on integrated hangars (with the front plastic bumper skirt still attached). To completely remove the skid plate, three small screws holding it to the front plastic bumper skirt must also be removed.
Toyotafilter kits contain a new filter cartridge, a plastic drain plug, and two O-rings. The drain plug is used to drain residual oil from the filter unit prior to removing the plastic screw-in housing. After removing the large, metal, round screw with a 1/2" square fitting in the middle of it, the plug simply snaps into the bottom of the plastic housing. The smaller of the two new O-rings replaces the existing O-ring on the screw.
Once drained, the plastic screw-in filter housing is removed using a filter wrench (Toyota special service tool). The larger of the two new O-rings replaces the existing O-ring on the screw-in housing. VERY CLOSE ATTENTION must be paid in placing the new O-ring - failure to properly seat the new O-ring could result in a massive oil leak! The filter itself is currently only available from Toyota.
Aug 15, 2010 | 2007 Toyota Tundra
Where is the air filter for the inside air
I believe, on your car, you will find it below the black plastic skirt, under the hood, above the fire-wall, passenger-side.
May 15, 2010 | 2000 Pontiac Grand Prix
HOW TO FIT A FRONT PANEL TO JACUZZI BATH
If you are talking about the skirt of the tub, most are held in place with a glue backed velcro type fastener. It is a thin panel of plastic that goes on the front outside of the tub, this is known as the skirt of the tub.
Mar 24, 2010 | Jacuzzi Home
Chevy caviler 1998 hit curb wit left tire
Something is bent... have a front end shop check it out, replace any bent parts and re align the front end.
Mar 13, 2010 | 1998 Chevrolet Cavalier
Its a air suspension comprssor for a 93 lincoln mark 8 were on the car is it located
The air suspension compressor is located on the passenger side of the car in front of the tire. To get to it, you must first lift the front tires off of the ground, remove the front passenger tire, and then remove the plastic skirt found behind the tire. After this is done it is easy to see the compressor which is found towards the front of the car, mounted just behind the skirt. I hope this helps
Aug 11, 2009 | 1998 Lincoln Mark VIII
Electric front seat stuck
the first thing to do is remove the plastic skirt around rhe seat,to do this remove the seat movement knobs by prying them off with screwdriver,gental steady pressure works,then remove the screw in the rear( back seat compartment),three screws at seat switches and the side skirt will pull out (four tabs are connected to the mating plastic pieces,pull outtoward you). two screws hold the front skirt on these are tough to get to they are at an angle. with this skirt removed you can get to the motor,
three screws remove the the motor (Isuggest unplugging motor,small connector) on each end of shaft are retaining bushings rotate them toward the back and they will disengage,you can now pick up the motor and the the shafts will come out with it.these shafts disengage from the motor and should be kept seperate (greasey)
I used a R2 square drive bit (the driver used to install deck screws) to find which screwdrive is jammed, I adjusted the other one to its front stop with square driver bit the worked the jammed one back and forth mostly toward the rear and it worked free.
I adjusted this one to the front stop and reassembled the motor,shaft(make shure to snap retaining bushing in place)reconnect motor connector,all plastic skirts AND NEVER ALLOW THE SEAT TO TRAVEL TO ITS FRONT STOP AGAIN. (4HRS)
Sep 18, 2008 | 2003 Toyota Camry
Washing Machines Logo
48 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
