Question about youtube.com
Fix sinkelator broke - youtube.com
My passenger door was opened while the lock was still down. Normally the lock pops up and the door opens but something snapped inside and now even when I lock it it can still be opened. Any ideas what
Not sure what broke but if you take your door panel off you will be able to see what broke and repair it yourself. Pretty simple mechanism and it will not cost you 500 to fix it yourself. A parts store will steer you in the right direction and sell you the parts. Should not be over 150 dollars to fix.
Feb 17, 2015 | 2008 Ford Escape
Spark plug wire failure
Put new one if not catalytic con. will be next.Could cost $500.00+
Jun 19, 2013 | Cars & Trucks
1995 jeep cherokee coolant line broke we fixed it
Take it back to the shop that fixed it or if you did it yourself, check that you didn't disconnect a sensor/plug from the transmission.
TD
Mar 10, 2010 | 1995 Jeep Grand Cherokee
The knob broke off. How do I fix it?
well if you broke only the knob, then thats an easy fix.. just obtain part # 154535903 - KNOB and replace.
however if you broke the shaft off inside the knob you will need to procure part # 154668901 - CONTROL MODULE
remove power from the dishwasher and remove the screws holding the inner door panel to the door.
once that is removed you should see the control assembly and related wire harness that needs to be disconnected and screws that need to be removed, etc..
hope that helps,
best of luck,
ttfn
Oct 19, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Cable connector broke off in back of tv
had same problem virtually impossible fix if broke off if you have rca plugs use vcr thats what i did!
Jun 30, 2009 | Televison & Video
How do i fix 3 red lights?
try extra cooler and googel for x-clamp fix
Jun 18, 2009 | Microsoft Xbox 360 Console
youtube.com Logo
Top youtube.com Computers & Internet Experts
Mike
Jerry King
Jerry King
Are you a youtube.com Computer and Internet Expert? Answer questions, earn points and help others
