Question about Phoenix Gold Octane-R 15.0:1 Car Audio Amplifier
Bridged wiring on 15.0.1 amp - Phoenix Gold Octane-R 15.0:1 Car Audio Amplifier
How do you wire 2 15 inch kicker cvx dvc 4 ohm subs to a 1700.1D hifonixs mono amp so i can get the most power
Wire both hot wires together and both ground wires together then wire them to the amp with the hot on one speaker output and the ground on the other speaker ground. This puts them in the bridged position. Pulls the maximum watts out the amp and unbelievable sound.
Feb 20, 2015 | Kicker Car Audio & Video
How do you wire a single 15 L7
Depends on a few things. What is the impedance of your speaker? I will assume it is dual voice coil with each voice coil having a characteristic impedance of 4 ohms. Next what amp are you driving this speaker with? What is its minimum stable load it can run at in bridged mono? If it is 2 ohms stable then you can wire the voice coils in parallel, + to + and - to -. Then wire the + and - to the amp in its recommended bridged configuration. If the amp is not stable down to two ohms you will have to wire the voice coils in series, you will not have effective power from the amp with an 8 ohm load.
Here is a diagram from kicker to aid you.
http://www.kicker.com/dvc_wiring
Jul 20, 2011 | Kicker Car Audio & Video
I wont to know if i can run 2 2410s concept amps bridged and how to do it thank you .they can run at 2410 watts at 1ohm or 1150watts at 2ohm .iam wanting to hook them up on a rdaudio v2 15 that is duel...
If you only have one of those speakers the lowest load you could present to an amp would be 2 ohms. So 1 ohm is out of the question. I would advise you to get another speaker and use 1 amp per speaker bridged mono @ 2 ohms. Connecting the outputs of power amps together is not advisable.
Dec 18, 2009 | Concept CD-2410 Car Audio Amplifier
I am running two 15 spl soundstream woofers with a soundstream 500sx amp how do I bridge them to get maximum performance
the 15 spl woofers are dual voice coil, i believe 2 ohms per voice coil.
the 500sx amp is rated 4 ohms bridged at 500 watts, it is capible of dropping to 2 ohms sterao, but no lower than 4 ohms bridged. to get maximum performance, you cannot use both voice coils of both speakers, you can only use one speaker, or both speakers, while only using one voice coil from each.
there is no point of bridging them, you can achieve maximum performance by attaching one voice coil from each speaker to each channel of the amp, while leaving one voice coil from each speaker unconnected. you could also use just one speaker, attaching one vioce coil to one channel, and the other vioce coil to the other channel. then, i would suggest getting a second, identical amp to run the second speaker.
if you are persistent on bridging to mono, then you can only use 2 voice coils (both from one speaker, or one from each speaker) and you must run the voice coils in series, that is, from the amp positive to the 1st vioce coil positive, then run a jumper wire form the 1st vioce coil negative to the 2nd vioce coil positive, then, finally, run the 2nd vioce coil negative back to the negative of the amp.
this is all assumming that each voice coil is 2 ohms and each vioce coil has seperate inputs, meaning that each speaker has 2 pairs of speaker terminals.
Oct 08, 2009 | Soundstream SPL 15 Car Subwoofer
Wiring diagram
run them in sereis hooking them all up together and bridging the amp
Jul 22, 2009 | Rockford Fosgate Power 1500BD Car Audio...
2 channel amp with 2 Kicker Cvrs 15"
Assuming the amplifier is 2 ohm mono stable... the amplifier is bridgeable... and the subwoofers are Single 4 Ohm Voicecoils, You would wire them as follows....
Both + on Both subs to the + bridged terminal on the amplifier.
Both - on Both subs to the - bridged terminal on the amplifier.
This will net a 2 ohm mono load for your amplifier.
If you have something different - let me know... and I will give you the proper wiring for what you have.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 10, 2009 | Kicker CVR12 Car Subwoofer
I need to know how to bridge a a 4 ohm 15 inch sub down to1or2ohm
Hello solo7908,
With a single 4ohm DVC sub there are only two possible wiring solutions, parallel the voice coils for a final 2ohm load or series the voice coils for an 8ohm load. In your case, you want to wire them in parallel, both positives and both negatives connected to the amp terminals.
Here are the diagrams: (-) to (-) and then to the amp - (+) to (+) and then to the amp. Impedance = 2ohms.
Hope this helps.
Jun 06, 2009 | Kicker CompVR 12" Subwoofers/Enclosure...
Wiring my subs to my alpine mrv-1000
did you read your instruction manual. does it says "it could be bridged to other amp"?. you can't make a bridge to amplifier that is not bridgeable. bridging an amp is a way which it is made through transistor type ampilfier by bridging more transistor inside and more voltage is required for bridging.
I don't know if we could do to an IC type amplifier. ask an experts about bridging IC types how to bridge maybe they know how.
and if you had an successful bridging, you may have a problem through your speakers, they may hit hard but you will experience some errors through your speakers and easy to worn.
Jan 22, 2008 | Pioneer GM-X962 Car Audio Amplifier
Hifonics X generation galiath old school
Find your manual here: http://www.maxxsonics.net/manuals/hifonics/ Next tell me the exact model number of your subs and type of box they're in Be sure to leave good feedback or I don't get paid
Sep 28, 2007 | Car Audio & Video
Phoenix Gold Octane-R 15.0:1 Car Audio Amplifier Logo
27 people viewed this question
Top Phoenix Gold Car Audio & Video Experts
Matthew Spark
Matthew Spark
Mark Skinner
Jeffery Lewis
Jeffery Lewis
Are you a Phoenix Gold Car Audio and Video Expert? Answer questions, earn points and help others
