Question about StarTech.com StarView SV211K 2-port KVM Switch
PING is virgin still going to ping boxes
Is virgin still pining the boxes
Posted on Jan 24, 2009
While playing games high ping,decrease it?
Whenever your ping gets high,You can reset the modem and un plug the connection ,then restart the pc ,then connect and try to play again.This may helps to reduce the ping.You can check the Local LAN Connection Ping using the steps below..
Start->Run->Cmd Prompt ->Ping ip or ping website name
To Ping a website you can visit the site Whoisxy.com/ping.aspx
Aug 31, 2012 | Computers & Internet
My ping is low what can i do?
Ain't it good that your ping is low? ;)
In case you ment your ping is too high:•Try to close all the p2p programs like bittorrent etc.
•Try some other server if you're facing this problem while gaming; the nearer, the better
•go http://www.speedtest.net/ and post your results here
Aug 27, 2012 | Microsoft Computers & Internet
Hello, to protect my self from hackers I tried to look in the Internet for the best ways to protect my PC from hackers and I did see this way start - run - command.com - host ping - ping port - ping port...
Unless you are experienced in computers you should not play with the registry (ever)
Do a system restore to before you went in and changed things. If that does not work you will need to reinstall windows.
Having antivirus and firewall turned on should be fine to protect you from malicious hackers.
Jun 15, 2011 | Computers & Internet
I want to ping by wan.
go to http://net2005.com/home/ and it will show you your external IP address. once you know your IP go to the command prompt and type ping (ip address)
Dec 24, 2010 | Computers & Internet
I get kicked due to high ping what should i do?
When choosing a server try to sort the list by ping rate and go with the lowest ping you can that is offering the map and amount of players you are looking for. If you frequently get disconnected or see connection_error on your screen while playing it could be a problem with your actual internet connection dropping packets. To test that you will need to ping a well known server like google or microsoft and see what ping times you get and if any packets are lost. This can by done by clicking start -> run and typing cmd then pressing ok. In the dos box that pops up type ping -n 20 www.google.com and press enter. Significant packet loss and high ping times could mean your connection is saturated from other downloads/uploads, there is some bad cabling or network hardware somewhere, or your ISP is having some problems. If you are connected to a router or other network equipment and assuming you have a high speed connection try connecting directly to the modem provided to you and see if that helps. If the problem continues you will need to contact your internet provider for additional troubleshooting.
Mar 17, 2009 | Electronic Arts Counter-Strike: Source for...
Unable to connect to internet.
Go to any working computer on your network.
go to start
programs
accessories
command prompt
at the command prompt, type ping and your IP address.
2) or go to start
go to run
in the run box, typr cmd,
at the command prompt type ping and your ip address
thanks
Jul 18, 2008 | HP Pavilion dv8000t Notebook
Virgin broadband to laptop
Try setting a static IP on your computer with the DNS provided by the modem- to set this up contact Virgin and have them help you setup a static IP(or if you know how to set static IP on the computer use the same IP information you getting from the DHCP).
May 13, 2008 | Belkin (F5D9230-4) Wireless Router...
ActionTech Wireless Gateway can't route Wireless to LAN
Disable firewall on all devices. All types of security sofwares should also be disabled in order to ping each devices.
Oct 07, 2007 | Actiontec GT704WG Wireless Router...
StarTech.com StarView SV211K 2-port KVM Switch Logo
44 people viewed this question
Top StarTech.com Computers & Internet Experts
Alun Cox
mbowen171
mbowen171
Are you a StarTech.com Computer and Internet Expert? Answer questions, earn points and help others
