Question about Hotpoint BWM12 Front Load Washer
My Hotpoint BWM129 keeps getting stuck in the spin cycle either as part of a wash programme or as a separate spin. Any ideas what might be causing this. It is a built in model
  • 1462 Answers
SOURCE: stuck in wash cycle
check if heating by putting on as hot wash and feeling the door. if no heat, check continuity thro the heater - modern heaters have a non-resettable cut-out in them which can cause problems. no heat then no program advance
Posted on May 08, 2007
SOURCE: Hotpoint WD129 Wash programme stuck
The solution was correct it was the heating element, after it was replaced the machine now works fine !!!!
Thanks for the help !!
Posted on Dec 22, 2007
vest6
  • 196 Answers
SOURCE: hotpoint bwm129 lights flashing
What mode are you starting this machine in ? I know this may sound silly and I'm trying to determe if this is a machine fault code or something else.
Posted on Jan 02, 2008
ghappliances
  • 126 Answers
SOURCE: hotpoint bwm129 gets stuck mid cycle and dial does not move round
YOU NEED TO ESTABLISH IF YOU ARE USING A HOT CYCLE IF THAT IS SO YOU MIGHT HAVE E PROBLEM WHERE THE ELEMENT IS NOT COMING ON THEREFORE THE THERMOSTAT WILL NOT FUNCTION RESULTING IN THE TIMER REMAINING STILL.YOU NEED TO CHECK THE ELEMENT IF THATS THE CASE.IF YOU ARE USING THE COLD CYCLE AND IT IS STUCK ON THE SAME POSITION FOR A LONG TIME YOU MIGHT HAVE A FAULTY TIMER BEST YOU HAVE IT REPLACED IF THAT IS THE CAUSE.LET ME NO IF YOU NEED ANY MORE ASSISTANCE.GOODLUCK.MOHAMED
Posted on Sep 15, 2008
ginko
  • 19396 Answers
SOURCE: I have the hotpoint BWM129 super silent 1200 spin,
The flashing lights means that an error had been detected.
The machine must be unplugged from main to check the drain hose and the drain pump.
The most common is that the drain pump is clogged with debris and must be unlocked.
Posted on Feb 18, 2009
What fault code on a Hotpoint BWM129 does Door Lock LED rapidly flashing along with Delay Start LED flashing intermittently represent?
replace the motors brushes check the filters
and clear any bits of bra wire etc
then reset the machine {usually hold power in and apply the mains}
May 25, 2014 | Hotpoint Washing Machines
My Hotpoint BWM129 drains at end of a cycle but doesn't proceed to spin, fault lights flashing are rapid Door locked and intermittent Delay Start. Does this fault code indicate a faulty drain pump or
Engine fault or main board fault. Most likely main board.
Check cable harness from main board to engine. Check the carbon brushes on the engine. If its all okay, replace main board
May 21, 2014 | Hotpoint Washing Machines
WF220 Hotpoint - burning smell + wash cycle stalls?
The burning smell is coming from motor. Also your clutch is bad where you are hearing the rattle/grinding.
Dec 12, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint bwm129 gets stuck mid cycle and dial does not move round
Sep 15, 2008 | Hotpoint BWM12 Front Load Washer
Lights flashing & door wont open
Dear RedBikeGirl
I've got a BWM129 which is causing me problems too (the washing is smelly at th eend of the cycle!) - How did you get the filter unit out of its housing, I turns around but doesn't seem to want to come out!
Any help gratefully received
Jun 01, 2008 | Hotpoint BWM12 Front Load Washer
i am having the same problem with my widl126 washer.
ant help?
Apr 30, 2008 | Washing Machines
Stuck in wash cycle
May 08, 2007 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint BWM12 Front Load Washer Logo
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
