Question about Mitsubishi WS-55908 55" Rear Projection Television
WS-55908 remote control
The TV was recently given to me as a gift, and when I first connected it, the remote volume worked fine; but after I configured the channels and sound settings, volume and mute buttons do not work. How can I reset the remote?
    President:
  • 3,130 Answers
Take out the batteries or simply reprogram the remote by using the manual search function on the remote. There is probably a couple of different settings in the remote for this type of TV set, Good Luck
Posted on Jul 02, 2007
Tivax STB-T9 DTV converter - remote control audio buttons no longer controlling TV audio
Maybe the remote got dropped by the cleaners. If you could control volume with the remote previously and now can't, I suspect the remote needs to be replaced.
Jan 26, 2014 | Televison & Video
The Color On My Mitsubishi Rear Projection Tv model- WS-55908 looks to be off, picture looks blue and Yellow.
its sounds like the convergence on your TV needs to be adjusted. (this adjusts all of the color guns in the back of the tv to line them up again, when they get off, you start to get yellow blue or red halos around objects in the picture. In the setup menu on your TV under picture or Display there will be an item that says "convergence" follow the instructions in there so all the crosses on the screen no longer have colored halos anymore.
Mar 10, 2011 | Mitsubishi WS-55908 55" Rear Projection...
I recently recieved the Mitsubishi 555 11 from my Dad first thing i dont know how to hook my Direct tv reciever to it second i cant get the volume bar to go away and lastly the remote doesnt work.
first of all all you need to do is hoop up the direct tv on input 1 yellow with yellow , white with white and red whit red , then about the volume check and see if you can do something without using the remote control just press the volume on the tv and if nothing happen then you have a defected key panel and that's way you can't use the remote control , now what you can do is take the speaker grill off follow the wires that came from the key board a desconnect then and then try the remote control it should work
Jan 15, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Hi, I have a WS-55908 Mitsubishi tv, I turn it on
Do the self check this set has--when you turn on and power light comes on and then goes off:
On the front of the set press both the Menu and Input (device) buttons at the same time and hold them for at least 5 seconds and then release both buttons.
The power light will then blink a two digit error code--the most common is 2 blinks, a pause and 2 blinks---it will repeat it several times.
Let me know what you find and I will tell you what it means---based on your description I bet you get 2,2 error code.
If this has helped you rate this solution as I do this here for free.
SD TECH
Dec 23, 2009 | Mitsubishi WS-55908 55" Rear Projection...
WS-55511 55in volume turns up by itself & can't switch devices
The remote is not the problem. The switch for volume up on the control panel has become leaky. Very common problem for this generation Mitsubishi. If you don't mind not having the control panel working you can disconnect it and the set will work just fine with the remote. To disconnect the control panel pull the speaker grill, it just snaps off, and remove the front access panel. Once that is done you'll see a cable going to the switches just disconnect it.
Nov 23, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Tv ws-65511 volume stuck
Did you ever get this problem fixed? Ours just started doing the same thing. It worked fine the night before, but today it's doing what yours is doing. The remote stopped working for the TV. The remote still works for the cable box, but volume and anything related to TV function not. The screen flashes when we try to adjust volume or anything else, but resets to previous volume. TV not responding to any commands either on the front panel or remote.
Any ideas? Thanks, Patti
Aug 10, 2008 | Mitsubishi WS-65511 65" Rear Projection...
My ws-55908 just turned off the other day and does not turn back on.
the main power supply has gone out it may not be worth the 4to5 hundred to repair it
Jun 21, 2008 | Mitsubishi WS-55908 55" Rear Projection...
Ws-5511 Mitsubishi
On these models we have found that a switch is sticking on the control panel not allowing the set to operate properly.
Disconnect the control panel.
You will be able to use the remote on it.
To find the plugs for the control panel:
Remove the speaker grill and front panel, then follow the wire to the connection.
Remember to unplug the set before putting your hands inside of it.
Dec 13, 2007 | Mitsubishi WS-65908 TV
Volume and mute buttons
I found the manual you need: http://download.jazel.net/misc/filecache/bc/bc9ff1b4e9d65cfcf99b8cea4b75180f_1104-V17++.pdf
Jul 02, 2007 | Mitsubishi WS-55908 55" Rear Projection...
TV picture goes out and then comes back, TV eventually turns off
Probable bad DM module = repairable by qualified Mits.tech.....
Nov 13, 2006 | Mitsubishi WS-48613 48" Rear Projection...
Mitsubishi WS-55908 55" Rear Projection Television Logo
96 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
