Question about Craftsman 13953615SR Remote is Equivalent to the 61LM
Where is the SR button on 13953615sr craftsman opener?
I need a gear for FCC ID : HBW1127 craftsman garage door opener 41A4315-7C, what is the part number?
This is the one you will need. Best place to buy is from Amazon if you are going to do it yourself.
http://www.amazon.com/Chamberlain-LiftMaster-Craftsman-41C4220A-Sprocket/dp/B006L8CZKI/ref=sr_1_1?ie=UTF8&qid=1424440429&sr=8-1&keywords=craftsman+gear+kit
Feb 20, 2015 | Craftsman Garage Door Opener 1/2 HP Chain...
Need MANUAL for Craftsman 13.5 hp 30" rider mower - CAN DOWNLOAD IF YOU PROVIDE MANUAL
go to sears... you need your model number and it's free... no model number, no help
Aug 22, 2014 | Craftsman Garden
How do i reprogram garage opener model 139.53776
To ensure that old codes do not work, first press and hold the SR code button (Learn) on the garage door opener's control panel. Hold the button until the LED goes out. The Learn button is a colored button that is usually on the back panel to the left of the force and up/down adjustment knobs. Sometimes the control panel is on the side of the unit.
Next get a helper to make the programming easier. One person will need to press and release the Learn button. Then within 30 seconds, the second person (or a fast moving individual) needs to type in a 4 digit code and press the enter key on the key pad. The LED near the learn button will flash when the code is received.
If you reset all of the codes, you'll need to repeat the fast press and release of the Learn button. Then press a control button on the remote for most of your other door opener remotes. (There may be a pair of remotes that came with the garage door opener that will never be forgotten.)
I hope this helps.
(This works for all of the Craftsman door openers that I've dealt with.)
Jul 10, 2014 | Building Materials
Sr 5003 is stuck in standby
The reciever has a internal problem, It will have to be taken in to be repaired, It is that simple to figure out, They do not stay in the stand buy mode , Just for something to do,
Nov 26, 2012 | Marantz Sr 5003 Home Theater Receiver 7.1...
How do I program 2 remotes for a craftsman 13953615sr garage dooe opwner?
Actually, if it is an older liftmaster, I'll bet you are using one older and one newer remote, probably different brands.
There were several code systems used, most notably "billion code" and "rolling code". The liftmaster can use one at a time. If you have one "billion code" (older) remote and one "rolling code" (newer), you will be able to use only one at a time.
See the "Remote control" section of this article:
http://en.wikipedia.org/wiki/Garage_door_opener
Jan 28, 2012 | Sears Craftsman LiftMaster Chamberlain...
Garage Door Opener Keypad I have an older Sears CRAFTSMAN Garage door opener and am trying to find a Keypad (that is afixed to the outside of the garage). that can operate the door. I have a remote (2...
Call around to the Chamberlain dealers in the yellow pages. They might have one in stock. The part number is 66LM. They are expensive though. $55.00. You might consider replacing that old opener you have.
Jan 15, 2011 | Sears Craftsman LiftMaster Chamberlain...
Garage door opens on its own with new Chamberlain "Clicker"
There can be a short in the logic board that causes this problem.
Oct 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
How do you change the code on the keypad for a sears/chamberlin garage door model#13953615SR
On the back of the motor unit near where all those white wires go you will find the smart/learn button. Press and immediately release this and walk over to your keypad and key in any 4 digit number you desire and press enter. Your code will be changed.
Jun 05, 2009 | Sears Craftsman LiftMaster Chamberlain...
Need to change keypad code, but lost instruction manual
The key code transmitter for your unit should be 53776 multi key panel:
you must have access to the operator to reset. The programming keys are as noted below:
1. Open the Touch C.ode Transmitter cover to access the keypad.
Decide on a 4-digit code number using numbers from
0 to 9. You can use a number more than once. (For
example, 4, 0, 4, 1).
2o Press the 'SR' code button on the opener panel. The
indicator light atongside the push button will turn ON.
3_ STAND AWAY FROM THE DOOR. Press the selected code
numbers on the keypad and then press the ENTER key.
The indicator light on the opener panel wiil turn OFF and
the door witl begin to move, The opener receiver has been ._
programmed with your code selection. (_
NOTE 1" If the indicator light turns OFF before the code _ . "_ _'
digits and ENTER key are pressed, repeat Steps 2 and 3. _._t,_-_ J t_
NOTE 2' During programming, be sure the,k/_ca_i_n push :---'-"_"
button (if your opener has that feature) is OFF and the
Infrared Sensor (if you have installed that accessory) is
free of obstruction. THE DOOR WILL NOT MOVE AND THE
INDICATOR LIGHT WILL NOT TURN OFF in either case.
To change your code at any time, repeat Steps 1, 2 and 3.
Hope this helps
Apr 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftsman 13953615SR Remote is Equivalent to the 61LM Logo
61 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
