Question about Maytag MAH2400A Front Load Washer
Maytag washer f23 error code - Maytag MAH2400A Front Load Washer
2 Suggested Answers
appliance765
  • 83 Answers
SOURCE: error code FL-maytag neptune front load washer won't lock
replace door latch (fl = faulty latch ) good luck APPLIANCES R EN
Posted on Mar 10, 2013
What does f23 error mean?
Display shows an error code - Front-load washer ' Whirlpool ...
https://www.whirlpool.com/...error-code...w...
Whirlpool Home AppliancesCheck the following answers for error-code related issues you can correct: ... Duet SportTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33.
What does error code f23 flashing mean on a Whirlpool ...
Nov 30, 2015 | Washing Machines
F23
PRESSURE SWTICH ERROR
The wash level and level heater safety are switched on at the same time F23
Possible Causes/Procedure
1. Unplug washer or disconnect power.
2. Check wire harness connections to pressure switch and Central Control Unit (CCU).
3. Check connections of the CCU board within the housing.
4. Check the pressure switch for worn or failed conditions .
cheers
Jul 18, 2017 | Whirlpool WFC7500VW Washer
My Maytag washer has a flashing F 15. What does that mean?
The following list of codes indicates an electronics communication problem with the washer: * EpicĀ® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
* Epic ZTM washer - F01, F11, F23, F24, F27, F28, F29, F30, F31, and F33
To remove the error display, press Pause/Off or Pause/Cancel twice.
If Pause/Off or Pause/Cancel does not work:
  1. Unplug washer or disconnect power for one minute.
  2. Plug in washer or reconnect power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, call for service.
Hope this helps.
Jun 24, 2011 | Maytag EPIC MFW9700S Front Load Washer
I keeg getting the dreaded F11 anf DL code!
Duet HT® washer - F01, F03, F06, F11, F23, F24, F27, F28, F29, F30, F31, F32, F35, F42, F61, F62, F63, F64, F65, F70, F71, and F99
Duet® washer - F05, F07, F09, F10, F11, F13, F14, F15, F21, F22, and FdU
PLACEHOLDER FOR ART
To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
NOTE: If the error remains on the display, then call for service.
Take care
Jun 22, 2010 | Whirlpool GHW9400 Front Load Washer
F35 code
Take care
Jun 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code f35 on my washer
Dec 19, 2008 | Whirlpool Duet GHW9150P Front Load Washer
ERROR CODE F71
Dec 11, 2008 | Whirlpool Duet GHW9150P Front Load Washer
F-23 error code
HOW TO FIX WHIRLPOOL WASHER F23 ERROR CODE What does F23 mean on whirlpool washer? It means there is a heater failure. If the water temperature in the washer fails to reach 86 degrees or higher then the washer will give the F23 error code. To fix the whirlpool washer f23 error follow the steps listed below.
Note: Some models do not have a heater as shown below, some models just have a temperature sensor. If your model does not have a heater just skip to checking the temperature sensor.
  1. First unplug the washer.
  2. Check the wiring to the heating element make sure its not burned, broken or corroded.
  3. Check the heating element for continuity of course if it does not have continuity then replace the element.
  4. Check the water temperature sensor wiring for corrosion or breaks.
  5. Remove the wiring harness from the temperature sensor and measure the resistance of the sensor. Refer to the chart below and if its out of range replace the sensor.
see link below for details and where to buy the part which is under $80 and fairly easy to replace
How To Fix Whirlpool Washer F23 Error Code Appliance Repair Guides
Jan 02, 2018 | Washing Machines
Whirlpool duet wahsher
PLACEHOLDER FOR ART
please do not forget to rate and comment about your experience with fixya today.
Aug 18, 2008 | Whirlpool Washing Machines
Maytag MAH2400A Front Load Washer Logo
168 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
