Question about Safe International Quick Ship: 21.5"H Gardall Media Safe
Battery compartment on gardall safe - Safe International Quick Ship: 21.5"H Gardall Media Safe
The battery in my home safe has died, i have a key but can't see where it goes ?
You didnt provide the type of safe but on mine the bottom of the keypad lock mechanism has a compartment for the battery. Mine doesnt need to be opened to change the battery. If your has a compartment if you push on it it will pop open then you just change the battery.
Apr 05, 2017 | The Home Security
Where do you replace the battery on this safe and what kind of battery
Although the following is applicable to most Safe, you model may differ.
The hardest part about changing the battery in a digital safe is finding where it is. But don't worry, it's not inside. The battery compartment is under the keypad, and has a little tiny hole for removal. If you don't have a jeweler's screwdriver that is small enough, you can use a straightened-out paper clip. The battery is a 9 volt.
Things You'll Need
  • Jeweler's screwdriver or paper clip
  • 9-volt battery
  • Insert the jeweler's screwdriver or paper clip into the small hole in the plastic panel, just below the keypad and to the right of the keyhole.
  • Slide the panel to the right.
  • Carefully pull the old battery out.
  • Carefully unsnap the wire connector from of the old battery. The connections are like clothing snaps and just pull off.
  • Snap the connector onto the new battery. Be sure to observe polarity--it will fit only one way.
  • Carefully put the new battery into the battery compartment, storing the wires out of the way of the cover.
  • Insert the cover in its slots, and slide it back into place with the jeweler's screwdriver or the paper clip.
Mar 09, 2016 | Home Security
The door is open.but i do not remenber the combination on the gardall eletronic sefe, and how can i change the combination
there is a panel on the back of the door, you will need a locksmith to change the code but only if the door is open.
Feb 08, 2015 | Home Security
How do I change battery in safe
Usually there is a compartment on the inside of the door that holds the batteries.
Jan 30, 2015 | Home Security
How can i open a locked safe?
Legally, I hope! You can call or write the manufacturer for a special code or instructions. They may be reluctant to help unless you can provide sufficient identification. Here is their support website:
http://www.gardall.com/area-support.htm?PHPSESSID=9c2dbe88278cd22d97fb7f55aa003f02
Jun 17, 2014 | Home Security
Gardall safe
No, you need locksmith.
Sep 13, 2013 | Computers & Internet
My Nikon N2000 works great but it has one problem , on one side of the battery compartment the two aaa dies very quickly but not the other two aaa batterys
You may have some corrosion under the battery compartment causing a short that drains the batteries. You can safely remove the battery compartment with a small cross point screwdriver. Remove the batteries, there should be 5 screws, The only concern is that some models had wires soldered at the contact end, but most had only spring contacts. Check the backside and end of the compartment for a white or green build up.
Jan 25, 2010 | Nikon N2000 35mm SLR Camera
Sentry s3877 battery compartment broke
I had the same problem with my Sentry S3877. I found the exact 4-battery replacement (with snap attachment on top!) at an online electronics.retailer, but had to purchase a lot of three. I don't need the other two, so I'll sell them for just $6 each to the first two folks to contact me mark@irregardless.net.
Oh, by the way, once the batteries went dead, you lost your combination! When you pop the new battery compartment in, the factory default combination will be in effect. That default combination is in your user's manual. I'm currently searching frantically for mine! Gee, how could I have misplaced it ... I just had it in my hands when I purchased the safe 10 years ago !!!
Anyone know the default combo for the S3877?
---- Mark
Sep 15, 2008 | Sentry Fireproof Safe
Safe International Quick Ship: 21.5"H Gardall Media Safe Logo
46 people viewed this question
Top Safe International Home Security Experts
Computer Repairing
Computer Repairing
Theo Nikolaidis
Theo Nikolaidis
Are you a Safe International Home Security Expert? Answer questions, earn points and help others
