Question about Genuine Ice Maker Ice Stripper WR29X10085
Ice maker stripper
How to install?
3 Suggested Answers
  • 106 Answers
SOURCE: ice maker plastic piece (ice stripper broken) How
CONTACT DEALER OR COMPANY
Posted on Nov 17, 2010
richroth
  • 9472 Answers
SOURCE: ice maker wont make ice
Here is the service manual for that ice maker.
Posted on Nov 22, 2012
Ice make does not make ice.
You say water pressure is fine but are you saying that the water valve is working? That's one possible answer and the other is a bad ice maker.
Aug 03, 2015 | Refrigerators
Why is my Ice Maker in GE Refridgerator "leaking"?
We had this happen twice and both times it was the line that supplies the water to the ice maker. We had to change the line because it was made of plastic and had cracked.
Jun 05, 2017 | Refrigerators
Timer ice maker kenmore side
If the timer piece you are referring to is behind the square white cover, and it's moving slightly back and forth, you should visually check the ice making area it's self to see if the ejector fingers are jammed with ice, or against the ice stripper. Ice Maker jams can be caused by reduced water pressure to the unit mainly from the water filter, your water filter in the toe kick should be replaced at an interval of 6 months to a year, regardless of filter status light. When water pressure is low, not enough water fills the unit and the undersized cubes can become lodged or stuck in the ice maker while being ejected, equally so if there is an over fill situation caused by other failures the ice maker can't eject at all. Pleazer Appliance...
Ejector fingers
Ice Stripper
Apr 17, 2014 | Refrigerators
+auger in ice maker broken Can replace auger only? part?
Hello, Thank You for using FixYa. I will be helping you today.I checked every where and the ice stripper is no longer available for that ice-maker. You would have to replace the whole ice-maker.
Thank You and please rate my answer if it was helpful..
Jun 10, 2011 | GE GSL25JFPBS Side by Side Refrigerator
ICE MAKER BLINKING ON/OFF. TURN IT OFF & BACK
Icemaker is jamming. Stripper may be bent where the ejector hangs up advise replacing icemaker
Feb 08, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The ice stripper on my icemaker has warped. Its
when ice maker goes into harvest the unit stall on the ice /the heater comes on and when tray is warm the ice moves out on the stripper . . i would think the tray is loosing its coating and the ice does't release and the heater stayes on too long . may have to replace the mold or ice maker .. ****
Jan 18, 2010 | Refrigerators
Ice maker won't work
check the position of the strippers in the icemaker. normal "home position" is at the 2 o'clock facing the front of the i/m if the strippers are in any other position most likely you have a bad motor module on the i/m pt# 628366 (whirlpool part number) should fix it up for you.. Good luck Peyton
Jan 19, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Ice maker.....one of the stationary fingers on the ice maker is broken. Can I just replace this Comb? or do I need to replace entire ice maker?
On some icemakers you can just get the stripper. It would depend on the brand and model of the unit.
Apr 18, 2008 | Refrigerators
Kenmore side by side
Your motor module is bad on the ice maker. It is located on the left side when mounted in the refrigerator. It is under the White Cover over the end. It is brown in color. To verify the correct problem, the ice stripper arm in the ice maker that turns and pushes the ice out of the mold, should be pointing up towards you when it is in the mounted in the refrigerator. I call it the 2 O'clock position. If the ice stripper arm is pointing another direction, it is broken. I sell the module on Ebay as username, themackshack. My parts are genuine factory parts. Good luck!, Mack
Jan 08, 2008 | Kenmore 50522 / 50524 Side by Side...
Genuine Ice Maker Ice Stripper WR29X10085 Logo
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
