Question about Health & Beauty
On my mercury prism scooter the fault light flashes 8 times . i have changed the battery but the fault remains and the scooter does not function
  • 175 Answers
I believe that this is the same as the US version of the Drive Phoenix scooter. If so, here's a link to the troubleshooting guide which you will need a multimeter to check. An 8-flash on the Phoenix indicates that there is a probable motor fault, which isn't good news at all. This is a small scooter, and the motors are not designed for heavy loads, or long climbs up steep hills. Other problems arise when folks drive their scooter through mud or other unstable surfaces and they get stuck. This can burn out the motor as well. More on the Phoenix here.
Posted on Jan 10, 2013
  • 175 Answers
SOURCE: my pride IV scooter will not start I get a click
An 8-flash code indicates that the controller has shot craps. The controller is located under the shroud beneath the seat by the batteries and it controls all of the power and automatic functions of the scooter. They are damaged most often by water infiltration like running through deep puddles, etc. or by over-amping the scooter by driving it through unstable terrain like sand, mud, wet grass. There's no fix for it but a replacement and it's pricey...several hundred dollars.
Posted on Aug 28, 2009
  • 4 Answers
SOURCE: I have a wheeltech travelease scooter.I can't get
WHERE CAN I BUY CHEAP SPARES ESPECIALLY CIRCUIT BOARDS FOR A TRAVELEASE MOBILITY THREE WHEEL SCOOTER BOB.
Posted on Sep 05, 2009
  • 177 Answers
SOURCE: Scooter moves approx 10 feet then stops led flashe...
Hi. 8 flashes is a fault code for a motor fault. It will be either worn brushes in the motor or faulty connectors to the motor. This fault code means that there is no circuit through the motor. Probably time to overhaul the motor. Most mobility scooters have plugs and sockets that are really to small to carry the amount of current that they do. Because of this, they sometimes fail.Good luck. Neil.
Posted on May 28, 2010
  • 177 Answers
SOURCE: road knight mini, 3 wheel scooter, light flashes o...
Hi. Does the light flash a few times and then pause, and then repeat the flashing ? Count the flashes, it is a fault code. Do you have the fast/slow switch in slow? It might be a speed control fault. How old are the batteries? Might have a faulty motor. Faulty motor or battery leads and connectors. Go for a ride and then check if any of the plugs and sockets feel hot.
  • 692 Answers
SOURCE: scooter battery shows full charge but scooter does
Plamont unfortunately that flash code usually means a controller error. The controller is the brains of your scooter. Take the seat off and remove the rear shroud that covers the batteries and motor/gearbox assembly. Check all the wiring connectors for damage or loose connections. After checking the connectors turn the scooter on and see if you still get 8 flashes.
Did Medicare purchase the scooter? If so they will pay for most of the repair costs. You can contact your provider that sold you the scooter or a repair service Repair Xpress@ 1-877-581-3733 or Roadrunner Mobility @ 1-800-467-2668 Hope this helps you
Posted on Sep 13, 2010
Why do the battery lights remain the same even after use for a couple of hours
hi if u have good batteries & u r driving on flat ground they wont change a lot unless there is a fault .....try driving up a big hill a few times this will test it ..good luck
May 18, 2016 | Pride Victory 4 Wheel Scooter
Was working ok but washed it now it just flashes a red light 8 times and wont go along
8 flash code is typically a controller fault and there are about 12 sub codes that goes along with that flash code. More than likely you will have to replace the controller.
Sep 05, 2014 | Golden Technologies Liteway 3/4 Wheel...
Will not run fault indicator flashes continually without pause
you can check to see if it is in free wheel at the rear of the scooter there shoulb be a lever make sure it is in the lock mode
Jul 20, 2014 | Mercury Prism Coloured Travel Mobility...
Aquasoothe travelite scooter, the batteries are fully charged, the battery gauge is showing full, but the battery light is flashing. It flashes 7 times then pauses, we can't get the machine to move or...
Response to similar query in 2011.
http://www.fixya.com/support/t5751777-aquasoothe_travel_lite_instruction
not my words. The link to the pdf for this is http://www.discovermymobility.com/store/scooters/summit-scooters/elite-portable-scooter/manual.pdf
you want page 22.
Problem Check Point
The driving of the wheelchair is too slow or insufficient, the status
indicator lamp flashes slowly Batteries are exhausted and need to be recharged
1 flash The battery needs charging or there is a bad connection to the battery. Check the connections to the battery or charge batteries.
2 flashes There is a bad connection to the motor.
Check all connections between the motor and the controller.
3 flashes The motor has a short circuit to a battery connection.
4 flashes Freewheel is engaged.
5 flashes Not used.
6 flashes The controller is being inhibited from driving; this may be because the battery charger is connected.
7 flashes A throttle fault is indicated. Make sure that the throttle is in the rest position before switching on the scooter
8 flashes A controller fault is indicated. Make sure the controller connections are secure.
9 flashes The parking brakes have a bad connection. Check the parking brake and motor connections. Make sure the controller connections are secure.
The-Active-Light
does not function,
the Battery/
Status indicator
flashes rapidly.
Count the number
of flashes:
10 flashes
An excessive voltage has been applied
to the controller. This is usually caused
by a poor battery connection. Check the
battery packs and controller
connections.
Sorry wasn't sure how much space they give you for answers. :)
Oct 11, 2013 | Health & Beauty
Mercury prism mobility scooter
The distance a scooter will go depends on the size and weight of the load also. If two people are different height ( wind drag ) and different weight or there is a difference in load you are carrying then there will be a difference in how long the charge will last. Since you switched the batteries with no change then this could be the case. There are other factors that can cause this as well , such as brake dragging, wheel bearings going out, low tire pressure if your tires are air, if 4 wheel scoters then wheel alignment. hope that helps.
Jun 06, 2013 | Health & Beauty
I have a golden companion scooter and it wont move it flashes a green light but i haave no info on where to obtain the trouble codes
The L.E.D. located on the tiller
dashboard will indicate with flash codes what problem is occurring.
L.E.D. Flashes 1 time and pauses, 1 time and pauses…. Batteries are low,
scooter will still operate.
L.E.D. Flashes 2 times and pauses, 2 times and pauses…. Batteries are very
low, scooter will not operate.
L.E.D. Flashes 3 times and pauses, 3 times and pauses….Over voltage to
controller.
L.E.D. Flashes 5 times and pauses, 5 times and pauses….Brake is in the
freewheel position or connection to brake is open.
L.E.D. Flashes 6 times and pauses, 6 times and pauses….Paddle or speed
potentiometer problem.
L.E.D. Flashes 7 times and pauses, 7 times and pauses….Paddle or speed
L.E.D. Flashes 8 times and pauses, 8 times and pauses….Motor
disconnected or faulty.
L.E.D. Flashes 9 times and pauses, 9 times and pause….Controller fault.
I hope this helps they are pretty standard codes I got this from Golden Tech Web Site
Aug 17, 2010 | Golden Technologies Golden CompanioN II -...
Scooter moves approx 10 feet then stops led flashes 8 times then stops
May 21, 2010 | Invacare Supply Group Invacare Lynx Large...
Road knight mini, 3 wheel scooter, light flashes o...
May 18, 2010 | Health & Beauty
My pride IV scooter will not start I get a click
Aug 10, 2009 | Pride Mobility Products Casual CL20KD Lift...
Health & Beauty Logo
444 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
