Question about Kensington KeyFolio Pro 2 Universal Bluetooth Keyboard / Folio Case for 10in Tab
Keyfolio passcode incorrect
Every passcode entered is incorrect. Where can I get a code that works?
How do i set code for paragon safe
INITIAL BATTERY INSTALLATION
1. Remove the key plate cover, insert the key into the keypad and open the door.
2. Remove the battery cover plate located on the inside of the door.
3. Install 4 AA batteries provided and replace the battery cover.
NOTE
: If both the red and green lights are on while the safe is open, this indicates that the batteries are low and need
to be changed.
TO SET UP OR CHANGE A USER CODE
1. With the door open, locate the red button on the back of the door near the hinge.
2. Press the red button and listen for the beep.
3. Immediately enter your new passcode (3-6 digits long)
4. Immediately after entering your new passcode, press the "A" or "B" button on the keypad. Your new user passcode is now stored.
NOTE:
This safe stores up to 2 passcodes (a user code and a manager code). Entering a third code will erase the
first passcode entered.
SETTING UP OR CHANGING A MANAGER PASSCODE
1. Open your safe with the passcode you wish to change and leave the door ajar.
2. Press the "0" button on the keypad twice. Press the red button, listen for a beep and then enter your new user passcode.
New user passcodes may be 3-6 digits long.
3. Immediately after entering your new code, press the "A" or "B" button on the keypad. Your user code is now changed.
OPENING THE SAFE
1. Input your code and then press the "B" button, the green light will turn on.
2. Turn the knob clockwise within 5 seconds to open the door.
3. Each key pressed will be accompanied by a buzzer and a yellow flashing light. If the entered code is invalid the yellow light will
flash and the buzzer will quickly sound, this indicates the code needs to be re-entered.
CAUTION
: Entering the incorrect passcode 3 times will lock the system for 20 seconds.
More information can be found in the attached document web page.
http://www.paragonlockandsafe.com/manuals/mastermanual.pdf
Aug 29, 2014 | Paragon Electronic Digital Safe Jewelry...
Where do i find the keyboard passcode?
Typically when the keyboard is turned on, the device discovers it. Once the device discovers it, you should be able to press connect on the keyboard and the Bluetooth pairing request with the code should pop up on your device. Then you should be able to enter the code on the keyboard, press enter and connect.
May 27, 2014 | Kensington KeyFolio Bluetooth Keyboard and...
How do I connect my Kensington folio via Bluetooth to my iPad 2?
I did not see any other comments, but to address the pairing issue between your Keyboard and iPad.... If your product is the actual KeyFolio Expert Multi-Angle Folio.
The KeyFolio Expert Multi Angle Folio and Keyboard uses a solid plastic frame to attach to the iPad. It's easy enough to slide the iPad in and out of the frame but the design means the case only works with the 4th and 3rd Generation iPad's and is not compatible with the iPad 2 or the original iPad.
Connecting the KeyFolio Expert case to your iPad is a simple process. Simply hold down the power button for over five seconds to put the keyboard into pairing mode and go to the Bluetooth settings menu on your iPad to connect it. Enter the four digit numerical code on your iPad when prompted to finalise the connection.
Pulled from:
Kensington KeyFolio Expert for iPad
If you do not fall under that product, try these steps - they shuold be the same for most of Kensington's Products:
Connecting the Bluetooth keyboard to your iPad is a simple process. Simply turn it on, press the connect button in the top right corner of the keyboard and go to the Bluetooth settings menu on your iPad to connect it. The iPad will prompt you to enter a four digit code using the keyboard to finalise the connection. (the code should be 0000)
Pulled from:
Kensington KeyFolio Pro 2 for iPad
Let me know the outcome.
Jason
May 05, 2014 | Kensington Folio Case Stand for iPad,...
Passcode
I don't know what passcode is and I don't know where to activat
Apr 25, 2013 | Kensington KeyFolio Pro 2 Universal...
My phone says PUK blocked and only lets me do emergency calls and you cant type in the code anymore
PUK stands for Personal Unblocking Key. This is a uniqueeight-digit code specific to your SIM card. This is required when the PINnumber to unlock your mobile phone is entered incorrectly 3 times. You are thengiven 10 attempts to enter your PUK code. If an incorrect PUK code is enteredafter the 10th attempt, you will block your SIM card permanently and willrequire a new SIM card from your mobile phone provider.
PUK codes can be obtained through the following ways -The PUK code is in your SIM card documentation Starter Pack.If you do not have this then -Please contact your phone service provider.
Your cell phone service provider can give you the PUK code once you give themyour account details and they have confirmed your identity.For details to obtain the PUK code for the SIM card, pleaseclick on this link and follow my instructions.
http://www.fixya.com/support/r5705889-puk_code
Apr 24, 2012 | Cell Phones
Security code airtel
For 5 consecutive incorrect passcodes, you will be prompted that you have entered incorrect password 5 times and need to wait for couple of minutes. You really have to wait, after waiting you can enter the default code 12345 then it should be working fine then. If in case that this won't work, you can try to hard reset phone by entering *#7370# and you will need to select yes for restoring to factory defaults. Remember that it will delete the settings and data saved in the phone not on the memory card but it will still be advisable for you to have a back up of everything before doing so.
Dec 09, 2011 | LG KG110 Cellular Phone
What is my PUK code?
Dec 09, 2011 | AT&T Cell Phones
1100 security code unlock
Thank you for choosing www.fixya.com
Nov 15, 2011 | Nokia 1100
How to open nokia 7230 keypad security code
Sep 12, 2011 | Nokia 7230 Cell Phone
My xbox 360 has a passcode that have been set but i do not set the passcode.
From the System area of the Xbox Dashboard, select Family Settings, Console Controls.
Enter an incorrect pass code.
You will be told that your pass code is incorrect. Select Reset pass code.
You will then be shown your pass-code question and asked to answer it.
Type your answer using the on-screen virtual keyboard and either your Xbox 360 controller or a standard USB computer keyboard plugged into a controller port on your console. Your answer is case-sensitive and must be typed exactly as you entered it originally. This will clear your original pass code and allow you to enter another.
Repeat the Set a Family Settings Pass Code procedure, beginning with step 2.
If you've forgotten the answer to your pass-code reset question as well as your pass code, please call Xbox Customer Support at 1-800-4-MY-XBOX (1-800-469-9269).
Jun 12, 2011 | Microsoft Xbox 360 Console
Kensington KeyFolio Pro 2 Universal Bluetooth Keyboard / Folio Case for 10in Tab Logo
Top Kensington Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Kensington Audio Player and Recorder Expert? Answer questions, earn points and help others
