Question about Zebra TLP 3842 Thermal Label Printer
Problem Printing Barcode labels on Zebra TLP 3842
I have a C# application (.NET 3.5 SP1) that I am printing serial numbers for product for a manufacturing company. I am using Active Reports 3 (ver. 5.2.385.2) to print these labels. However, when the printer(Zebra TLP 3842) has an issue, it seems like the printer queue reprints the print job. This causes duplicate serial numbers to be printed. Does anyone know how to ensure that this will not happen. I would rather not have a serial number print than have duplicate serial numbers.
4 Suggested Answers
SOURCE: improper printing of barcodes
recalibrate the label length in the printer(hold feed and power up). from memory bar-one uses the label settings from windows, so go into printers and faxes under control panel and correct the label size
Posted on Nov 09, 2007
  • 45 Answers
SOURCE: Zebra TLp 2844 (printer not connected error message )
Go to Control Panel, Administrative Tools (in Clasic view), and double click on Services. Scroll down and right-click on "Print Spooler". Start (or Restart) it and your printers will reappear in the "Printers and Faxes" window, and the spooler will try to send jobs to the printers again.
If you check the Properties of the Print Spooler, on the Recovery tab, you can set it to "Restart the Service". I set mine to Restart on the First Failure and Second Failure, and Take No Action on the Third Failure, in case something really needs attention.
Posted on Sep 23, 2008
bartech9
  • 155 Answers
SOURCE: Labels not printing properly
El problema es que la impresora tiene diferentes parametros de impresion, de oscuridad o velocidad. Ajustalos para que sean iguales en el print server como en workstation. The problem is that the printer has different printing parameters, or speed or darkness. Adjust to be equal in the print server as workstation.
Posted on Jun 04, 2009
How do I stop my printer from skipping a blank row of labels in between each row I print?
I was using LibreOffice Writer to print terminal block labels on my TDP43MY and was having all kinds of problems. (I tried EasyMark too, but had just as many problems.) The printer was constantly switching landscape and portrait modes on me. It would print 2 sets of good labels (portrait) and then the next label would be landscape. It did this no matter if I printed one page at a time or if I printed the whole document. I spent over half a day trying to get it to work, and finally succeeded - read on.
No surprise that the Panduit TDP43MY printer is really a Zebra printer. I discovered this by accident when I first got the printer. I connected it without first installing the driver and windows asked for a driver for a Zebra printer. Knowing it was a Panduit, I rejected windows offer and installed the Panduit driver. I spent a whole day trying to get it to print correctly and decided I would try windows recommendation of a Zebra driver. I did some digging and discovered it is a Zebra TLP 3842 printer. I removed the Panduit driver and installed the Zebra TLP 3842 driver. The version I have says "Windows driver for ZDesigner TLP 3842 Version 5.1.07.6290 Copyright 2016". I then used LibreOffice Writer to print my labels again. Wonder of wonders it printed with ZERO problems! Yeah for Zebra!
May 06, 2014 | Panduit TDP43MY Thermal Label Printer
Zebra TLP 3842 isn't printing
Step 1:Firstly, restart the computer and check the print queue.
After the computer restarts, double-click the printer icon in the lower right corner (the notification area) of the computer. The print queue opens.
If theprint jobs remain in the print queue,continue to the next step
Step 2: Run theFixitavailable in the link below:
Troubleshoot-printer-problems
http://windows.microsoft.com/en-US/windows-vista/Troubleshoot-printer-problems
Step 3: Make sure the printer is not paused or offline.
1. On the print queue menu bar, clickPrinter, and then look for thePause PrintingandUse Printer Offlineitems in the menu.
2. Make sure that there is no check mark next to either item. If a check mark displays next to either item, click to clear it.
Change-your-default-printer
http://windows.microsoft.com/en-us/windows-vista/Change-your-default-printer
Step 4:Run the fixit available in the link below to restart the Print Spooler service.
Fix printing problems by resetting the print spooler
http://support.microsoft.com/kb/2000007
You may try to add the printer locally and test
Add-or-remove-a-printer
http://windows.microsoft.com/en-us/windows-vista/Add-or-remove-a-printer
Mar 06, 2014 | Zebra TLP 3842 Thermal Label Printer
Hi, I am having Zebra TLP 2844 barcode printer.I have installed the printer in my machine. I have tried to take barcode labels.From application, for each and every label i need to generate the label in PDF...
The TLP2844 can print from any windows application providing the application can use a windows printer driver.
The page size oof the .pdf needs to be the same size as the physical label size.
Nov 03, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Jun 03, 2009 | Zebra Eltron TLP 2844 Thermal Label...
I have Thermal Zebra Printer TLP2824, I have installed it and
download.....http://www.barcodesinc.com/free-barcode-font/
free barcode font for programs. copy into c:/windows/fonts
it will install into that folder, and just select that font in VB6 application before printing
May 27, 2009 | Zebra TLP 2844-Z Thermal Label Printer
Zebra LP2844-Z - no longer prints a barcode on a specimen label
Added ''3 of 9' font to C:/Windows/Fonts.
Opened Word document, selected 3 of 9 as Font and typed a word.
Went back to printer and it printer the accession number and barcode.
Mar 27, 2009 | Zebra LP 2844-Z Thermal Label Printer
Zebra TLP2844 does not print the barcode label
Can you print the barcode using the software that come with the printer. Zebra TLP2844 come with basic Designer software. Test whether it's printing the barcode or not.
IF it prints the barcode via its software, then you might be having barcode font problem between your application/os and the printer.
May 21, 2008 | Zebra Eltron TLP 2844 Thermal Label...
Printing quality TLP3842
clean the printhead, if no better replace it
May 15, 2008 | Zebra TLP 3842 Thermal Label Printer
Improper printing of barcodes
May 25, 2007 | Zebra TLP 2844-Z Thermal Label Printer
Zebra TLP 3842 Thermal Label Printer Logo
348 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
