Replacing thermostat: tstatccshp01 with th8320u1008
I'm trying to replace a Carrier thermostat tstatccshp01 with the Honeywell thermostat th8320u1008. The carrier has six wires: Y, C, R, G, W & O. None of the wiring diagrams included with the Honeywell install guide match this combo. My system is a heat pump/air condition model 38EYG. The Honeywell thermostat provides the following connections: Y2, L, E, AUX, S1, S2, RC & R (jumper connected), O/B, Y, G & C. If I connect Y to Y, C to C, R to RC & R (jumper connected), G to G then I am left with O & W from the carrier. Which Honeywell terminals would I connect these two wires to? Any help would be really appreciated!
  • ivanejackson Jan 22, 2009
    That worked perfectly! Thank you so much for your help!!!
    Scholar:
  • 144 Answers
Hook up o to o/b, then in the installation programming set the change over valve to energize in cool. Then hook up w to aux. Good luck.
Posted on Jan 21, 2009
The functions seem to be frozen. what do I do?
Try removing power to the thermostat including the batteries for 20 seconds and see if that solves the problem.
Sep 24, 2014 | Honeywell Th8320u1008 Visionpro Digital...
I have a Carrier Weathermaker SX HVAC unit with a Honeywell thermostat. Even if the thermostat is turned "off", my fan keeps blowing!
Hello, usually this is a sign of a bad blower relay on the intergrated control board. The only option is to replace the control board.
May 09, 2012 | Heating & Cooling
My honewell th8320 is reading error 126 or 626
Look in the manual that came with the thermostat it will give you the problem for each code.
Nov 11, 2009 | Honeywell Electronic Programmable...
My Model TH8320U1008 touchscreen not working. I have replaced the batteries, still doesn't work. Is there a way to reset it?
I dont think its your thermostat. The 8000 pro series is relatively new. I think is you furnace you lost 24 Volt power. Check the furnace out first. www.fastacservice.com
Oct 18, 2009 | Honeywell Electronic Programmable...
I REPLACED BATTERIES ON MODEL # TH8320U1008 THERMOSTAT, AND AM WONDERING IF I NEED TO SOMEHOW RESET SOMETHING TO GET THE A/C UNIT TO TURN ON. I GET A CLICK SOUND AS IF THE AC WILL TURN ON, BUT IT DOESN'T....
Go to instuctions and find procedure to go to Advanced Settings. I think it is #170 to identfy the system you have if heat pump go to 190 and set to A/C Mode 0
Jun 27, 2009 | Honeywell Electronic Programmable...
Replace Carrier tstatccshp01 builders standard thermostat with Honeywell rth7500 series and wiring not matching Does O wire go to Aux..? fan working but no cool air.
No... Aux. is auxiliary heat strip. This is usually a white or black wire its up to the choice of the installers preferance. O or orange wire. is used to the reversing valve on a heat pump. If you do have a heat pump there is a programing section inside the Honeywell t-stat. which should say heat pump or straight cool, then another section that will ask if you want the reversing valve to energize in heat or cool. most Heat Pump brands energize in cool the exception is Rheem and Ruud they energize in heat.
May 17, 2008 | Honeywell Heating & Cooling
Wiring a Honeywell VisionPRO TH8320U1008 Thermostat
the thermostat will to any temperature but will not shut off
Nov 25, 2007 | Honeywell CT3600 7 Day Electronic...
Heating & Cooling Logo
819 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
