Question about Sony CLIE PEG-T615C Handheld
No Power My clie just quit working and wouldn't even charge. I bought a new battery and still the same problem. I checked my chargers (I have 3) and still have the same problem. Help!
Push in the reset button on the back of the unit. Use the head of the stylis
Posted on Jun 24, 2008
SOURCE:
Charging 2006 trailblazer, dvd started working
The charger puts out about 14 volts, The battery is 12.6 fulley charged. If battery is bad or dirty battery cables the voltage will be to low
Dec 31, 2011 | Panasonic Televison & Video
A Sony Clie PEG-N610C has been in storage for years(it appears unused). Neither the AC charger or the cradle charger will make the charge indicater light respond. It is completely dead in all respects. Can...
Since the battery is within the unit it can leak or go BELOW the threshold level of the cell wherein the charger will not work to charge the unit. However if you can confirm the battery voltage to be below, use a multimeter to check, then before replacing use a JUMP START with an external limiter DC bench supply , you can use a series resisitor of about 47 ohms with a 6-9 VDC.
If the battery takes up voltage the see if the charger will respond and the set will power.
Sep 30, 2011 | Sony CLIE PEG-N610C Handheld
Bought a Nikon Coolpix S3000 (orange) for my daughter after Christmas. It just stopped working one day; wouldn't charge, no lights or come on. The battery it came with is a Nikon lithium ION Battery...
Read page 16 of the manual. Do not use any other charger with this camera. Are you sure you have the battery inserted correctly? When trying to charge, does the green light blink? If so, when it stops blinking and turns off, the battery should be fully charged. Do not attempt to turn the camera on while the charger is trying to charge the battery.
Aug 17, 2011 | Nikon Coolpix S3000 Digital Camera
Inspiron 1501 charging problem
should find out why the original charger stopped working in the first place... was it a faulty mother board really. anyway if the ratings on the charger you bought are for that laptop indeed, then it should power up the laptop minus the battery. ofcourse if you put in charger minus battery, dont expect it to show the charging led..just try to power it on
Regards
Feb 26, 2010 | Dell Inspiron 1501 Notebook
Can get it to chanrge (this is brand new)
remove the back cover and make sure the battery is inserted properly
Jan 10, 2009 | T-Mobile Sidekick® 3 Cellular Phone
Samsung D900i
It is probably the charging port. It seems to be a common issue with this model of phone.
If it is the charger port on th eD900, You have 3 options.
1. get it repaired, under warranty if possible
2. Get a new one
3.Get an external battery charger and charge battery separate from phone.Another battery and charger will set you back about 10 dollars on ebay
For more information and links to the parts check the following link below.
Samsung SGH-D900 will not charge problem
Aug 29, 2008 | Samsung D900i Cell Phone
My sidekick wont work
It seems your charger port is broken, it hapfens often on cellphones, wear and tear. Check to see if its under warranty, and it can be replaced. Check my profile if you need more help.
Jan 24, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Clie PEG-SJ22 does not charge battery
Have you tried resetting the unit? There's a little button on the back that you can press in with a paper clip. That'll cause the unit to reset (you won't lose data) and then you might be good for charging.
Dec 16, 2007 | Sony CLIE PEG-SJ22 Handheld
Sony Clie sj33 battery
If you haven't already done so. Try resetting PDA in back, if that doesn't work go back to battery and verify connections are correct and check connection wires (they may be frayed or damaged). I'm not sure that will solve the problem, but it worths a shot.
Sep 19, 2005 | Sony CLIE PEG-SJ33 Handheld
Sony CLIE PEG-T615C Handheld Logo
71 people viewed this question
Top Sony Computers & Internet Experts
Ekse
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
