Question about Maytag Neptune MAH5500B Front Load Washer
What pedistal can be used with 40272900 - Maytag Neptune MAH5500B Front Load Washer
My washing mAchine is broken?
code le = thermal overload protection
let washer stand for 30 minutes then restart
if code persist call for service
page 28 user manual
Sep 27, 2015 | Kenmore Washing Machines
Front loading washing machine get "dE" error when we try to turn it on. Door will not lock so the washer won't run. Kenmore model 40272900.
Is this an HE2 or a HE3 model? I don't get any results on that model number. Is there any numbers before the 40272900?
Nov 10, 2012 | Washing Machines
2005 Chevy Equinox 3.4 Liter engine. Do I need to shim under the rocker arm pedistals after taking .003" off the head.
No that is an acceptable loss of clearance, it will be absorbed by the hydraulic followers.
Oct 29, 2012 | Cars & Trucks
I have a Toshaba 3HL 67U I can-not get the pedistal stand off it. Can you help me please. I want to hang this tv on the wall.
Don't know why u have that much problems to take out the tv pedistal stand off it.Just check make sure u take out all the screws around tv back of the pedistal,make sure u take it all out.Used one hand hold the tv bazel frame tight and the other hand and jusy wiggle and push it in the pedistal and put it out.The pedistal should came right out.
Jul 31, 2011 | Toshiba REGZA 47HL167 TV
Does a pedestal for the 2005 LG WM2277HW fit the newer models of LG Front loaders?
Yes, it can be used, but the fastening system for pedistal to washer is much better with the new pedistals.
Jan 25, 2011 | LG WM-2277HW Front Load Washer
I need pedsteal brackets for my Lg washer
the side brackets/screws/manual should've been included. some of the new pedistals no longer use side brackets though. contact lg with pedistal model# located in drawer and research further.
May 07, 2009 | LG WM-2277HW Front Load Washer
Washer is off balance for a kenmore elite quietpak he4t How do you level washer?
adj all 4 feet all the way in..try to rock washer adj front feet as need to give washer as solid footing as possible tighten lock nut in top position against washer bottom ..adj only as much as need ..the further out the feet are the more likely the washer is to vibrate ..a weak floor is the biggest reason washers vibrate ..if washer is on a pedistal be sure the for screws holding pedistal to washer are tight adj pedistal legs same as washer feet so bottom of pedistal is as close to floor as possible
Sep 19, 2008 | Washing Machines
We just installed a new whirlpool front loading duiet sport washer and dryer , It keeps going off balance it was installed by the store . we have had the service man out twice now , he is no help at all....
floor may not be as solid as you think.remove pedistal drawers make sure the screws holding pedistal to washer are tight 2 front and 2 back going into bottom of washer frame next adj legs so bottom of pedistal is as close to the floor as possible you may have to lossen the lock nuts to do this next try rocking the unit by hand and adj front legs as needed to stop motion and and give washer a solid feel retighten lock nuts up to bottom of pedistal
May 05, 2008 | Washing Machines
Maytag Neptune MAH5500B Front Load Washer Logo
53 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
