Question about Sony Ericsson W380i Cellular Phone
Sony ericcson w380i not switching on
My mobile wont switch on felt hot for a while so not sure if battery gone or?
  • beth_ei Jan 31, 2009
    My w380i mobile has a blank screen it switches on but goes no further, it had been switching itself of for no reason and then took a long time to start up now it just has a blanl screen.
    I noticed this only started when I started to use the walkman
Batterys probaily short ciricuiting on the system, thats why it's gettin' hot , so remove it and check to see if the metal bits look like this like this II I II and replace it , if still not working contact a w380i boffin .
Posted on Feb 16, 2009
Battry is lasting only for 2 to 3 hours..phone gets hanged and it gets hot...i'l b glad if any one helps me out ..:)
hi the problem may be because of two reasons fist check that the battery of ur cell has been used for more than one or two years generally u should try replacing ur battery after 1&1/2 years of ur use if not the electrolytes in the cell will be used up and ur cell not not be charged for more than one year if it has not been more than one year then check the pin of ur mobile for any rust marks of any sort of dust take a piece if clean cloth and take a small pinch of solution(e.x. colin,etc) and wipe the pin thoroughly with the cloth then try connecting ur charger and see whether the battery lasts long or not if the problem still persists contact ur sony ericcson service centre for help was this useful if yes pls rate my solution or provide ur problem in brief to get a more clear solution
with warm regards- bonefirediv.
Apr 04, 2011 | Sony Ericsson W380i Cellular Phone
The external display of my sony ericsson w380i no longer switches itself off. A full battery now only lasts about 24 hours. Is there a fix for this
Remove battery off for few hours and reset it , if the fault does not clear remove memory card and check for errors or virus in the card.
If the phone reboots to actual settings then format card after removing files and reinstalling with safe files.
if no result then the software needs to be reloaded.
Sep 30, 2010 | Sony Ericsson W380i Cellular Phone
K770i won't switch on
remove the battary, place it agn, press little hard the switch on button
Jan 03, 2010 | Sony Cell Phones
I have a sony ericcson W380i and it now will only light up when I switch on and then nothing else happens - so the battery is OK but no function is working. It was fine last night but not when I went to...
Hi.
That means that the phone is not comleting the initial phone test, and not booting.
Remove also memory card.
Check the connector at the base of the phone, where you plug in the charger. Ensure that it is clean , and that there is nothing that can make contact in there (eg. oxide). If you need to clean the connector, remove the battery first.
Try holding the phone start button on top for about ten seconds.
Go to a shop and ask them to test a spare battery, or if you have a spare battery, test it. A shorted battery can cause the phone not starting.
If it is none of the above, then it is a faulty board. Also a short inside the phone or a faulty switch can cause the phone not starting. In that case the phone must be disassembled and repaired.
Regards.
Oct 23, 2009 | Ericsson Lands Phones
Why do I keep getting a flashing red light when I attempt to switch on my Sony Ericcson K770i?
Welll There is two reasons either you have dropped it recently or your battery does not work and or its not holding a charge..?
Sep 22, 2009 | Sony Ericsson K770i Purple 3G Camera...
W380i vibration problem
The vibration is performed by a small motor in your mobile.. please check it out it... i think its gone.. It will be in back side of your mobile... near battery..
May 29, 2009 | Sony Ericsson W380i Cellular Phone
My sony ericsson w380i keeps frezzing and won't turn on???
download sony ericcson update service from sony ericsson website and follow instructions on their website
May 05, 2009 | Sony Ericsson W380i Cellular Phone
I cant get sony ericcson videos converter to convert into.DCF format
Just try Wondershare Video Conveter Platinum, which could convert video files fit for your sony ericcson and other portable player like iPod, iPhone ect.
Here is the torurial about how to use it
Apr 24, 2009 | Sony Ericsson W380i Cellular Phone
Sony errocson w380i dead
Most probably your phone needs to be reflashed. Try this link and see if it will recognize your phone and reflash it for you. Otherwise only option is to have it flashed by a repair dealer
Mar 14, 2009 | Sony Ericsson Cell Phones
Network problemin Sony Ericsson W380i where as the same SIM card in NOkia works fine
It is better to replace your phone with new one as you have bought recently. contact your retailer.
Oct 29, 2008 | Sony Ericsson W380i Cellular Phone
Sony Ericsson W380i Cellular Phone Logo
157 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
