Question about Invicta Reserve Subaqua Venom Swiss Quartz Sunray Dial Strap Watch for Men
Setting a 6206
Setting the alarm function on model 6206
  • Clive Arnold
    Clive Arnold Jan 13, 2013
    No this was not helpful.Wrong watch! the answer I require is how do you set Invicta model 6206.
  • Invicta Master
  • 18,409 Answers
How do I set the alarm on model wau111a tag watch
  • Pull out the crown to the alarm setting position. The crown is located on the right side of the face of the watch. Pull the crown out until "AL", the alarm indicator, is shown on the watch. Depending upon the model of your Tag Heuer Aquaracer watch, you will either pull the crown out in the first or second position.
  • Select the hours and minuets for the alarm. Once your watch is in the alarm setting position, press the bottom right button on your watch. This will enable you to select the hours and minuets that you want to set the alarm for.
  • Set your alarm. To begin setting your alarm turn the crown clockwise until the desired hour or minutes are displayed on your Tag Heuer Aquaracer watch. If you happen to accidentally pass the alarm time, turn the crown counter-clockwise the get back to the desired alarm time.
  • Save your alarm. When you are ready to save your alarm, simply push in the crown. Once your alarm sounds, to silence it press any button on your Tag Heuer Aquaracer watch.
  • Nov 06, 2014 | Tag Heuer Link Watches
    Set date on 1440 sports watch 504-t5k085
    My watch has model number 504-tsk085, labeled Timex 1440 Sports, and Timex provides the incorrect manual for it online. I wrote these instructions after careful experiment:
    Upper left button: press to switch to a stopwatch, or...
    Press and hold to enter alarm setting mode. Once flashing press again to enter time/date setting mode.
    -- you can only do one or the other without exiting the setting
    mode (time or alarm set).
    - within the setting mode you use the two right side buttons
    in obvious ways to set times/dates
    Exit setting mode by pressing upper left again
    Lower left button: light
    Upper right button (when not setting time): reveal date while pressed
    Lower right button (when not setting time): reveal alarm time while pressed.
    ALSO: WHILE lower right button is pressed you can change alarm
    on/off and chime on/off through the four possible settings by
    secondarily pressing the upper right button repeatedly.
    Mar 01, 2012 | Timex 1440 Nylon watch
    Alarm setting I want to set an alarm to repeat daily as a alarm clock would for a g shock
    casio gshock...Setting the TimeG-Shock watches feature a digital display that is set using the function buttons on the outside of the watch face. To set the time, press and hold the the upper left ...">casio gshock...Setting the TimeG-Shock watches feature a digital display that is set using the function buttons on the outside of the watch face. ...
    Mar 10, 2011 | Casio Watches
    Cant set it
      Setting the Time
    1. G-Shock watches feature a digital display that is set using the function buttons on the outside of the watch face. To set the time, press and hold the the upper left button until the seconds unit blinks on the display. Reset the seconds to "00" by pressing the lower right button.
      Push the lower left button to switch to the hours unit, which will start blinking. Advance the hour by pressing the lower right button. If you hold down the lower right button, it will advance the hour unit at a higher rate of speed. Once the hour is set, press the lower left button to switch to the minutes unit. As with the hours unit, pressing the lower right button will advance the minutes and holding it down will advance the minutes rapidly.
      Once the time is set, press the upper left button to save the setting.
    2. Backlight
    3. The backlight on a G-Shock watch has a manual control and an automatic function that will light the face of the watch whenever the alarm, countdown alarm or hourly alarm ring. To use the manual backlight, press the button on the bottom of timepiece. The light will glow for approximately 2 seconds before going out.
      The automatic function is set by pressing and holding the lower right button. When the automatic function is set, an indicator icon will display on the watch face above the seconds unit. You can turn off the automatic backlight function by pressing and holding the lower right button until the icon disappears.
      Note that backlight causes a drain on the battery, and overuse of the backlight will greatly reduce battery life.
    4. Setting the Alarm
    5. The G-Shock has an alarm that emits an audible tone for approximately 20 seconds when it turns on. To set the alarm, press the lower left button until "AL" displays in the upper left corner of the timepiece. Press and hold the upper left button until the hours unit starts to blink. Adjust the hour by pressing the lower right button. As when setting the time, you can advance the hour at a higher rate of speed by holding down the lower right button.
      Once the hour unit is set, press the lower left button to advance to the minutes. Use the lower right button to set the minutes. Follow these same instructions to set the month and day you want the alarm set.
      When the alarm time and date are entered, press the upper left button to save the setting. Push the lower left button three times to return the G-Shock to "Timekeeping" mode.
    Aug 19, 2010 | Casio G-Shock G 520D 4AVDR Cockpit Series...
    I cant figure out how to work it my casio gshock
      Setting the Time
    2. Backlight
    Aug 14, 2010 | Casio Watches
    Can't set time on aqualite watch-field ranger
    I have an aqualite field ranger watch too. I lost the information but I found another notice for another watch and I was able to set the TIME as well as the alarm. I am not despairing as to one day set the date correctly! ;-)
    The instructions I found are for "LIFELONG Chrono Alarm Sport watch" from Hanig & Company. The watch this particular instructions comes from has a rectangle LCD display that only takes the center of the dial, and only 3 buttons for the functions.
    Aqualite has 4 buttons, but one of them is only for lighting the dial only, therefore if we use the 3 other buttons the same way they are described in this manual, it will work.
    Aqualite has 4 buttons:
    1) top right (we will call it S1 like this manual does)
    2) bottom right (this will be S2)
    3) bottom left (this will be S3)
    As I said the number 4) (top left) is only for light and we will forget it since it is not needed to set our watch.
    Setting the minutes, hour, date month and day:
    Press S3 3 times, or until the following are flashing in the display : TU and seconds
    Set the minute: press S2 once and advance by pressing S1
    Set the hour: press S2 and advance by pressing S1
    Choose from AM (A), PM (P) or military time (H)
    Set the date: Press S2 and advance by pressing S1
    Set the month: Press S2 and advance by pressing S1
    Set the day Press S2 and advance by pressing S1
    Press S3 to bring you to the time display
    Setting the chronograph:
    The chronograph feature will store and add to the last recorded time interval up to 23 hours, 59 minutes and 59 seconds in the time display.
    1. Press S3 (flashing in the display: SU, FR, SA)
    2. Press S1 to begin. Press S1 to stop.
    3. press S3 to return to the time display.
    Setting the lap time:
    The lap feature will record from 1/100th of a second up to 23 hours, 59 minutes and 59 seconds.
    In the time display.
    1. Press S3 (flashing in the display: SU, FR. SA)
    2. Press S2 to clear setting
    3. Press S1 to begin. Press S2 to stop.
    4. Press S1 once and S2 twice to reset.
    5. Press S3 to return to the time display.
    Setting the alarm and snooze:
    The time alarm features with a convenient snooze function which will sound 5 minutes after the first alarm in the time display.
    1. Press S3 twice for the alarm mode (hour will be flashing): advance by pressing S1
    2. Press S2 once (minute will be flashing)
    3. Press S3 to set alarm and return to time display
    3. Press S1 to deactivate alarm
    5. After 5 minutes, snooze alarm will ring. Pres S2 to deactivate.
    6. Press S1 and S2 at the same time to deactivate the alarm at any time.
    To test alarm
    In the time display
    1. press S1 and S2 simultaneously for alarm test.
    Hourly chime
    Your chrono alarm sport watch ha the option of an hourly chime in the time display.
    1 Press S2 and then press S3 to activate hourly chime
    2. Repeat process to deactivate
    Jul 23, 2009 | Watches
    DECADE WATCH HAS NO SETTINGS MANUAL
    If your Decade watch is like mine it has 4 push buttons (10, 2, 4 and 8 "o'clock" positions respectively; and one pull and turn stem (at 3 o'clock position) -
    For the purpose of setting the watch and functions mentally label the push buttons as follows:
    10 o'clock position "A"
    8 o'clock position "B"
    2 o'clock position "C"
    4 o'clock position "D"
    NORMAL TIME SETTING
    1) In normal time readout press B (3x) to get to normal time setting mode: "SEC" will start flashing, press C for synchronization
    2) Press D once: "MIN" will be flashing, press C to advance
    3) Press D once: "HOUR" will be flashing, press C to advance ("A" is for am, "P" is for pm, "H" is for 24 Hour format)
    4) Press D once: "DATE" should be flashing, press C to advance
    5) Press D once: "MONTH" should be flashing, press C to advance
    6) Press D once: "DAY OF WEEK" should be flashing, press C to advance
    7) Press B once: Setting is completed, return to normal time readout
    ALARM TIMES SETTING
    1) In normal time readout press B (2x): Alarm time "HOUR" should be flashing, press C to advance
    2) Press D once: Alarm time "MIN" should be flashing, press C to advance
    3) Press B once: Setting is completed, return to normal time readout
    ALARM FUNCTION
    1) In normal time readout press C and D simultaneously: Alarm signal should appear
    2) In normal time readout disarm alarm by pressing C and D simultaneously: alarm signal should disappear
    Note: Alarm (when activated) will stop itself after 1 minute; or can be silenced by pressing D or press C to snooze for 5 minutes (operates for 1 hour)
    CHIME
    1) In normal time readout press D and B simultaneously: Chime signal should appear
    2) In normal time readout disarm chime by pressing C and D simultaneously: alarm signal should disappear
    CHRONOGRAPH (STOP WATCH FUNCTION)
    1) In normal time readout press B once to get into "CHRONO" mode: press C for to start counting event -
    While in Chrono mode there are two options
    a) During a counting event: press C to stop counting, press D to clear and reset stopwatch to 0:00
    b) During a counting event: press D to see a "split" time (IE first leg of a relay time is shown while the counting event continues, press D again to return to running counting event; press C at end of event, press D to reset stopwatch to 0:00
    2) press B to return to normal time mode
    Mar 27, 2009 | JCPenney Watches
    Old model timex compact disc digital audio
    Hi catlady05,
    To set the digital time and date on your Timex Ironman, please follow the steps below.
    1. press and hold the "set" button for two seconds.
    2. Use the "advance" button to reach the correct hour.
    3. Press the "mode" button, followed by the "advance" button to set the minutes on your Timex Ironman.
    4. Repeat the procedure of pressing the "mode" and "advance" buttons to set the month, date, year and day of week.
    5. When you are finished setting the time and date, press the "set" button to save.
    Setting an Alarm
    1. Begin by pressing the "mode" button until the alarm screen appears.
    2. Press the "set" button and use the "advance" button to set the hour for your alarm.
    3. Repeat the same procedure to set minutes and seconds for your alarm.
    4. When you have finished setting the alarm, press the "set" button, followed by "advance" save and activate your alarm.
    5. When you alarm sounds, you can deactivate it by pressing any button on the watch.
    Hope it helps.
    Thank you for using FixYa.
    Oct 29, 2007 | Timex Ironman 53151 Wrist Watch
    Invicta Reserve Subaqua Venom Swiss Quartz Sunray Dial Strap Watch for Men Logo
    82 people viewed this question
    Top Invicta Watches Experts
    Ansel Alberto
    Ansel Alberto
    Jimmy Accardi
    Are you an Invicta Watch Expert? Answer questions, earn points and help others
