Question about Sony VAIO VGN-N385E/W Notebook
Diassembly of notebook
Sony VAIO® VGN-N385E PC Notebook
there seems to be one screw under the keyboard holding the top panel and I can´t see it unlees it´s possible to remove the keyboard fro the top panel
  • kt76 Jan 21, 2009
    I´ve uscrewed all the screws from the back of the laptop, there are no screws marked with a keyboard sign, all the screws are marked with an arrow.
    The reason I´m disassembling it is because I need to change the video inverter, It´s not under warranty any more.
  • Daniel Florin
    Daniel Florin May 11, 2010
    Why do you want to diassembly the notebook ?
    if is under the guaranti you wil lose the guaranti , anyway to take out the ketboard you need to unscrew the 2 screw from the back of the laptop wich keep the keyboard the sign of the keyboard is beside of each screw after that you can take out the keyboard.
Won't turn on,, battery is always blinking . some help please..
Quit the battery, your notebook now (if is ok) must be start without troubles.replace the battery(maybe in short circuit)
Sep 27, 2013 | Sony for SONY VAIO VGN-N37GH/B VGN-N385E/W...
Replace the keyboard in my sony vaio vgn-nw265f
you may need service manual.
if you need contact me
servicemanualboy@gmail.com
Jan 06, 2012 | Sony VAIO VGN-NW265F/B Notebook
I need to know how to replace the keyboard on my Sony Vaio VGN-N320E. Can't seem to find the springs to unlatch the keyboard
You can't replace the keyboard of the laptop by yourself. Take a help from expert engineers or Service center experts.
Revert back for more assistance.
Feb 02, 2010 | Sony VAIO VGN-N320E Notebook
Seem to be a screw in the case under keyboard how
with the laptop over on its back you will see two screw holes seperated apart by a couple inches right in the middle of the case. These screw holes are in the middle of two recesses molded into the case bottom. The screw on the right is the screw that releases the keyboard. Once this screw is removed, the only other thing holding the laptop keyboard is the 5 retaining tabs along the bottom of the keyboard. Release these and rotate the keyboard up and release the cable from the motherboard.
Jan 18, 2010 | Sony VAIO VGN-N320E Notebook
Remove and inspect non working keyboard VGN-T37GP
Sony makes getting a keyboard off it laptop like trying to launch a shuttle craft. Take the three screws out on the bottom, Push in the two detent tabs at the top of the keyboard, the hold it in place when on the palmrest. They are located at F5 and Num Lock keys. Now take a thin skewer or wire and push through where the screws were, this will release the keyboard. Now slide the keyboard toward the screen and that releases the lower detents that hold it at the lower part of the palmrest....nor unplug the cable and you are good to go. Oh, by the way below is the link to the service manual for your laptop....it has it fully illustrated.....
http://tim.id.au/laptops/sony/vgn-t.pdf
Oct 19, 2009 | Sony VAIO VGN-T370P/L Notebook
How to open case on VAIO VGN-TX670P
under the keyboard there is a screw. you have to open the keyboard, there is a lock near the speaker, you will neat a very thin flathead screw driver. near the key F1 F5 F12 and insert. open that and you see what i mean
Mar 26, 2009 | Sony VAIO® VGN-TX670PB PC Notebook
How do I replace asony vaio PCG 7v2l keyboard
ou must first take off the top plate where the buttons are. Start from the right side and work your way over, the there shouild be 3 screws holding the keyboard down. Once the screws are out slide keyboard up and disconnected the connectors on the botton.
Mar 21, 2009 | Sony VAIO VGN-N250N/B Notebook
Need driver and application software of sony vaio vgn-cs60b..
Hi!
I hope the following address will reveal all www.cnet.com it is where I get all my FREE downloads,software and drivers.
Please press that blue button when sorted!
Paul 'W' U.K.
Jan 28, 2009 | Sony VAIO VGN-N250N/B Notebook
Sony VAIO VGN-N385E/W Notebook Logo
109 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
