Question about Frigidaire GLTF2940ES Front Load Washer
E 11 Cose on a GLTS2940ES3 Frigidaire Front load washer
Apparently an E 11 code has to do with the water pressure and length of time it takes to fill the washer. What am I looking for to correct the problem. Any help is greatly appreciated.
  • Frigidaire Master
  • 3,463 Answers
Turn water supply off, and remove hoses, check and clean if required the wire gauze filters fitted in the valves..Before reconnecting hoses, check water pressure through the hoses
If still slow filling, and the pressure is o/k, then I would say the only solution is to replace valve(s) as the case may be.
Plz rate my solution.
Thanks.
Posted on Jan 21, 2009
What does error code E-11 mean
Hello Roger, thank you for your inquiry!
Based off the information you have provided you would like to know what an E-11 error code means on your Frigidaire washer. An E-11 error code means that the fill time is too long. This could be a possible problem with your pressure sensor, water valve, or main control panel. If the water pressure is below 30 PSI then it will continue to display the error code of E-11. Also make sure the hoses are not restricted or blocked because this could cause the error code to display. I hope this information has been helpful to you. -Matt
Dec 01, 2015 | Frigidaire Affinity ATF6000F Front Load...
Error code 13. Turned water on to machine and it leaked.
Try this link
it says the following:
E13 Condition Water leak in the tub or air leak in pressure-switch air hose Check/Repair The washer fills for too long without the water level pressure switch tripping to indicate that the washer is full. Check for a leak in the wash tub. If the tub is not leaking, check to see if the washer is overfilling. If it is, check the air hose and water-level pressure switch for problems.
Shop Parts Outer wash tub, Air hose, Water-level pressure switch
Frigidaire Front Load Washer Error Codes Sears PartsDirect
Jun 09, 2015 | Frigidaire Washing Machines
E11 error code
Good Morning Juan, thank you for allowing me to assist you!
Generally, error code E11 indicates that your washing machine is taking a long time to fill (or is continuing to fill).
    ·Is the incoming water flow normal? If it is, does the fill water continue to enter the washer? If yes, disconnect power from your washing machine. Did the water fill stop? If so, a service technician may need to check the pressure sensor or switch to determine if it needs replacement.
    ·If your water flow is abnormal, double-check water faucets to ensure they are in the "on" position. If on, your incoming water pressure may be above 30 PSI and could need adjusting. Check for any kinked or blocked water hoses or clogged water screens. If you've cleared the water screen and/or unblocked any kinked water hoses, and the problem still persists, it could possibly be a water inlet valve assembly.
    ·If you have checked all of the above, your washer may need a main control board replacement. I would recommend contacting a qualified service technician to further assist you in diagnosing this issue.
Jan 16, 2014 | Frigidaire ATF6000ES Front Load Washer
My FAFW3511KR front load washer won't spin on the wash cycle. It has error code 11
Hello Geri Witkowski - I understand that your washer displayed E11. Typically error code E11 indicates that either the unit is taking too long to fill with water or there is a possible leak.
· Try resetting the unit by flipping the household circuit breaker off or unplugging it. Wait approximately ten minutes and restart unit.
· Is the incoming water flow normal? If it is, does the fill water continue to enter the washer? If yes, disconnect power from the unit. Did the water fill stop? If so, a service technician may need to check the pressure sensor or switch to determine if it needs replacement.
· If your water flow is abnormal, double-check water faucets to ensure they are in the "on" position. If on, your incoming water pressure may be above 30 PSI and could need adjusting. Check for any kinked or blocked water hoses or clogged water screens. If you've cleared the water screen and/or unblocked any kinked water hoses, and the problem still persists, it could possibly be a water inlet valve assembly.
If you have checked all of the above, the unit may need a main control board replacement. I would recommend contacting a qualified service technician to further assist you in diagnosing this issue.
Mar 18, 2013 | Frigidaire ATF6000ES Front Load Washer
E-10 code
Hello - Typically error code E10 indicates that it takes too long for water to fill. Contact a professional to run multiple tests to verify that the incoming water flow is normal and to check the electronic pressure sensor. Possibly might need to replace the main control board. Hi - Typically error code E10 indicates that water takes too long to fill. Contact a professional to run multiple tests to verify the incoming water flow is normal and to check the electronic pressure sensor. Depending on the results, washer may possibly have a faulty water inlet valve assembly, pressure sensor/switch or main control board.
Oct 25, 2012 | Frigidaire ATF6000ES Front Load Washer
E10 error code on Frigidaire affinity how to repair it
Your fill time, water fill time, is too long. Have a professional complete the following:
. Is the incoming water flow normal? Yes, go to step (4). No, go to step (2). 2. Are the incoming water faucets turned on? No, turn water faucets on. Yes, go to step (3). 3. Is the incoming water pressure above (30) psi? No, have customer correct pressure problem. Yes, check for kinked or blocked incoming water hoses, clean incoming water screens. If problem still remains, replace the water inlet valve assembly. 4. Does the fill water continue to enter the washer? Yes, go to step (5) no, go to step (6). 5. Remove power from washer. Did the water fill stop? Yes, go to step (6). No, replace the inlet valve assembly. 6. For Better models, check the electronic pressure sensor. For Good models, check the pressure switch. Pressure sensor checks good. Go to step (7). Pressure sensor checks incorrect. Replace pressure sensor. 7. Replace the Main Control Board
Aug 16, 2012 | Frigidaire Affinity ATF7000ES Front Load...
I am getting E10 error code, there is no water going into washer.
Hi
Error E10 in Frigidaire washer means Long Fill. It means that the washer is taking a longer time to fill; it may be due to low water pressure, due to faulty pressure switch or due to faulty water inlet valve. Please try and clean the inlet filter screen. If this doesn't resolve your issue then check the connections at Water inlet valve. Make sure the connections at the fill valve are firm and check the continuity using multimeter. To access the fill valve take the two screws in the back that are connected. Now, pull the back of the cover towards you and lift it off. Check the three multicolored wires connected to the inlet housing that you have to remove. Next remove the two screws on the inlet housing. Now, pull the housing from the detergent cabinet then back towards it to remove the entire inlet unit. Hope this helps... Please post back if you need more information.
Daniel
Feb 11, 2011 | Frigidaire Affinity ATF7000E Front Load...
I leave the door open on my front load washer so it can dry and not have a smell. Twice now I have came home to a flooded house. The machine apparently starts to fill with water on it's own and all the...
Turn off the water at the Fill vale if it now does not fill fit a new Solonoid valve to the fill on the machine...if it still fills with the water turned off then the problem is with the drain Too Low allowing water from the sink to enter machine.....
Feb 10, 2011 | Frigidaire ATF6000ES Front Load Washer
I have a Frigidaire gallery series front load washer that flashes an E10 error code. What is this for.
E10 = long fill.
Check hoses, faucet and water valve screens first. Clean if necessary. If this did not help - something has failed in the washer, either the pressure switch, control board, or water valve.
Apr 10, 2010 | Frigidaire ATF6000ES Front Load Washer
Taking in water then the code E11 comes up and it would not do anything.
This code is for fill time taking to long. The water filling the washer could be to slow. Maybe the water pressure to the machine is to low or the control board is faulty. you can try and reset the error code and try running the machine again.
Jan 07, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
55 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
